Question about Garden
Sprayer wont stop pumping - Garden
My Lamona dishwasher HJA 8650 lower spray arm wont rotate, water is spyaying out and nothing in place to stop it rotating, can you help?
Sounds like the pump that pushes the water up to the spray arm is going south on you.
Check to see if the pump or any of the piping, or sprayer arm jets are clogged.
Feb 23, 2017 | Dishwashers
Garden hand pump sprayer not presssurising
There is probably a leak somewhere in the hosing or gasket. As you try to pump it up, take some soapy water and pour it around sealed areas of the sprayer. Look for bubbles as the sprayer leaks air. Also check the nozzle of the sprayer for a clog. Rinse it thoroughly with hot water until it has cleared any blockage.
Feb 22, 2014 | WD-40 Foaming Bike Wash 1L With Sprayer
Sprayer will not stop pumping when switched to pump mode after primed it will not shut down it just keeps pumping. .
Paint sprayer.
Flip lever down to prime > paint comes out small plastic hose.
Flip lever up to put pressure on spray line.
Problem: prime keeps running and spray line never gets pressure.
Future solution:
You did not clean sprayer very well last time, or it is rusted. When cleaning, run full 5 gallons of cleaner through machine twice.
You should fill spray line and pump with kerosene if machine sits idle more than few days.
We all forget.
Good news: you have prime. If machine doesn't prime, you probably have to disassemble.
More good news: There are two steel balls inside pump. Tap top one with hammer to loosen. Keep machine running. Keep lever up. Start tapping top one. Tap a little harder... keep tapping ... sometimes it will not free up ... take apart pipe and see if you can nudge ball loose >> be careful not to scratch anything... the sprayer is high pressure and all parts have to fit
Oct 07, 2010 | Garden
We have a 457 model hand sprayer. It wont pump to pressure , we think the end has come off the plunger. How do we pull the pump apart?
I recently ordered just the plug on the bottom of the shaft and it solved the problem. the company was really good about sending the plug right out for free at that. it worked and im back in business. just replaced it. no taking the pump apart.
The Pool Tech
Aug 07, 2010 | Solo 457 225 GAL DELUXE SPRAYER EA...
Heater only works when it's on the highest setting (I believe it's the blower setting). Can't get the windshield wiper sprayer to work. Reservoir is completely full!
Heater: make sure temperature slider is all the way to the red /hot zone. This is a different slider than the one for blower speed. Blower setting will not change the temperature. Sprayer: 1) make sure rubber hose from tank to sprayer is purged (full of water). If unpurged, water wont reach sprayer. 2) make sure that hose did not detach. 3) Can you hear the water pump running when activating the sprayer? maybe cable became unhooked or pump is shot.
Dec 08, 2009 | 2001 Dodge Stratus
It is filling and running but the water is not
Could be two different things -- either the pump is not moving water through the sprayer arm, or the sprayer arm isn't free to spin around.
I've fixed one of each in the past year, so either is reasonable.
First, check the easy one -- the sprayer arm.
Open the dishwasher and pull the bottom tray forward so you can reach the sprayer arm.
Reach in and try to spin it around by hand. It should move freely, and if you flick it around, it should spin a full turn around before stopping.
If it's unable to move at all, then look for something stuck like a fork or plastic bag.
If it moves, but very quickly stops spinning, it might be a foreign object or it might need a new sprayer arm assembly. The one I got this year was $38 including shipping.
If the sprayer arm is free and easy to move, then check the water pump:
Start the dishwasher and listen. When it's done filling and sounds like the wash cycle, quickly unlock and open the door.
It shouldn't spray water in your face, but there should be lots of water dripping from the racks and the top (and the dishes, if it's loaded when you do this test!)
If not, then the problem is either a failed main pump or a blocked pump, and the repair will be a bit more money and a lot more time.
If this helps, be sure to click the thumbs-up to tell me so!
Sep 01, 2009 | Maytag Dishwashers
Windshield washer sprayer 4 front.....no no pump sound
The reservoir does not need replacement.
First check for burnt fuse.
Next check if the washer motor terminals are securely connected.
If you want to test the motor connect it to the battery and see if it works. If the motor is fine then this is a wiring fault.
The motor may also be clogged with things like small bits of paper etc.
Aug 17, 2009 | 2001 Subaru Outback
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
