Question about Home
Setting clock it is a tochigi tokei model 1285 wall chime clock. Ive tried to set it a few times to no avail. Could use some instructions
  • 277 Answers
2 Suggested Answers
  • 40234 Answers
SOURCE: does the pendulum swing have anything to do with keeping time? On a tochigi tokei wall chime clock model882-1285 ?
Yes, it does
Posted on Dec 02, 2016
Trying to find a replacement motor for a wall clock. It takes TOCHIGI TOKEI CO. LTD NO (0) JEWEL 22903A 0101E ?
Sorry this site does not sell parts or have any references to look them up other than a search engine like Google.
Nov 16, 2016 | Audio Players & Recorders
Setting tochigi tokei co quartz westminister chime
the 2 hour buttons and 2 minute buttons represent a 24 hour clock ie 2:55 is 1452 hours so press first hour button onces the second hour button 4 times then the first minute button 5 times then the second minute button 2 times
Nov 25, 2012 | Seiko Mantel Clock
How do I set the clock on my RCA RS 1285 radio?
Here are the Instructions for setting the clock on the RCA RS 1285.
1. Press Clock until time flashes (12:00)
2. Press Tuning Up or Down to set the Hours and then press Preset Up or Down to Shift to Minute Digits.
3.Press Tuning Up or Down to Set the Minutes.
4.Press Save to save the settings and stop to quit setting.
Mar 01, 2011 | Audio Players & Recorders
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    Quartz president wall clock, I need to set the chime
    I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
    *Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
    *Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
    If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
    Apr 21, 2010 | Watches
    Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
    Apr 05, 2010 | Seiko Mantel Clock
    Strausbourg Manor Wall Clock chime adjustment
    It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
    Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
    If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
    Rate me, please.
    Jul 29, 2009 | Seiko Mantel Clock
    Salton Chiming Wall Clock is chiming inconsistently
    yes .
    check volume setting.
    if you have a manuval volume control try to clean inside of volumecontrol.if ok fine
    if not ok Replace volume control with same type( new one.).
    Nov 10, 2008 | SkyScan 86709 Atomic Wall Clock
    Instructions for Sunbeam clock model # 882-495
    Move the second button from the left to set, enter the time in 24 hour format via the HH and MM buttons, then move the button to start. The far left switch, on/ is for the chime. Set to on for 24 hour alarms, set to auto for no chime from 11pm til 6am, set to off, to turn it off.
    Mar 29, 2008 | Office Equipment & Supplies
    Home Logo
    81 people viewed this question
    Top Home Experts
    john h
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
