Question about Samsung Heating & Cooling
I have an error on my air con Samsung d6 error what is it thank you
Reset fault codes
http://airconditioningfaultcodes.blogspot.com/2013/05/hitachi-error-codes.html
I think this link should have the answers to your question.
Hope this helps.
Jan 12, 2014 | Hitachi Heating & Cooling
I have a samsung air con model FSO9A1VE the indoor unit is working but the outdoor unit is not the air con may have been ruuning for some time as i was not home
Actually, it's not advised to run the a/c when occupant is out for long time. Check in out door unit for power. If not check thermostat setting. Keep +3 degree minimum for cool, than room temp.And -3 for heat than room temp. If power not in out door, check indoor out put out. No power goes to out door, repair/replace PCB.If power in indoor out put and not in out door, replace wire connected in between indoor and out door. Thanks.
Feb 03, 2011 | Samsung Heating & Cooling
Air con is working, but not cooling the air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 05, 2011 | Samsung AS18A6RB Air Conditioner
My air con is quite new, it just fixed n used about 5-6 months. Today i just turn on the air con then about 5 second it turn off by itself. My air con is LG brand. How can i do now, is it a big problem or...
dear sir/madam
please check when you make on your air con it,s getting turn off from it,s circuit breaker then it,s an electrical short circuit problem if it,s turn off by it,s remote controller then it can be micro control program error.
if you know how to read to a electrical meter then try to check your electrical main source it,s passing electricity to air con and try to find out the problem
if not then try to contact to maintenance personnel. it,s up to you what you want to select option.
hope answer the question
thank you
please vote!
Sep 23, 2010 | LG Heating & Cooling
IDEC aircon E5 error what does it mean?
i am air con tech and i face all ready this problem may be it will help u . e5 error is ur air con not have gas becoze of that the low presser switch give error on disply thanks best regard for all. pls let now if its help full
May 27, 2010 | LG LSC183VMA Split System Air Conditioner
Samsung printer error ssg_thnk-32 diag error
There might be a firmware update on the printer, try that. Also did you try another network cable? Sometimes they go bad.
Apr 18, 2009 | Samsung SCX-4300 Monochrome Laser...
Sony Walkman cassette player/recorder will not rewind the tape
Fat chance to repair yourself! we repair that WmD6c but very hard to do!
Feb 23, 2009 | Sony Walkman WM-D6C Personal Cassette...
I have a Samsung that say Transfer Belt Error
Hi
I have a utility to reset the consumables errors on this printer, but only if the component is past its lifecount. (60k for transfer belt)
Its called CLP-300_Reset_RLCv04.exe or just RLCV-04.exe (if you can find a copy)
If you need a copy, let me know and I'll find some way to get it to you.
I've used it for transfer belt reset and it works.
Dec 19, 2008 | Samsung CLP 300 Laser Printer
Heating & Cooling Logo
26 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
