Question about Panasonic Office Equipment & Supplies
Panasonic projector tv keeps turning off with error of cleaning filter
  • Panasonic Master
  • 6,694 Answers
You have to remove and clean the filter. you can fin the instructions of its manual .
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Dec 06, 2016
The projector turned itself off after couple hours of use and the Temp. red light came on. Power Light turned red instead of orange as usual. After 3hrs I turned it back on, cleaned the dust off the fan...
There are three temp sensor inside the projector and now your projector need full service but if the air filter becomes clogged with dust, the internal temperature of the projector will rise, the TEMP indicator will illuminate and the projector's power will turn off (the TEMP indicator will flash after the power is turned off) The air filter should be cleaned every 100 hours of use.
If you clean the filter with a vacuum cleaner to clean off any accumulated dust. then your projector working normally
Jan 03, 2011 | Panasonic PT-LB50U Multimedia Projector
Keeps turning off
So, Shutting down to protect itself. The error light says it needs service, Cycling power makes it work for a few more minutes, then the Panasonic safety circuit shuts it down. Projector shuts down when bulb life gets to the danger zone, and also when its heat sensor says there is a problem.
So you have a bulb life issue or you have a dirty projector / fan cooling issue??
I say clean it up with some compressed air when it is cool, then check the # of hours the bulb has on it (in the menu).
Lastly brace yourself, the bulb is gonna hurt you :-$
Jun 27, 2010 | Panasonic PT-AX200U Projector
Panasonic projector TV PT-43LC14 has a light yellow splotch on the left hand of the screen. Can this be fixed?
yes and no. it is a burn spot on the light filter on the blue lcd panel due to excessive dust and heat. panasonic does not sell individual parts of the optical engine, so you'll have to replace the entire engine. to avoid it happening again or getting worse, keep the projector cool and dust free. use canned air to blow it out.
Nov 30, 2009 | Panasonic PT-AX200 LCD Projector
Clean the filter keeps popping up and I do not
I found a site with a manual and looked it up - Thanks
Nov 06, 2009 | NEC VT595 LCD Projector
Panasonic projector keeps shutting off
Try this utube link. I did it and it solved the problem in about 30 seconds! Don't spend any money or send out your unit. This does it.
http://www.youtube.com/watch?v=6jGwB05_gdk
May 27, 2009 | Panasonic PT-AX100U-EC DLP Projector
5 minute fix guaranteed
worked for me
Apr 05, 2009 | Panasonic PT-AX100U-EC DLP Projector
Air filter keep popping on screen and shut off after 1 minute.
I had the same problem with my Panasonic tv, just 3 days after a technician came out to fix "fuzzy spots" which were multi colored, but mostly green spots. I really thought that the technician was in some way responsible, but Panasonic insisted that there was no possible way he was. It was going to cost $240.00 for him to come out to clean the air filter, and both the technician and Panasonic insisted that I couldn't do it myself. I had decided to buy a new tv to cut my losses. My boyfriend talked me into trying to fix it, we are both sort of mechanically inclined, and it was going in the trash anyway.
We took the back and top off the tv. It took some looking, but we finally found the filter, just over the projector. We removed the cover, it has to be done from the back of the tv, it is black and held on by 4 small screws, be careful not to drop them into the tv, we dropped one, but it shook out. We vacuumed the filter really well, and vacuumed around everywhere. We put the tv back together, not expecting it to work, but thinking at least we tried. It works great. It has only been a few days, but it seems like the problem has been solved.
Good luck if you decide to try. I have decided not to put another penny into the tv.
Jan 07, 2009 | Panasonic PT-60LCX64 Television
Loss of picture
Yes, it is the projector.
Take the filter out and vaccum it, take the lamp out and use compressed air to clean the dust away.
Be carefull witt the air thoug! keep it a bit away from the projector when u cleand the dust away, to close and you can make big mamages inside it.
And, remeber to keep the filter as cleas as possible, i clean min every 2,5-3 monthes.
Good luck
Dec 06, 2008 | Sanyo PLV-Z4 Multimedia Projectors
111 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
