This is in regards to a tellermate cash counting machine, not a calculator. If I want a negative number do I enter the amount then the negative sign or the negative sign then the number?
Mattimeo310
  • 30 Answers
SOURCE: TI-83 Plus No Longer Squares Correctly
when you type -2 imagine your calculator doing the equation: -1 x 2. The - sign actually stands for a -1 so when you do -2 squared your calculator is simply following order of operations. It first squares the 2 making it 4, then it multiplies the negative making it -4. In order to get around this you must use parenthese. (-2)^2.
Hope this helped
Posted on Nov 23, 2008
SOURCE: Monroe Calculator 7130 - won't print red for negative
turn it off & back on & that should fix it. the ribbon lift needs to reset.
dennis
Posted on Apr 22, 2009
moondogwst75
  • 189 Answers
SOURCE: I want to do subtraction. But when I enter the "
There's a negative button and a minus button. I think you're accidently pressing the negative button. The actual subtraction button is the red "-" button above the "+" button. I hope this helps, but if all else fails, you can always add a negative!
Posted on Apr 16, 2011
JonBrant
  • 129 Answers
SOURCE: i changed my batteries on
Check your MODE menu. You might have it in Sci or Eng
http://www.calcblog.com/mode-menu-ti83-ti84-settings/
Posted on Jul 25, 2011
  • 7993 Answers
SOURCE: i have TI-30xs calculator how do I enter negative numbers
Use the change sign key marked (-) or +/-. Press the (-) key then the number.
Posted on Jun 24, 2012
I have a possible glitch on the Sharp EL-531X calculator. If I use the negative (+/-) key BEFORE hitting enter, the number is made negative as it should be. But for whatever reason, AFTER I hit enter, it...
I doubt that it has a glitch. Although possible, it is not very probable. Try to use the calculator correctly.
Follow the algebraic logic.
If you did not input any value the answer memory contains the value 0.
When you press (+/-) followed by [=] it takes the value in answer memory and negates it, thus giving you (-0).
Adopt a consistent way of inputting numbers, namely always enter the negation sign before the number that is negated. The calculator will enclose the negated number between parentheses, which prevents may errors. Too bad this feature has not been kept in more recent calculators by Sharp.
Dec 04, 2013 | Office Equipment & Supplies
I have a possible glitch. If I use the negative (+/-) key BEFORE hitting enter, the number is made negative as it should be. But for whatever reason, AFTER I hit enter, it displays only -0. If I hit...
2 things how do you disable clerk sign on and how do you program a cash/amount tender key it wont give the amount of change
You can't normally turn off the clerk system as it would facilitate terrible fraud. You are just supposed to sign on and start using it.
All cash registers should be able to calculate change. Press SUBTOTAL once you have entered the items. Now type the amount received from the customer (no decimal point). now press Cash (or other payment key) and the change should be displayed.
Oct 25, 2013 | Casio Parts Cash Register PC Desktop
I have TI-30xs calculator how do I enter negative numbers
Jun 23, 2012 | Texas Instruments Ti-30Xs Multiview...
How to Calculate IRR?
To calculate IRR and NPVEnter the cash flows as follows, remembering the sign convention:
  • Clear previous data by pressing fXY and fCLX.
  • Enter the cash flow at time zero using # gPV [# CF0].
  • Enter subsequent cash flows using # gPMT [# CFj].
  • If a cash flow is repeated, enter the number of times it is repeated (including the first time you just entered) using # gFV [# Nj]. For example, three equal flows in a row would be entered as3 Nj.
  • When you have entered your last cash flow:
    • If you are calculating an NPV, enter your interest rate as # i (consistent with interval between cash flows) followed by fPV [NPV].
    • If you are calculating an IRR, enter fFV [IRR].
This is an excerpt from http://luna.pepperdine.edu/faculty/mkinsman/calculators/hp12c.html
I did not come up with this solution. Just found it for you.
Apr 04, 2011 | HP 12c Calculator
Negative log
Use the log function (common logarithm). See screen capture for markings on key.
To evaluate the negative of a logarithm
Enter the number (argument) of the logarithm
Press the = key to have it calculated.
While result is still displayed, press the sign change key or (+/-).
Beware that -log(number) is not necessarily a negative value.
Another way to calculate -log is to use the relation
log(1/a)=-log(a) .
Your example
3 [EXP] [(] [+/-] 2 [) ] [LOG][=] [+/-]
[EXP] is the key to enter exponent of a power of 10 :It is a shortcut, so no 10 is entered. Respect the key sequence above.
[ (] left parenthesis to prevent ambiguity due to the negaticve exponent. Just a security.
[)] is the enclosing right parenthesis
[+/-] is the Sign Change key
May 06, 2010 | Casio FX-260 Calculator
Where is the negative button, I need to use negative numbers?
There is a key with a "+" sign, 2 arrows and a "-" sign. After you enter a number, hit this key to change it's sign. Hope this helps. Good luck!
Mar 04, 2010 | Texas Instruments TI-30XA Calculator
How do you enter negative numbers on a TI-30X iis calculater?
On the bottom of the calculator near the zero and the enter key it has the symbol (-) that is a negative number symbol
Nov 22, 2008 | Texas Instruments TI-30XA Calculator
k24674
