Question about Home Security
Field & stream safe electronic lock green light comes on but will not open
dmathwizard
  • 113 Answers
SOURCE: small floor safe Sentry Model 3877 electronic lock and key
This manual will answer both of your questions.
http://www.sentrysafe.com/pdfs/OwnersManuals/501664.pdf
Posted on Mar 05, 2008
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Posted on Aug 21, 2008
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
Posted on Jan 22, 2009
loxmith
  • 21 Answers
here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
Posted on Jul 24, 2010
SOURCE: How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Posted on Aug 09, 2010
Where is the battery compartment in my ce electronical digital safe?
do you have a round lock pad. This model has 2 9 volt batteries under the key pad
http://bestbatterytips.com/change-replacement-batter/safes-with-electronic-locks-replacing-the-battery/
Lots of info here
  • How to open digital safe when battery is flat and key not ... www.youtube.com/watch?v=aqC9V7SDKdQ
    • BY KHTHHONL
    • 1 MIN
    • 417K VIEWS
    2012-11-09 · How to open a digital safe when the battery is flat and the ... How to open digital safe when battery is flat and ... How Secure Are Electronic Safe ...
  • Locked out of my Digital Safe [Archive] - PPRuNe Forums www.pprune.org/archive/index.php/t-357319.html PPRuNe Forums > Misc. Forums > Computer/Internet Issues & Troubleshooting > Locked out of my Digital Safe. ... CE (Chinese made) electronic security safe ... battery ...
  • LA GARD LG Basic digital electronic safe lock changing ... www.youtube.com/watch?v=M07EpfSmoAU
    • BY DEANSAFE
    • 3 MIN
    • 99K VIEWS
    2009-10-13 · For instructions on this and other electronic digital safe ... How to change the combination and battery on ... Basic digital electronic safe lock changing ...
  • User Manual for Safe EA25 Installation - Tayabally www.tayabally.com/digitalsafe/mannuals/Safe EA25 Installation... You should change the code as soon as possible after opening the ... BATTERY REPLACEMENT. This safe uses ... MAINTENANCE FOR KEY AND ELECTRONIC SAFE.
  • Elektronischer Digitaler Safe Electronic Digital Safe www.produktinfo.conrad.com/...799999/...DigitalerSafe_de_en_fr_nl.pdf · PDF file Electronic Digital Safe Version 12/08 ... (CE). Any usage other than ... Replace your batteries when both the red and green light illuminate. 1.
  • Instructions for an Electronic Digital Safe ' eHow www.ehow.com > Home > Home Safety > Home Safes Instructions for an Electronic Digital Safe By Shawn McClain eHow Contributor Pin Share ... Replace the used batteries with new ones. For most safes, ...
  • Apr 24, 2016 | Locks & Locksmithing
    Hardline safe lost key & battery flat
    if you have lost the key -- then look on the face of the lock cylinder and see if there are letters and numbers on it,, ( key code ) -- take this keycode to your local locksmith and see if they could make the key. if the code is not there then take the safe down to your local locksmith shop and have them pick open the safe. now if the safe is mounted in your house and cannot be removed - then have a locksmith come out and pick open the lock and make new keys for the safe.
    c...
    Feb 06, 2011 | Safe International Digital Electronic Safe...
    How to set up th ebatteries in my sentry safe DSW5781?
    Locksmiths agree
    1. Remove and discard the screw (if
    equipped) at the base of the lock case.
    2. Turn the electronic lock case to the
    right (clockwise), from 12 o’clock to
    2 o’clock, and remove.
    • Insert 4 new AA batteries (not included) to power
    this lock.
    • Replace the electronic lock case and turn to the
    left (to 12 o’clock) to reassemble.
    NOTE: The yellow LED will light when the batteries
    need to be replaced.
    3. Turn the key (if your safe is equipped with a key
    lock) to the right so the lock cylinder pops out.
    4. Enter the factory code. When the green light appears, you
    have four seconds to turn the handle down to
    open. Try this several times before proceeding to
    the next step.
    To unlock safe:
    Enter the 5-digit factory code, a pre-programmed
    user code, or a pre-programmed user pin
    programming instructions. When the
    green LED lights you have 4 seconds to turn the
    handle and open the safe.
    To lock safe:
    Close the door and return the handle to the
    horizontal position. For greatest security, depress
    the key lock (if equipped) with your finger.
    Aug 15, 2010 | Sentry Fireproof Safe
    Opened micromark safe using factory code, how do i change this to a personel number ?
    Hi have micromark electronic safe no EX2003085561 when i enter code top right hand green light flashes and lock will not open any assistance gratefully accepted
    Stewart
    Nov 23, 2009 | Safe International Digital Electronic Safe...
    I locked my key in the safe and I CAN'T REMEMBER THE CODE THAT THE MANUFACTURER GAVE YOU WHEN YOU FIRST PURCHASE IT. psf80 PRO-SAFE ELECTRONIC DIGITAL SAFE
    Press 159 - safe will beep for each number pressed on the key pad, Then press A or B, the green light will come on. Rotate the knob clockwise and pull the door open.
    Aug 18, 2008 | Office Equipment & Supplies
    My sentry safe will not open after entering the code it reads "err"
    You have to press the program / enter button after you enter the code How to open electronic sentry safes.
    Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
    Aug 10, 2008 | Sentry Fireproof Safe
    How to open my safe with the code
    Apr 18, 2008 | Sentry Fireproof Safe
    Mar 29, 2008 | Sentry Fireproof Safe
    Forgot how to open my fireproof lockbox
    Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
    Nov 03, 2007 | Sentry Fireproof Safe
    Home Security Logo
    64 people viewed this question
    Top Home Security Experts
    Are you a Home Security Expert? Answer questions, earn points and help others
