Question about Sirius Audio Players & Recorders
How to change fuse in sirius snap radio - Sirius Audio Players & Recorders
How to see Sirius number on radio
Once you change the radio to Sirius, change the channel to channel 0 (zero). It should show the Radio ID on the screen.
Apr 25, 2014 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
My Starmate 5 constantly has to acquire signal in my car at home it works perfectly.Any suggestions?
Check the antenna's connector for your car based antenna. Sometimes the little finger tabs need to be gently pushed back towards the center to make a better connection. Be careful not to move them more than a precision screwdrive blade's width or you might snap it off.
Jul 08, 2010 | Directed SIRIUS Starmate 4 Satellite Radio...
My fuse blows everytime i plug in my sirius radio to cigarette lighter...why?
is that the only device that is blowing a fuse? if it is the only thing blowing your fuse you may need to replace the charger. check the fuse to make sure it is the correct size ( usually 10 amp). check the power adapter to make sure there are no loose connections or anything in the plug that doesn't belong there. unplug the radio from the adapter and plug the adapter in without the radio see if the fuse blows . if it blows replace the adapter. if it doesn't blow the fuse check the adapter to make sure it is the right one make sure the polarity is correct
May 12, 2010 | Sirius Satellite Radio Receiver
Broken antenna jack on a Sirius Stratus 5
Are you missing the center pin, by chance (which often snaps if the plug isn't lined up correctly or if you wiggle the lead to connect or disconnect)?
I fixed mine by inserting a 1.5CM piece of very thin but stiff copper wire into the dimple. You may have to 'coax' it a bit with needle nose pliers.
Crat
Oct 25, 2009 | Sirius Satellite Radio Receiver
2006 vw jetta gli sat radio, sirius expired, now want xm
U can't change the provider, the radio's are built to recieve sirius or xm, u can't have both on the same radio.
Jun 13, 2009 | Car Audio & Video
Sirius Sportster 5 won't power up.
Check the fuse in the power to the dock. They blow out all the time.
Mar 16, 2009 | Sirius Sportster 5 Satellite Radio...
Sirius S-50 Portable
Go to device settings - FM Frequencies - select the FM 1 or FM 2 or FM 3, turn the dial to move the FM frequency to that which you want. Press the Sirius Dog to enter this frequency. That's it.
Oct 20, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Sirius Radio Invalid Channel message
1) Do you have a Sirius account?
2) Have you called Sirius and given the serial number of that receiver?
Those are the first two things you have to do to get a Sirius receiver working. (The original owner could have changed his account to use his new receiver, if he has one.) Go to http://www.sirius.com/install - the "activate" part - for details.
Aug 20, 2008 | Clarion (NAVSIR) SIRIUS Radio Receiver
Stuck on 255??WTF
you need to call sirius and activate the new unit the id number is on the bottom sir-alp1 unit or the box it came in
Jan 28, 2008 | Sirius Satellite Radio Sirius SIR-ALP1...
Sirius Problem
The sirius unit does not have any channels in the unit.
You need to refresh the radio (XM allows you to do it online, I dont know about sirius) and leave it powered on for about an hour for it to update the channel list.
Mar 25, 2007 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
110 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
