Question about Cameras
  • Cameras Master
  • 5,412 Answers
1 Switch camera on
2 Aim at subject
3 Press shutter release
Posted on Dec 02, 2016
The front facing camera of my new nextbook flexx 11 will not work, locks up. rear facing camera works fine.
Try a factory reset which will scrub it clean and reload Windows. Unfortunately, it seems to be a known issue. See below the reinstall link.
How to ? Restore Reset a Nextbook Flexx 11 to Factory ...
  • 8 MIN
2016-01-29 · Video embedded · How to ? Restore Reset a Nextbook Flexx 11 to Factory Settings ? Windows 10 ... on a Nextbook Flexx 11 Laptop ... Nextbook Flexx 11 windows ...
  • I have a Nextbook Flexx 11 and my webcam isn't working and ...
    2015-08-05 · I have a Nextbook Flexx 11 and my webcam isn't working ... with my nextbook. it was ... found that both the front and back cameras do not work ...
  • my camera in my nextbook is blank. it wont work. help ...
    my camera in my nextbook is blank. it wont work. help DE. ... I understand that you are experiencing problem with camera not working in nextbook.
  • Welcome to ... the Nextbook Flexx 11 tablet is the ... 11 delivers great image quality to read, work, ... Front/Rear Camera. The Nextbook Flexx 11 features a ...
  • Related searches for nextbook flexx 11 front camera not working
  • Nextbook Flexx 11 USB and Camera Problems - Microsoft ...
    2015-08-12 · Bought a brand new nextbook flexx 11 from ... Nextbook Flexx 11 USB and Camera Problems ... Only one I have yet to overcome is the camera not working.
  • Nextbook Flexx 11 USB and Camera Problems - Qnundrum Bought a brand new nextbook flexx 11 from Walmart, ... Nextbook Flexx 11 USB and Camera Problems. ... and nothing but a black screen on both front and back facing ...
  • Nextbook Flexx 11 Camera Not Working-Idyliq Search Welcome to the Nextbook Flexx 11 tablet is the ... Touch-Screen Technology & Front/Rear Camera. The Nextbook Flexx 11 features a touch ...
  • Nextbook Flexx 11 Camera Not Working_Yaelp Search Results for Nextbook Flexx 11 Camera Not Working: Also try: Ads: Next; Also try: Ads: ©2015 Results for Nextbook Flexx 11 Camera Not Working ...
  • Jul 02, 2016 | Cars & Trucks
    In my 4 camera surveillance system two cameras stopped working
    The screen should say a message similar to "VIDEO LOSS" if it does The power packs or multi power supply to your cameras are easiest to check for starters. Unplug the power to a working camera and plug it into the non working camera close to the dvr. If the camera that didn't work came on, then the power pack is most likely the problem. If it didn't have a message saying "VIDEO LOSS" then it may be the sensor that switches to day/night vision. I have had cameras that when it switches to night vision the screen goes black and unplugging in the power to the camera and re-plugging it in gives it a boost and then comes on. If switching the power from a working to non working camera don't work get the ladder out and unplug and re plug in the connectors at the camera in case it is a connection there. Last if that didn't work would be to take the camera that don't work off and plug it into the end cables to a working camera, if it works then I would suspect the cable to the camera to be bad. Just a process of elimination.
    Nov 29, 2014 | Sony 1/3 Sony Super HAD CCD Outdoor IR...
    New cameras work BUT I have no night coverage on the cameras and wonderful day pictures.
    You don't want to let more light in the hole if you want it to work at night. Plug one of the cameras that work at night into the plug of one of the cameras that don't work at night and see what happens, if the problem moves with the camera then it is a bad camera or the wrong model for your system.
    Oct 05, 2014 | Home Security
    Lorex video camera not working
    First make sure all connections (Both at the cameras and the DVR are connected properly, hand tight.
    Next I would make sure they system is up and running.
    To ,narrow down the problem take 1 of the malfunctioning cameras and hook it up to where a working camera is hooked up (I would strongly recommend putting a label on each Camera (Working and not working)with masking tape and a black marker, same for the cables at the back of your dvr. i;e. Camera 1, Camera 2, Camera 3...ETC) And as for the cameras write known working on a piece of masking tape attached to each and if possible the cable it's hooked up to (just like you did earlier, camera 1 -4)
    Now, with everything running, disconnect one of the no working cameras and walk over to one of the working cameras. IF there all the same cameras just unplug at the camera and leave everything esle as is. Now unhook the working camera, set aside, and plug in the non working camera. If this does not fix it, I would look at both working and non working cameras and make sure any switches that may be behind a panel are EXACTLY the same.(dont change the working cameras settings, just non working) If you have to change the non working cameras buttons try it again. Repeat with second non working camera. If the cameras still do not work then they are faulty. If they did work with or without making any changes to the non working camera then your cable ends and/or cable is bad)
    IF none of this helps, try going to the back of the DVR and switching 1 known working cameras cable with a non working cameras cable. IF this fixes it then you unit is bad, if not, then camera and/ or cable is bad as discussed earlier. This should narrow down your problem and put you on a path to getting the system working, not that you know for sure where the problem is.
    Feb 03, 2014 | Computers & Internet
    Nothing works
    i cant help you if you note decrib exactly the problem...please say me what you have does with the for ffaulty or you have see that the camera dont works...have you proove if the camera works with a external suplly... look your camera has a 5 volt jack find a external supplies for 5volt plus internal minus external in the plug in jack proove if the camera works...if the camera works with external supply this is a typical fuji defect ..the internal board have burn the alimt....fuse
    and the camera dont work with akkus or batteries paolo italy
    Nov 18, 2010 | Fuji FinePix S1 Pro Digital Camera
    Will not show picture and camera is working. Is
    Not too much info here. Based on your statement, I'm guessing you are trying to connect a digital camera to your monitor to display pictures on it.
    1) Does the monitor work fine as a monitor on its own?
    2) Make sure you're on the right display/input setting on your monitor.
    3) How do you know the camera's TV-out function is working? Have you tried it on other TVs?
    Its possible that the camera is not in display mode. Its also possible that the camera's TV-out is not working. Its also possible that something about the output from the camera is not compatible with your monitor. I would try the following:
    1) Test the camera on another TV to make sure the TV-out is working.
    2) If its working, go to the appropriate input/source setting on your monitor, before connecting the camera. Then connect the camera, when the camera is off. If nothing displays then turn the camera on, and see what happens.
    If that doesn't work, it may be possible that your camera displays in a different set of settings (resolution, etc) than your monitor is able to display. Also I would check the manual for your camera to make sure there isn't some way to adjust the settings.
    Feb 16, 2010 | ViewSonic NX1932W LCD Monitor
    Can't get the flash function to work on the vivicam 8018 camera
    There is a switch on the side of the camera that needs to be in down position (scenery) for the camera to flash. Worked for me.
    Dec 26, 2009 | Vivitar ViviCam 8018 Digital Camera
    Olympus Stylus 1000-- The camera is not reading the battery. I know the battery is good because it works in my other Olympus camera, but reads 'empty' when put in this camera
    Your camera may be ok. Every and each camera has different reactions to a battery condition depending on the design of the circuit. Your battery may work ok on the other camera but this camera needs more juice (assuming the camera is working ok). If the camera demanding more power from the battery, try the rechargable batteries. Hope this helps. -James
    Mar 28, 2009 | Olympus Stylus 1000 Digital Camera
    Fisher Price Kid Tough Digital Camera - freezes on logo
    This is a solution for getting a working camera, not really to get your camera working. I phoned Fisher Price and was told to format the camera. Turn camera off, plug into USB, right click on the camera drive in my computer and choose format. When this didn't work for me, they sent me a mailing label to send the camera back so they could send me a new one. The formatting is worth a try, and at least you get a new camera when it doesn't work.
    Jan 07, 2009 | Fisher-Price Kid Tough Digital Camera
    Camera's won't work
    1. check connection wires and terminals are connected correctly there is no struggle in the cable or the cabling has been damage.
    2. check the other three cameras the most simple is to connect the cameras that doesnt work in the terminal that does work!
    Oct 05, 2008 | Samsung Weather Resistant Security Camera...
    Cameras Logo
    37 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
