Question about Vehicle Parts & Accessories
Everstart starter 200 quick start battery charger 200amp engine start, 35amp fast charge 2amp trickle charge, for 12volt batteries,, user manual
Commercial style charger/ jump starter like used at mechanics shop
3 Suggested Answers
  • 332 Answers
SOURCE: MY Schumacher SE4020 10/40/200-AMP Wheel-Style
I researched your question and I did find a website that sells parts for your battery charger. Click on the link or paste it in to your web browser the link is below.
I hope this helps you out and if it does please leave me a Yes that I did help you. Thank you.
Posted on Apr 06, 2011
  • 1591 Answers
Are you asking about internal or external wiring?
To hook it up to a car, the black handle goes to frame ground (not the negative battery terminal) and the red goes to battery positive.
If you need internal wiring, please give me a complete description of what needs to be wired and why (ie - charger works but 200A booster for starting doesn't work, etc)
Posted on Apr 24, 2011
How do I set the settings on my NAPA automatic starter/charger 85-435 to charge my car battery or to try to quick start my car? I have a 1997 VW Cabriolet.
It is best to "trickle charge" a low/dead car battery using the lowest setting. The "jump start" function will probably not have enough juice to start your car by itself. Refer to the manual of your charger for safety precautions.
Oct 03, 2014 | Cars & Trucks
Manaul for schumacher battery charger model se4020
Your battery charger supplier or manufacturer should be able to supply you with an operating manual.
Aug 14, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
My Everstart Maxx Jump Starter 500 amp will not charge and it beeps every 5 seconds unless I pull out the fuse? What is the problem?
I don't think they read the problem right. His charger will not hold a charge, not the car. I'm having the same problem. My charge will not charge when I plug it up to a outlet.
Dec 02, 2012 | Cars & Trucks
Car dont start in cold weather should i fix the ignition swtch or what
cold weather seriously weakens the battery. Chemical reactions in the battery simply can't happen with the same efficiency at colder temps. Try charging the battery overnight with a 2amp "trickle charger" before a cold morning start.
Feb 09, 2011 | 2004 Saturn ION
When Charging a battery with charger do you set it on the 12 Volt 2amp or or 12volt,6amp My Charger is SE-82-6, H943
For charging a car battery that is run down, use the 6 amp setting. The 2 amp setting is for smaller batteries (like a motorcycle or lawn mower battery) or if you are using it to maintain a charge on a battery that is used infrequently (like a boat battery).
May 30, 2010 | Schumacher & Fast Charge Starter Charger
Is the 10 amp se-40ma battery charger to big for my motorcycle battery can it over heat or over charge it
A battery that might sit for a month at a time, would only need a trickle charge or about 1 amp, a charger of this type can stay hooked to the battery for the whole month. A 10 amp would be for a quick charge or only about 4 - 12 hours depends on how fast the battery lost the charge. A 10 amp charge would cook the battery if left for days.
Mar 26, 2010 | Schumacher 10 Amp Fully Automatic/Manual...
Battery in Jeep Grand Cherokee dead this am and less than 1 year old. I have a Everstart 100 battery charger plugged in and on the car. How long does it take to charge the battery. The charger is plugged...
How many amps does this charger put out????
A small trickle charger will take forever to fully recharge a dead battery, you'll need to have a battery charger that can put out enough amps to properly charge a dead battery.To clarify, the chargers sold at Sears, the large square types on wheels are the best for charging dead batteries and they also have an amp meter telling you how much the battery is accepting. After you charge your battery, you should be around 12.5 volts to 12.7 volts. DO NOT OVER CHARGE!!!
Jan 18, 2010 | 2004 Jeep Grand Cherokee
I'm putting on a trickle charger - is it a one amp
The 1 amp and 2 amp on your charger only for 1amp a slower charge and the 2amp is a little faster charge . A charge on a battery works better the slower you charge them,Hope this helps you
Nov 29, 2009 | 2006 Triumph Bonneville T100
My Suzuki GS500F has only 500 miles and is 2006. I had the battery charged at Battery Mart, but it still will not run. Every time I push the start button the headlight goes off, but the light stays on for...
The battery LOOKS new. Your battery is three years old. Batteries age quickly. They normally last 2 to 2-1/2 years. Just get a new battery and ride the bike more frequently. In lieu of that, get a cheap 1amp or 2amp trickle charger and charge the battery for two hours once a week. Be sure to keep water over the plates in each cell.
Apr 18, 2009 | 2006 Suzuki GS 500 F
Battery charger on 2008 Chevrolet Equinox
most chargers have a few different settings you want to put it ona slow charge for about 4-6 hrs bye slow charge I mean it should have a 2amp or a3amp trickle charge unless you are attempting to start the car immeditly the you will you the setting labled starting
Mar 01, 2009 | 2008 Chevrolet Equinox
Vehicle Parts & Accessories Logo
237 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
