Question about Electrolux Ovens
Model EVE636BA Can I use both ovens at the same time - if so how
Oven beeps and gets hot after trying to change the time
Hello Celia;
My name is Peter. I am a retired field service appliance technician.
Open your oven door. You will see a label with your oven model number. Repost with the model number.
The beeping sound usually means the set timing is complete, although it is not.
You either have a bad thermal couple which is faulty (About $25.00-$30.00), or a bad control board. Normally, a control board is about $250.00-$300.00. You can get a remanufactured control board with a one year warrantee for about $50.00.
Get back to us with your model number,
Feb 24, 2016 | Ovens
Instruction manual for necht oven model ame 10001
Hi my parents have got this oven and are trying to locate a spare oven shelf for it, they having a awful time trying to find information about a company that seems to not exist, Can You help ?
model no AME1OO1
May 05, 2012 | Viking Electic 30" Ultra-Premium Select...
Need to set clock on oven
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove '
Mar 19, 2011 | Ovens
How do you get the ge profile oven time set to not on military time. we push clock time and the time, and it defaults to military time.
I don't know this particular model but on a lot of different brand stoves/ovens the clocks only work on military time. I have encountered many of these and they are manufactured to work on this time only. Unfortunately I have one sitting in my kitchen!
Mar 13, 2011 | GE Profile JTP56 Electric Double Oven
How do I clean my Electrolux Icon Oven?
Which Electrolux Icon Oven do you have?
For most ovens, with a use a cloth and hot soapy water (do not use an abrasive cleanser or an oven cleaner), clean the door and the frame of the oven outside of the gasket. Similarly, remove the heavy amounts of spilled food (get rid of sugary or highly acidic food spills particularly) in the oven. Take the oven racks and oven rack support, broiler pan and insert, utensils and any foil out of the oven. Then close the door. If you have a single oven, press Clean. If you have a double oven, select the oven to clean and then press Clean. Select the duration of the cleaning cycle (either by hours (2,3, or 4) or cleaning level (Lite, Medium or Heavy)). Some Electrolux ovens have buttons for the cleaning level otherwise use the up/down arrows. Then press Start. The door will lock and remain locked until the oven cools after the cleaning process. For a delayed cleaning cycle, make sure the time is correct on the clock and press End Time and enter the time you want the cycle to end and then Start.
Make sure the kitchen is well ventilated.
The manuals are available for most from the Electrolux site. Start at and search for your model. (Either search on the model at the top right or under Kitchen Appliances) If you find a page for that model, it will have a Specifications and Guides tab. The manual is in that tab as a pdf.
I hope this helps.
Feb 06, 2011 | Electrolux Ovens
Hi - Please post the model number of you appliance, it will look something like CEC1536.
Jul 02, 2008 | Magic Chef 9512 Electric Single Oven
Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Apr 11, 2008 | Ovens
Kemore Gas oven - trouble igniting
Depending on the age of the oven, it is possible that your ignitor is now weak and it is taking longer to ignite.
Feb 03, 2008 | Ovens
Ovens Logo
Top Electrolux Ovens Experts
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
