Televison & Video Logo
Jennifer Cook Posted on Dec 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I program a dish network remote that I don't use anymore to a receiver I have that the remote stopped working?
Level 3:
Top Expert:
  • DISH Network Master 76,851 Answers
  • Posted on Dec 02, 2016
DISH Network Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994136
Points
237762
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. .
5 Related Answers
Anonymous
  • 374 Answers
  • Posted on Nov 11, 2008
SOURCE: need codes for a phillips magnavox for dish network controller
Follow this link and got to the remote section. Once there shoose the type of remote you have and select remote codes to get the ones for that particular remote that may operate the piece of equipment desired. I hope this is of assistance to yoiu and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Jim
Anonymous
  • 64 Answers
  • Posted on Nov 25, 2008
SOURCE: dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
Anonymous
  • 374 Answers
  • Posted on Jan 07, 2009
SOURCE: new dish network remote not working
The 6.3 remote has a blue number two key tab on it when it is shipped from the warehouse. If you remove the battery lid you will be able to remove the tab by pulling it out.You will need the other keys that should have come with the remote and use the black colored uhf key and insert it into the remote and put battery cover back on. Ensure the UHF antenna on the back of the receiver is tight and in the upright position. Now turn the TV on and using the buttons on the receiver press menu twice. This should bring you to the system info screen. There will be a remote address toward the bottom of the screen and usually this number is 1. Now take the new remote and press and hold the clear SAT button on top until all the lights across the top illuminate. Now release and key in 01 and press the pound key. The SAT button should flash three times. Press the record button and noe try to navigate the highlight to the done or cancel option using the left and right key. You should now have control of the receiver if not the antenna port which receives the commands could be faulty. If you were successful with the remote remember you will also need to program it to the TV itself to enable you to turn the TV on and off and control the volume with the remote. The FINAL issue that may be causing your issue is that the part number you gave does not match a 6.3 remote. A 6.0 WILL NOT WORK WITH THE 510 EVEN IF YOU DO ALL OF THE ABOVE as I tried it the other night to verify the accuracy of information that is put out internally. I hope this resolves your issue and if you need help programming the remote to the TV itself please let me know. Thanks for using Fix Ya.
Anonymous
  • Posted on Jul 19, 2009
SOURCE: My dish network dvr625 tv2 remote will not work
Bring up the System Info screen (Menu 6-1-3, or System info button on front panel). On the lower right hand side you will see the address of the UHF (TV2) remote. On the new remote press and hold the SAT key 'till all the top buttons light once you release the button it should it flash. Then press the number on the key pad the receiver is set to, then the # key. The Sat key should flash three times locking the new code into the remote.
Anonymous
  • 36 Answers
  • Posted on Jan 03, 2011
SOURCE: Dish Network IR Remote's SAT Mode Not Working ____
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
  1. Go to System Info screen (in this case -- obtain by removing smartcard from receiver)
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record.
Hope this helps!
Codes for innovage universal remote to program it with my dish network box
Hi Gw, my name is Mike Houston a Social Media Representative at DISH. I understand you want to program your innvoage remote to our DISH receiver. When we send out our DISH receivers we will include our own DISH universal remotes that can control many different components like; HDTV, surround sound receivers and sound bars. We do not have the codes for other universal remotes to work with our system. I will provide you a link explaining in more detail on programming your remote: http://www.ehow.com/way_5501311_innovage-jumbo-universal-remote-instructions.html
The dish cut out today. the satalite took hours to reset now it is on a dish infomerciall channel and our remote is not able to turn channes but still functions with the tv. we have an old box style...
Hey Ryno4606,
It is possible, while rare, for a remote to no longer be programmed to the receiver after a reset. To fix that a simple readdress should fix the problem. I have provided the steps below to assist you with that!
Addressing Remote to Receiver:
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the numeric keypad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Test remote and see if works.
Let me know if you have any other questions!
Tommy Faust
DISH Network
4helpful
Dish Network IR Remote's SAT Mode Not Working ________________________________________ I programmed my Dish Network Remote (IR 1.5 Blue Button Remote Control ) for my Sharp 27F543 and now the remote would...
Hope this helps!
Steps to set ir 103602 to dish receiver
msg0624
I have provided a link with instructions for programming your remote to your receiver.
Program remote to receiver, step 5:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
IR Remote Control Remote Control: my control is not working...
Guest
I have provided instructions on how you can program your remote to your TV or readdress to your receiver. Readdressing your remote to your receiver begins with step 5; programming to your TV begins with step 6.
Program remote: http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
I hope this helps.
Ray Calo
DISH Network
I would like to control my dish network receiver 3100 with my samsung remote
trifonas_ger
If you are trying to use your Samsung TV remote, it will not work with our DISH receiver. Some universal remotes can be programmed to the receiver but you may not get full functionality with the universal remote. Our remotes are designed to allow for functionality for the TV if programmed to the DISH remote (volume, on/off). I hope this helps.
Ray Calo
DISH Network
Programmed remote to tv now doesnt work the satellite properly
chevymancoop
If the remote is not functioning to the receiver properly, then you will need to readdress the remote to your receiver. I have provided a link with instructions on how to program the remote to your receiver. I hope this helps.
Ray Calo
DISH Network
Our dish network remote is having trouble programing to operate my memorex tv, I tried all the codes in the dish operating guide buy none work, in fact when I called the dish network we tried to program it...
Due to the various remote types used by Dish for their different receiver types they may or may not have another receiver w/ a remote that would be compatible with your system. It also is a possibility that there is another remote that will operate your receiver and TV as well. you can check on Dishnetwork.com to find compatibility or you can provide me with the make and model of your tv and i will research it for you and let you know my results.
What you have right now is a half code situation with the remote. Their is no solution to this than the above or buying a universal remote capable of communicating with your receiver.
Hope this assists you and let me know if I can be of anymore help in the future.
Universal remote
only a uhf remote will work from that location, you will probably need to get a dish network 6.0 or 6.3 remote
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
