Question about Epson Office Equipment & Supplies
Need help connecting Epson XP-330 to the internet
My printer will print offline, but I don't know how to get it on line
jackboy
  • 2985 Answers
SOURCE: epson c43sx not printing
Make sure tiy have set the utility tocyour model of printer,
Make sure all connections are correct.
Reload the software.
Does the printer give a message of some sort?
Posted on Dec 29, 2007
thumu
  • 69 Answers
SOURCE: HP Deskjet D4160
This is Vikram Kumar Thumu from India-Hyderabad. I have seen your issue and I would like to provide my solution on the issue.
Well, this is the issue that could happen with either with Printer Software or with Printer Ink cartidges that could be out of ink or very low in ink...
To isolate and to resolve the issue I recommend you to perform below solution. I hope that this will fix the issue for you.
Solution 1: Hard Reset Printer
1. Turn OFF printer
2. Disconnect Printer from Computer.
3. Remove the Printer Power Cable from wall outlet and then try to remove the ink cartidges from Printer.
4. Wait for a minute.
5. and then reseat the Printer ink cartidges and then Connect the Printer cable to the Computer and then Power ON Printer.
This should generally fix the issue. However, if the issue still persists then I recommend you to proceed further solution on the issue.
Soltution 2:
Right click on the Printer icon of HP Deskjet D4100 Series and then select the option " online " and then press F5 key in the keyboard. to effect the changes.
Solution 3:
Try to print a Cartidges Test page from Printer Properties to check the ink cartidges ink status.
if found issue with ink cartridges then replace them else try to uninstall and reinstall the Printer software.
This should resolve the issue. If the issue still persists then I recommend you to contact HP CHAT SUPPORT or HP PHONE SUPPORT team or HP EMAIL Support on this issue. They can help you further to resolve the issue for you.
If you need any further assistance you can mail me at thumuvikram@rediffmail.com. I 'll be glad to help you ...
Bye.
Posted on Mar 27, 2008
SOURCE: offline problem...won't print
Go to start>settings>control panel>administrative tools>services.
Scroll down the list to "print spooler." Right click on this and choose the "restart" option.
This should fix the problem and print any stuck print jobs.
Posted on Feb 07, 2009
the kowalski
  • 86 Answers
SOURCE: I can not print
You could try to use static ip to remove possible problems with dns retrieving:
  • Set the machine to static ip (Menu -> Network -> WLAN -> Boot Method -> Static).
  • Check the ip number on the machine (Menu -> Network -> WLAN -> IP address)
  • On your PC, go to Control Panel -> Printers
  • Right-click printer, choose Properties
  • Choose Ports and click "Add Port"
  • Double-click on Standard TCP/IP, follow the guide and type in your IP number earlier retrieved.
  • Save settings, press OK and the problem could be solved (if it was due to dns problems).
Also, if it works, you can change the network settings for scanner driver to go to ip address too instead of dns, even if it isn't a problem right now, it could later be.
Posted on Jun 02, 2009
MUKHTAR
  • 2022 Answers
SOURCE: epson lx 300 dot matrix printer not printing properly
Make sure you installed correct printer driver and choose the correct model .and remove the pending print job if it is there.
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Have a nice day and do not forget to rate please...!
Posted on Feb 15, 2010
Installed new ink cartridges. noyw when I try to print I get blank pages
FAQs - Epson XP-410, Top FAQs - Technical Support ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid...
Epson[ Answer ]; How do I print with black ink when a color cartridge is expended? [ Answer ]; I see the message Printer is Offline when I try to print with a wireless ...
Epson XP-400, Top FAQs - Technical Support - Epson ...
Epson[ Answer ]; What should I do if my product is printing blank pages? [ Answer ]; I don'thave the CD that came with my product. How do I install the software for my ...
Epson XP-810, Top FAQs - Technical Support - Epson ...
Epson
Feb 05, 2016 | Epson Expression XP 410 Wireless Printer
How do I change from offline to online?
When running a WIRELESS PRINTER, it happens to me all of the time, Turn the Power OFF, wait 15 seconds and while you are waiting, CLEAR OUT your Printer Que... Then Power back up and then it should work.. If this did not work, then Do it again and UNPLUG ALL the cords to the Printer and wait 30 seconds and then replug them. If it continues, then you need to remove and reinstall the Printer on your list of available printers...
Oct 21, 2014 | Epson WorkForce Pro WF-5690 Inkjet...
How do I change from offline?
Power it down, Unplug, clear out the Printer Que on your Computer and then reboot the Equipment. IF this does not fix it, you may have to delete the printer and reinstall into your computer... IF this a Wireless Printer, ensure you clean the Que before attempting to use it.,
My pinter is off line
check your printer connection to your pc, also check its power supply connection. If the two are OK and still it is offline, try reinstalling the driver software of your printer. If still offline, you may need a help of a technician and resetting the printer may be the last option. If your printer is about 2-3 years old, it may need to be reset using a resetter software.Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Epson Printer Support
Mar 25, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
I could print before but now it says printer is offline and I do not know how to get it back online
There's a button on your printer that says on-line. Press it.
What is the make and model of your printer. Are you directly connected to the printer or is this through a network?
Aug 17, 2013 | Acer Aspire One PC Notebook
Offline
Any number of things that could be causing this but things to try.
  1. Try plugging the printer into a new USB port (assuming you're using USB for connectivity
  2. Try a different connection cable
  3. Check the printer has not been accidentally marked as "Use offline" (WinXP: Right click on the printer icon and look for the relevant line)
  4. Check some joker hasn't set the "Printer Properties" > "Availability" time to limit access
  5. Check the Print Spooler service is running for your computer
Those are all reasonably common issues but usually it comes down to the cable or an OS setting.
Hope that helps, albeit a bit later than you'd hoped.
Jun 23, 2013 | Epson Stylus Photo R300 InkJet Printer
How do i get my hp1200 printer to print, is on a off line mode
Hi Joy,
Disconnect the printer completely from the PC.Unplug its power cable too.
Reboot your PC.
Connect everything again from scratch but use a different USB port to connect to the PC.Make sure everything is well connected.Try printing now.Cant print?
Under printers and faxes,check whether 'work offline' is checked by right clicking on the printers icon and 'Uncheck.Still cant print?
Uninstall the printer driver on your PC,reboot the PC and install software again.If you don't have the installation disks,install from this Hp Support site making sure you select the driver that corresponds with your Operating System[Windows 7,Vista,Windows XP etc]
Hope this helps.Thanks!
Please rate this answer.
Dec 02, 2011 | Office Equipment & Supplies
HP Deskjet 6980 won't print. Says offline but i don't see how to turn it back online. was working. now not.
Printers often go off line for no reason. It can be genuinely off line or the pc is just not seeing the printer anymore To put it back on line all you need to do is open the print queue (double click on the printers icon in printers devices/ printer and faxes) go to File and in the drop down list it will say "Use printer Offline or Use printer online. click on it and if the pc is seeing the printer if will change and the printer will then start up and print. If this does not work then check your cable to the printer or your network connection to reestablish the connection.
Aug 07, 2011 | HP Deskjet 6980 InkJet Photo Printer
Hi i have a epson workforce 620 printer. but my computer says it's offline? my computer is connected via wifi all the other computers on the same network have NO trouble printing via the wireless but...
The Epson printer connected to your system requires drivers to function properly. Drivers link the Operating System and the printer, and issues with the drivers would directly affect the functioning of the printers. If the driver is not able to communicate with the printer, the Epson printer would show an offline message. All users having this problem are advised to check the printer drivers installed on the system using the device manager and if the drivers are found at fault, they would have to be replaced with suitable ones
Get more information to fix Epson Printer Offline Error . Hope this information helps you.
Jul 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
Printer is offline
go in control pannel> printer> right click on your printer there was option use printer online click on it
Jan 17, 2009 | HP Deskjet 3915 InkJet Printer
41 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
