Question about Bissell Vacuums
Need wiring diagram for Bissell lift-off turbo model 3760-1 specifically wiring power and brush switches together
reddevil6
  • 1673 Answers
SOURCE: Bissell Lift-Off(R) Revolution(R) Turbo Upright.
If you have a rubber smell, then the belt is slipping, does the brush roll turn freely while holding the ends? If not then replace it, part #2036619, if it is ok, then the belt has strectched and is slipping under load, part # 2106679, Style 8.
Posted on Jan 21, 2008
  • 97 Answers
SOURCE: We have a Bissell Revolution Lift-Off Turbo 3760-1
these belts need to be changed every 6 months regardless of the way they look.
Posted on Jul 20, 2009
Vac Belts
  • 701 Answers
SOURCE: I have a 3760 lift off bissell. Replace the torn
Did you get the right belt size? The belt you should have bought is this one:
Bissell 3760 Belt
Posted on Nov 08, 2009
heatman101
  • 43501 Answers
SOURCE: Info on how to operate a Bissell Turbo Brush Model 7901-P.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
345erw
Posted on Sep 30, 2010
  • 4088 Answers
SOURCE: I've changed the belt on my Bissell 3760-2 model
Clogs affect the air movement, but not the brush assembly. Remove the brush assembly from the vacuum base. Remove, clean, and lightly oil (with 3-1 or similar) the two end bearings. They are usually choked with debris to the point that they lock the brush roller. Reassemble it without the belt for a moment and check for free turning. If ok, install the belt and test the whole vacuum. Hope this helps!
Posted on Jan 29, 2011
Bissel 3760-4 brush motor doesn't turn on
Hi Tim. I understand the brush is turning & belt is fine. You may want to remove and reseat the canister. If this doesn't work, you'll want to have one of our Authorized Service Centers inspect your vacuum.
Here's a link to assist you in locating one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
Apr 19, 2013 | Bissell Lift-Off(R) Revolution(R) Turbo...
Need a new belt for a bissell lift off revolution turbo
Hi Dale, sorry to hear the belt has broken. Now is a good time to order filters for orders that are $30 or more receive free shipping. Here's a quick link to ordering one.
http://www.bissell.com/parts/?sc=search2&searchtext=3760
Jan 26, 2013 | Bissell Cleanview Helix Deluxe Bagless...
I've changed the belt on my Bissell 3760-2 model but the brush still doesn't rotate. I've checked for clogs and there are none.
Jan 29, 2011 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell 3760 Belt
Nov 08, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
Need tel number for manual
You listed this under a Bissell Lift-Off so I am assuming your looking for a Bissell manual. You can reach Bissell at (800) 237-7691or you can download your manual below. Your unit should be a 3750 or a 3760.
http://www.bissell.com/Product_Search.aspx
Dec 15, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Replacement wheel
The rear number is 2036627, there is no side casing, you would have to replace the whole back, which Bissell isn't making avaiable. But o get the wheel, you might try bissell.com and see if you can order direct, or try a local repair shop to see if they will order it for you.
May 06, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell Lift Off Broken Belt and Brush Roller
I had the same problem. I found that the brush actually melted to the end cap (the one with the square/ovalish end). I was able to pull it off with some force and applied some WD-40, but that only worked for one more use. The brush has again melted to the end cap and it is too deformed to try and fix. I suppose I will have to search for a new brush, but this model obviously has some innate flaws.
Feb 14, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Vacuums Logo
43 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
