Question about Water Water Heaters
    Top Expert:
  • Water Master
  • 49,266 Answers
Call a plumber .might need a new DIP tube or heating element
Posted on Dec 02, 2016
How do I set ao smith pro max model ect 52 on vacation mode
No vacation mode in this heater. I have used this for last 5 years.
Dec 18, 2014 | AO Smith A O Smith Water Heater Hot...
The fitting at the top need to be looked at. Use tolit paper wipe around all the fittings and drain lines over head check the popoff valve next if you got a plastic drain valve. Replace it with a 3/4 nipple and cap or a ball valve full port and hose adapter turn gas valve off and use up the hot water I had a valve break during replasment cool water is better. Use pipedope on fitings
Apr 12, 2014 | AO Smith ECT-52 50 Gallon ProMax...
Not enough hot water ge smartwater water heater gas
1) Copy following links:
2) Low temperature setting, extremely cold incoming water, Water leak or broken pipe running hot out of tank, crossover caused by bad faucet cartridge or bad recircirculation check valve,, bad gas control valve thermostat.
Feb 19, 2013 | General Electric GE SmartWater Household...
Water won't stay hot long
1) Thermostat may be bad, or out of calibration. Set temperature higher, and/or troubleshoot by type of gas control.
Copy following link to troubleshoot by type of gas control valve:
2) Dip tube broken
3) Water leak running hot water out of tank.
Turn off all taps and put ear against pipe listening for water leak.
Dec 08, 2012 | Water Heaters
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I just had a noritz tankless hot water heater converted from LP gas to natural gas, and had the hot water heater moved outside my garage. Before the gas change over and the move, I could turn on my garage...
One thing that comes to mind right off is did they use proper size orifices when they converted? L.P. uses a much smaller size then natural gas because it runs at a much higher pressure. Just a thought but I had a water heater from the factory for a mobile home that had the nat. gas sticker on gas valve and I hooked it up in town to nat. gas supply. Unfortunately it had L.P. orifices and I was in a hurry to get to another job ,lit it turned burner on and left. Two hours later my customer called to say they didn't have enough hot water. Didn't take long to discover what the problem was and correct it. Thank god for good customers. Hope this helps you. Thanks
Nov 24, 2010 | Bosch Indoor Gas Tankless Water Heater...
Hot water heater not venting properly.
Hi .. it appears that your house is very tight. From your description of leaving a window open , it seems that the gas heater is suffering from lack of make - up air. Forcing the gas exhaust up the chimney will not really resolve this. You will still be trying to move air out without any air input to replace it. You may be able to install a spring loaded vent so there will be an air exchange. Something like a dryer or bath vent hood installed backwards .. this might work. There does not need to be much of a make-up air supply .. something like a 1 inch hole might be enough. I have seen this problem in a neighbors house , he weather proofed his house so good, that his fireplace would not light, no draft !
Any thoughts, concerns?
Please Vote !
May 30, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Tankless water heater: cold sandwich effect. While showering, hot water stops for about 1 min and then runs again. Was fine for 5 years.
tankless water heaters are a great appliance with one small draw back they require a constant flow of water through them to maintain production of hot water if the water presure fluctuates they can cut out momentarily or if your water supply is less than great ie hard ,high iron,
sulpher ect.. then the heat exchanger can become plugged over time like say 5 years. Contamination of the flow sensor/presure switch could also be a culprit depending on how handy you are a through cleaning with a good kettle descaler will probably help.
Good Luck
Oct 07, 2009 | Water Heaters
Water Heaters Logo
43 people viewed this question
Top Water Heaters Experts
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
