Question about Kenmore Washing Machines
Kenmore Elite Oasis topload washer overfills. I have replace the pressure switch hose but it did not solve the problem.
  • 38 Answers
If you have gotten that far, you've done good.! I'd say to look at the painted screw on the pressure switch.. Needs to be turned. In clockwise direction to make sure diapham closes.. Or it's possible the circuit board is gone out..
Posted on Dec 02, 2016
Kenmore elite oasis top load error code Ld
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 02, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
F 1 error comes up alot and I have to restart the load 2-3 times
Hello
Fi error code means controller senses something wrong with pressure switch or water level signal
Check water level /pressure switch before replacing controller.Switch could have kinked /clogged hose
Or switch needs to be replaced.
Aug 22, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a kenmore elite oasis washer (Black) and my problem is the error code "F1" and "OL", what can i do to solve this problem?
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!
Aug 14, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis washer has error code f1
Jul 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Oasis HE 27082 Stainless Steel Top Load Washer: I have KENMORE ELITE Oasis He and it kept repeated...
May 18, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Elite oasis washer will not stop draining or trying to drain
Outlet hose not allowing air down the side of the tube making a syphon action (Remove tube from outlet pipe and clean
Pressure Switch not switching over to tell machine it is empty (Clean out pressure switch lines or replace pressure switch)
Apr 01, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Have kenmore elite oasis, type 580. when starting
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!!
Jan 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore oasis elite flashes f1 and wont run it's cycle? Can't find my manual.
The F1 error code indicates either that the pressure signal is out of range or the pressure hose is blocked. This would mean that the control board is defective or the pressure hose is pinched or blocked somewhere between the control board & the outer tub. You can check the pressure hose by removing the rear panel & looking where the drain hose is coming out of the back of the cabinet.
Jan 13, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
