Question about Brother DCP-1510 Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Copier/Printer/Scanner - 21 ppm Mono Print - 2400 x 600 dpi Print - 21 cpm Mono Copy - 600 dpi Optical Scan - Manual Duplex Print - 150 sheets Input - USB
Brother DCP 1510 top cover is open - Brother DCP-1510 Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Copier/Printer/Scanner - 21 ppm Mono Print - 2400 x 600 dpi Print - 21 cpm Mono Copy - 600 dpi Optical Scan - Manual Duplex Print - 150 sheets Input - USB
SOURCE: Brother DCP-7020
Props to Profjake. I followed his advice and problem solved! Here is what I found out.
I had the "Back door open" error on the LCD panel. There is a "interupter" type of sensor that detects if the back door is open or closed. When the back door is closed a lever is pushed forward and blocks the interupt module. The lever that blocks the sensor was not reqching the sensor horizontally - it was too far to the left. The lever on the far right is part of a 6" rod that goes across the middle of the paper path. The rod had jumped out of it's "home" position to the left and it was bowed a little bit. I carefully re-seated the rod to by gently lifting it and moving it to the right into a slot 1/8" from where I found it. The error cleared immediately. The was most likely caused by removing a paper jam.
Once again props to Profjake as his advice led me to the solution.
Hu said that!
Posted on Jun 17, 2009
xptareq2000
  • 1447 Answers
SOURCE: The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Posted on Nov 22, 2009
sys_admin
  • 829 Answers
SOURCE: Message
This error is due to tray problem check if the back tray latch is not broken .also check the Fuser unit at the back if its not been fixed or loose contact.
Regards.
Posted on Feb 08, 2010
Jimsta01
  • 405 Answers
SOURCE: hiya my brother dcp 7010 printer keeps saying back
This is happening because there is a paperjam in the machine and its covering the sensor for the back cover. Open the front cover of the machine and remove the drum and toner, then you can remove the paperjam.
Posted on May 06, 2010
cdiazgon
SOURCE: Brothers DCP 7020 Laser printer. Paper feeds into
I was about to surrender, but tried again in a calmer mode and started checking everything in the paper path thru the printer.There's a small coiled spring that can come loose under the printer. This spring is connected to the plastic lever/sensor that tellls the printer there's paper in the drum/toner chamber.You should see it with the help of a lamp or flashlight, since almost everything under the printer is black plastic. You have to prop the printer on it's back to see it. there'a metal plate exactly below the paper feed rollers, you have take that plate out by removing the six screws that hold it in place. This is to check that the lever/sensor I pointed before is actually inside the hole that holds it in place. The spring, if its loose should be hanging by one of it ends using very small tweezers or needle nose pliers, you should be able to hook it back to the lever/sensor, it has a hooked end where the spring should hook to. The printer is working like a charm again!!! (IF THIS SPRING IS MISSING, IT SHOULD BE REPLACED WITH A SIMILAR ONE, IT IS ABOUT THE SIZE OF A BALLPOINT PEN SPRING, BUT WITH LOW TENSION, IT HAS THE TENSION OF A LEAF SPRING LIKE THE ONE IT THE BACK COVER OF THE PRINTER)
Posted on Feb 23, 2012
Why my brother Dcp 1510 printer shows drum busy
-How long you have this printer ?. If it's been used to print a lot then possibly the imaging drum is out (effect). You possibly can buy a replacement drum.
-But for me I better buy a new printer at the same cost of a drum.
Good luck
Mai
Jan 25, 2017 | Brother DCP-1510 Laser Multifunction...
What Print unable 0B
brother dpc 1510 printer showing on print unable 0B. how to clear?
May 27, 2016 | Brother DCP-1510 Laser Multifunction...
Cover open error even when cover is closed
Open the printer replace the cover sensor if you don't find the rocket wire or terminal.
Oct 20, 2015 | Brother DCP-1510 Laser Multifunction...
Toned ended brother 1510
System error 02:10
Explanation
A problem has occurred with the carriage assembly.
Recommended action
Turn the printer off and allow a few minutes for printer to cool. Turn the printer on and attempt to verify functionality.
If the problem persists, click on Support at the top of the page for additional HP support and contact options.
Jul 27, 2015 | Brother DCP-1510 Laser Multifunction...
Brother DCP-135 unable to clean
How to Open Brother DCP-135C
Loosen + remove 3x Cross-Collar Screws on Control Panel. Rise, 2x unplug Control Cable, Control Panel release to forward. Remove 1x Cross Collar Screw front top left, remove the Casing. Remove upper Cable Covers of Scanning Unit Cables, unplug and free the Cables. Remove Scan Unit Pillar, rise complete up and release backward. Remove 3x Cross-Screws at the front top, 1x inside the Cable Compartment, 2x rear top. Remove upper Cover. Now, the Print Head is accessible.
Brother DCP-135C Oeffnen
3x Kr-KragenSchrauben an Bedienfeld oben loesen. Hochklappen, 2x Stecker abziehen, Bedien-Blende nach vorne ausklinken. 1x Kr-KragenSchraube vorne oben links loesen, Front-Verkleidungen abnehmen. Obere Kabelabdeckungen der ScannUnit abnehmen, Kabel abziehen und freilegen. ScannUnit Stuetze loesen, ganz hochklappen und nach hinten ausklinken. 3x Kr-Schrauben vorne oben, 1x im Kabelfach, 2x hinten oben loesen. Obere Verkleidung abnehmen. Jetzt ist der Druckkopf zugaenglich.
Jan 21, 2014 | Brother DCP-340CW All-In-One InkJet...
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-1510 Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Copier/Printer/Scanner - 21 ppm Mono Print - 2400 x 600 dpi Print - 21 cpm Mono Copy - 600 dpi Optical Scan - Manual Duplex Print - 150 sheets Input - USB Logo
60 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
