Question about Radio Communications
Message: Headset unplugged, keeps popping up and is disruptive. I do not use a headset.
  • 5 Answers
SOURCE: nokia 6260
try a master reset on your phone, this will be located somewhere in the settings
Posted on May 17, 2006
SOURCE: GN 9350 Wireless Headset doesn't ring on the headset when phone rings
It only picks up certain digital rings. I changed the ringer on my phone and had the same problem. To fix it, I had to plug in the little microphone that plugs into the handset lifter and place the mic over the ringer speaker. Now it works fine.
Posted on Mar 18, 2009
SOURCE: GN 9350 Headset won't charge, blue light remains off
Unplug the unit, then take the ear piece and slide the battery off .... When you have the battery detached from the ear piece, wipe off the metal prongs, leave it off for a few minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the unit to be charged. That should take care of the issue.
Posted on Sep 16, 2009
  • 5 Answers
SOURCE: headset not going into pairing mode.
Hold down round button on earbud for 5-6 seconds until the lights blink alternating red and blue.....then, enable your phone/device to connect in pairing mode. This will be a "find device" command or something similar. Once they recognize each other....it will send you a screen to enter a code. This will be 0000.....enter that...and once they pair...you are good to go.
Posted on Mar 08, 2010
SOURCE: Green light stays on....headset not turning on
I have had no trouble with mine (3+ months of good use) until today. Same problem you had - green light won't go out, unit won't turn on. Jonsumer's solution got me to thinking, and this worked for me:
1. plug the charger into the wall.
2. plug the headset into the charger.
3. unplug the headset from the wall.
Plugging & unplugging the headset to charger multiple times had NO effect. It was only when I plugged it into the charger and unplugged the charger from the wall that the green light turned off and the headset began to work normally.
Posted on Jul 06, 2010
Replacing sound board?
Check and replace the socket to headset in the TV. It is faulty. Not the audio output board.
Sep 14, 2013 | LG 47LE8500 47" 1080p LED TV with 240 Hz...
Pop/Clicking Sound From Headset
try to isolate the issue. charge your device and use different cable and see if you will still get the same problem. it is also possible that the headset is faulty
Apr 26, 2013 | Microsoft LifeChatâ„¢ LX-3000 Headset
Just recieved my plantronics 903 backbeat headset plugged it in to charge and just blinks red llight left charged for 5hrs and when unplugged wont come on
Try resetting the headset and see if that helps. Here is the users guide, the reset instructions are on page 10.
Below is the link for the Backbeat User's Guide for more information.
Plantronics Backbeat User's Guide
Good luck from Headsets Direct!
May 14, 2011 | Plantronics Backbeat 903 Bluetooth...
Change battery on a motorola bluetooth H700
Turn off the unit before attempting a battery replacement. Without doing so, the power disruption that the headset will acquire can damage the internal workings.
  • Find the even **** on the bottom side of the unit, where the microphone boom is attached.
  • Place the edge of a flathead screwdriver along these slits, and twist gently back and forth until the unit opens up. Do not completely open the unit up, however.
  • Find the small ring near the plug and the mini-USB port. Use the screwdriver to push under the ring where the battery is found. Push forward gently to pop the battery out.
  • Jun 07, 2010 | Motorola Mobility H700 Wireless Headset
    ClearChat Pro USB headset asks for driver upon install
    1. (Vista) Confirm your system restore point first. It needs to be prior to what you're going to attempt here. If it has a recent restore point, great, but if not, make a system restore before you do this, in case it doesn't work.
    2. In the Control Panel, click System, Advanced System Settings, click System Protection, and click System Restore.
    3. (Optional) Try updating your usb drivers before trying the final step, reinstalling the Vista Service Pack 2.
    4. Here's how to verify if your USB (drivers) in the Device Manager are up to date.
    5. Open the Control Panel, System, Device Manager.
    6. Open the Universal Serial Bus controllers (usually at the bottom of the device list).
    7. Right-click, on your first USB, Updating Driver Software. It will look for the update or let you know (which may take a bit of time) that it is up to date already. Repeat this process on all the USB devices.
    8. If that doesn't work, try this: plug in your headset, and keep it plugged into the usb.
    9. In your Windows Updates, re-install the Service Pack 2. After Vista reboots your computer and finishes the install, unplug your headset from the USB and then replug it in. What you are likely to see is a Windows message indicating that it sees the software and is installing it (minus the windows pop-up message of "where's the driver disc for it?").
    10. Now the trick is to get the headset to play the microphone through the speakers appropriately!
    Oct 20, 2009 | Logitech ClearChat Pro USB Headset
    New vtech phone model cs6229-3 headset keeps saying line in use
    These phones look at the voltage on the line to determine if the line is in use.
    Do you have any devices on the line that get power from the phone line? If so, they may be loading down the phone line causing this issue. If you have these types of devices on your line, try disconnecting those devices and see if the problem goes away.
    Otherwise, your phone line may be defective. You may need to contact your phone company to get the problem resolved.
    Sep 13, 2009 | Vtech Cordless 6041 Phone
    USB Device Not Recognized...
    Your headset is faulty. Open it to check for loose wires.
    May 28, 2009 | Logitech ClearChat Pro USB Headset
    Logitech USB Headset
    its basic (USB Audio)
    browse for the drivers.. or select driver to install
    do it from device manager if you dont get a pop up
    Apr 16, 2008 | Logitech ClearChat Stereo Headset Headset
    Headset compatability
    99% this message coming because the headset u are using is not compatible with this phone, try to go to any accessories shop try their two three kinds of headsets i am sure u will be able to get right one
    Jan 29, 2008 | Nokia 2610 Cellular Phone
    The headset keeps blinking a red light
    I had this very same issue which was remedied when I unplugged the headset recharging dock for approximately 5 seconds then plugged it back in. After about 10 seconds everything re-synced and was fine after that. -No more blinking.
    Sep 02, 2007 | GN Netcom GN 9120 Professional Headset
    Radio Communications Logo
    47 people viewed this question
    Top Radio Communications Experts
    eradiostore
    eradiostore
    Are you a Radio Communication Expert? Answer questions, earn points and help others
