Question about Hisense Televison & Video
Can not change input source on my hisense 40h3e 40 inch tv manually on the tv keeps going back to hdmi 2 and wont change to tv, component, hdmi 1, hdmi2, AV, etc... remote also stopped working.
  • 103 Answers
SOURCE: HDMI Malfunction
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
Posted on Mar 03, 2008
mistersony
  • 320 Answers
SOURCE: HDMI Input Stopped Working Sony Bravia KDL-40S2000
Bad input board BU or AU
Posted on Oct 18, 2008
salsaurbana
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
  • 3 Answers
SOURCE: I need to change the source on my tv to HDMI without my remote
Not sure if yours is the same but Philips codes work with Skyworth and if you hit the TV/AV button on the side of the TV and the table of options should come up. And then with the channel +or- go up and down till you are on HDM1 or where ever you want and then touch the TV/AV again when you are there.
Posted on Mar 28, 2010
SOURCE: No picture on Memorex MLTD3222 flat panel LCD.
I recently got this tv from somone because of this exact problem. I have found a solution that works for mine. You can check to see if it works for you also. What I did was take of the back cover. 3 screws (1 big one in the center and 2 little ones below it). Next look at the power board. If plugged in and turned on the red light on the power board should be lit up. If so your power board is fine. Next find the component that has 4 switches. I manually turned these on and turned the tv on and it worked! Has been working ever since!
Posted on Jun 27, 2010
Codes to upgrade hisense40h3e to a smart tv
There is no code to turn the Hisense 40H3E into a smart TV. This TV doesn't have the network LAN or WI-FI hardware or software. You can only add network streaming by connecting a streaming stick (Roku, Fire, etc.), streaming box (similar items) or use a computer. Most streaming devices connect to the HDMI port; you may need an HDMI switch to share the TV with multiple devices.
Note: the USB port on this TV may not supply sufficient power for some streaming devices. You may need to connect them to an USB power supply to a standard outlet.
I hope this helps.
(the 40H3E does support viewing files from a USB flash drive - see the manual for the list. I found the manual on Manuals Lib here: https://www.manualslib.com/manual/1053975/Hisense-40h3e.html . )
Feb 18, 2018 | Televison & Video
I have an element tv and it has thr hdmi on the back put when I go to input it has component 1 or 2 I tried the compent one then switch to 2 and it still giving me blue screen with no signal
check your remote for the tv. some remotes have hdmi and components input separate. or try another hdmi cable. also keep in mind that some tv's use hdmi as a service port only.
Jun 10, 2017 | Element Televison & Video
Hisense 46" or 48", not sure which, will not change input source. currently on HDMI 3 for fiber optics cable but when HDMI 1 or 2 is selected the source won't change, it just stays in HDMI 3.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 05, 2016 | Hisense Televison & Video
How do I fix hisense TV on standby
Televisions go into standby mode when there is not an input source. First try cycling through the inputs i.e. HDMI 1/HDMI2/CABLE/VGA/RCA etc. next try changing the cable you are using. It may be bad. Outside of that, either the input port has gone bad on the board or the source is not sending a signal, either way this would be something handled by a professional repair technician
May 04, 2016 | Hisense Televison & Video
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
Sceptre TV unexpectedly changes input source away from HDMI
My sceptre tv just started randomly changing through input modes, sometimes once or twice before stopping and sometimes it continues
Jun 30, 2012 | Sceptre X405BV-FHD3 40 in. LCD HDTV
I cant keep my tv turned on after i pushed the rgb button by mistake it keeps on displaying no signal and then it goes off
Turn on the TV again. You need to change the input from RGB back to cable or HDMI or Component or whatever input you have a source for. If you don't know which one, look at the back of the TV and the wires you've got plugged into it.
If it's 1 round coaxial cable, change the input to Cable.
If it's three wires (red, white, and yellow) change the input to A/V.
If it's 5 multicolored wires, change the input to Component.
If it's an HDMI cable, change input to HDMI.
If you cannot change the input before the TV turns itself off, try unplugging the TV from the wall socket for about 10 seconds, and then plugging it back in. If its still on RGB, you're going to have to either find a way to get faster at switching inputs, or find an RGB cable and something to connect it to your TV. This is a last resort however.
Jun 09, 2011 | Televison & Video
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    Note:
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    Note:
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
Mar 01, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Samsung 40 inch LCD LNS4092D No Picture
You need to check the back light is still on when the screen is blank (check through the back).
If the back light is on, need to change the Powwer Board.
but,
no back light, need to change the inverter.
Feb 06, 2009 | Samsung LN-S4092D 40 in. LCD HDTV
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Televison & Video Logo
343 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
