Question about Drills
Dustbuster lithium 16v, light flashing very fast, not charging or working all of a sudden.
The black and decker dustbuster lithium 16 v does not work after it has been on charger overnite....what do you think is wrong
The battery is defective or the charger is, check the charging voltage with a meter.
Oct 14, 2016 | Vacuums
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
Apr 11, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
Are all the Lithium batteries working like this. Mine work for a short time then stop dead. Wait a while then they will work again. Really a pain when you are working trying to do somthing and have to run...
I use the Ryobi Li-Ion tools the L-I batteries will cut off when they get to a low charge level this is to protect the batteries Li-Ion batteries life span is shortened when fullt discharged so when the tool suddenly stops put the battery on charge,also if the battery has a charge indicator light for a more accurite idea of the charge (green is charged,red discharged) hold the test button on then run the tool the light may go from green to red if it does that shows the the charge is about depleted if the light stays green you have a little run time left.
Oct 25, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
New batteries, slow for "ready"
You can have a fast charging of your flash only by using best quality batteries.
I recomend for "continuous shooting" to use LITHIUM AA 1.5V CELLS. They are indeed more expensive than other types, but the quality is the best.
Please let me know if it helped.
Aug 26, 2011 | Nikon Speedlight SB-600 TTL Flash
Our black and decker 14.4 Dustbuster is functioning but the charger does not shot its light that will indicate of charging. we dont know if the charger is not working or just the charge light is the one...
You can test the output of the charger with a multimeter. Set it at about the 20v scale and touch the contacts at point where it connects with the Dustbuster. If you get a reading it means that the charger is working. I would say that the charger is most likely not working because LED indicators very seldom fail while chargers are not all that reliable.
Jun 09, 2011 | Black & Decker Vacuums
18V Litiom Batteries (Skil)
I would return it and tell them that the battery wont work.
Mar 02, 2010 | Skil 18V Lithium Ion Drill/Driver Model #...
Charging Black & Decker Dustbuster
Leave it in the charger for at least 7 hours and then try and see if it works on a full performance time of roughly 3 minutes.
Feb 04, 2009 | Black & Decker V9650 DustBuster Handheld...
Flashing lights
I had the same problem. 1 of four way's can fix it. #1 Put a batt. that has a little charge in that flashing spot 1st. and see if that works. #2 put the batt. in that flashing slot first and then in the 1st slot, If that did'nt work, #3 Put Batt. in backwards for 1 sec. in and out fast. and I do say very fast, In that flashing spot. #4 buy a new one. The one that fixed mine was #1 and it stoppppped flashing, The order I put them in was - 3-1-2-4 I put in #3 batt. first, it was the one flashing And it worked, You may have a bad batt. or it's on it's way out, but try It. worked for me!
Mar 30, 2008 | Duracell AAA NiMH Battery Charger with 4...
Drills Logo
160 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
