Question about Americh Home
Instruction manual Americh bathtub BA7236P - Americh Home
Need an Americh Contura II drain stopper (plug) Ours no longer stays down
Americh does not make that part. You will need to track that kind of part down through your local plumbing store.
US Parts Center
Feb 03, 2013 | Americh Contura II Freestanding Biscuit...
How do you remove and clean, or where do you find replacement jet knobs for americh jetted tub?
their jets un-thread counter clockwise. you will need to contact Americh directly. they will be able to sell you new jet trim.
Feb 19, 2011 | Americh Madison 2 6036 Bath Tub
I bought a jucizzi and there where no manual book instruction how to work the tub
google the model. It'll probably take you to a website like or something close. order a manual.
Sep 26, 2010 | Jacuzzi Home
No I don't think so.\r\nI have an Americh 6 jet
If you have hard water you will get lots of crud build up in the pipes.
Try soaking the jets in the cheapest vinagar you can find. The weak acid in the vinagar is great for getting crud off plumbing. Let it soak for at least 15 min then give it a try.
If this frees it up a little try the cheapest dishwasher powder you can get. The cheap stuff is a little abrasive and works great at cleaning jets.
Jun 05, 2010 | Home
My americh spa tub sounds like the motor is running but no air comes out of the jets.
Make sure the filter isn't blocked and that the air control is turned fully on.
Jun 02, 2010 | Americh Madison 2 6036 Bath Tub
Danger of electrical shock from bathtub?
If the lights come on automatically then you are correct in the possiblity of shock though it is very low as there should be safety measures incorporated into the system for that not to happen in the advent of a malfunction........(but you never know). If the lights are turned on by a switch then leave the lights off and there is no rick due to the fact that no electricity will be conducted to the light.
Jul 11, 2009 | Home
Cracked housing to underwater tub light
I belive but am not positive that those lamp assemblies are required to be low voltage. In other words, there is no safety issue if water contacts the builb or wiring. Call Americh to verify. The lens ought to be easily replaceable so as allow for bulb replacement. Ask Americh.
Jul 11, 2009 | Home
I have an americh walk in tub equipped with whirlpool. water is leaking from the door.
The rubber seal needs to be replaced around the door. Some have two sets of seals, one on the tub and one on the door. Americh should have them in stock, or know where to get them.
Apr 15, 2009 | Home
Home Logo
131 people viewed this question
Top Americh Home Experts
john h
Tom Chichester
Are you an Americh Home Expert? Answer questions, earn points and help others
