Fan adjustment. Fan comes on after heat has shut down
    Top Expert:
  • Computers & ... Master
  • 23,200 Answers
Please explain what it is you are using.
Posted on Dec 02, 2016
When thermostat turned up furnace ignites, heats and fan starts when plenum is up to temp. When thermostat is turned down flame goes off but fan continues to run.
If your furnace is relatively new, as in 10 years old or less, there should be a field adjustable 'cool down' cycle. On the circuit board there should be a dip switch or series of dip switches with 30, 60,90,120 indications. These numbers represent the length of time the relay on the circuit board allows the fan to run AFTER the thermostat satisfies. You may be able to adjust the time frame down one position from where its positioned now.
The second possibility, if the blower never shuts off at all is that the relay itself could be stuck in the closed position and keeping the fan on.
Sep 30, 2015 | Heating & Cooling
Toshiba A135-S4527 starts to power up then shuts down.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
When a blue screen occures...do u load defualt settings in the award bios cmos utility menu? my concern is my cpu tempature and the shut down temp as well as the warning temp. should all go to previous...
The BSOD (blue screen) is most often caused by a bad driver and sometimes by ram. Your computer can shut down suddenly if it's overheating but generally when it's from overheating it will start stuttering...running jerkily...before it shuts off. The screen will semi lock up, things run slow. Obviously it will also feel hot either to the touch or at least the air coming out will be hot or not moving at all. Heat is caused by a bad fan or fans including a bad cpu fan. Of course heat is a big problem.
Though you can adjust when the machine shuts down as a saftey precaution that you still need to address the overheating problem itself. A fan may need to be replaced or you may need additional air flow ie additional fans.
A major cause of heat is a dirty fan due to dust, pet hair etc. Computers, including laptops, need to be cleaned out periodically.
I would look into these issues before worrying about cmos adjustments unless you have changed the settings and this was the result.
May 25, 2011 | Computers & Internet
My Ruud furnace used to regulate 1 deg +\- the set temp. Now it regulates right at the set temp and the fan cuts off while the burner continues to fire for a minute or so then the fan kicks back on for...
It appears to be the fan limiter switch. It comes on at a certain temp when heating up and shuts off on the high end of its setting. Once the burners are shut down, the fan continues for a few minutes to cool down the burners. The limiter switch is adjustable but it sounds to me to be defective and should be replaced. Good luck and stay warm, :-)
Mar 15, 2011 | Ruud Heating & Cooling
Fan runs long after room reaches desired temp. heat goes off and fan continues to blow cold air, have a protech 520 thermostat
Is your 'Heater' you are talking about-- A furnace-- with a burner and a blower?
Either way-- We need to adjust a control that determines WHEN THE FAN RUNS--
Most furnaces have a section where the heated air collects, and there has to be a sensor in that chamber, that senses when that air is warm enough to circulate around--- and when the burner shuts off, the air in that area cools down, and the sensor should shut off the fan-
Can you find the Heated air area?-- and can you find a temperature control in that area?-- Can you adjust the control, so that it shuts off the fan when the air temp drops to 100- to 120 degrees F...
Tell us more about the type of furnace/heater we are workig with, so I can better help you-
Tell us more
Mack B
Jan 18, 2011 | Heating & Cooling
My electric heater is on off why is there warm air coming from the furnace is this normal
That is not normal. It is normal for the sequencer to shut down in an orderly manor however. The heating needs being met the the power is shut down to the sequencer and it shuts down when the bi-metal inside it cools down. If all of the coils and fan were energized the load would be too much so the heating coils are powered up in stages. That does 2 things. Keeps from tripping the breaker and ensures warm air comes out the vents when the fan comes on. You may have a problem with a sticky sequencer.
Nov 13, 2010 | Heating & Cooling
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
If the weather outside is cold and you are running the heatpump/aircondition. Is the fan motor on the outside suppose to stop running. I notice the there is heat coming from the unit after it as been...
yes the fan will shut down during the defrost cycle. But the fan only shuts down during this cycle....other than defrost the outdoor fan motor should be running during a call for heat.
Jan 07, 2010 | Amana Heating & Cooling
My microwave heats but shuts off due to the fan not coming on
A little late for a reply; you probably have replaced it by now.
I suspect it shuts down because the fan is no longer turning on and there is probably a thermal shutoff switch near or on the magnetron to prevent the chance of fire.
Jan 08, 2008 | GE JVM1190 Microwave Oven
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
