Question about Exercise & Fitness
Model 700/a does not heart on 600 setting but works on other settings
What is the factory set idle speed for 5.3 V8 Chevrolet engine ?
Your motor is getting hot because it is broken get a new one
Feb 06, 2018 | Chevrolet Cars & Trucks
Changing the language on roomba pet series
You need to post a model numbers before I can help you.
Now, a three second search of the roomba help section on the roomba website turned up this:
All Roomba 700 Series and select 500/600 Series can provide troubleshooting messages in either English, French, German, Spanish, Italian, Dutch, Danish, Swedish, Norwegian, Finnish, Polish, Russian, Portuguese, Japanese, Korean, or Chinese.
Roomba's default language is English.
700 Series: Instructions for Setting the Language
  1. Turn ON your Roomba by pressing CLEAN.
  2. Press and hold DOCK until it beeps and says the current language.
  3. Release DOCK. Roomba is now in Language Selection Mode.
  4. Now press CLEAN repeatedly until you hear the language you want.
  5. Press and hold CLEAN to turn off your Roomba and confirm language choice.
500/600 Series: Instructions for Setting the Language
  1. Turn OFF Roomba. (Press and hold CLEAN until Roomba's lights turn off.)
  2. Press and hold CLEAN until Roomba beeps and says the currently selected language.
  3. Release CLEAN. Roomba is now in Language Selection Mode.
  4. Press CLEAN repeatedly until you hear the desired language.
  5. Press and hold CLEAN to turn OFF Roomba and confirm the language choice.
Jan 25, 2014 | iRobot Roomba 550 Vacuum
I need to set up the centrious puls teck heart monitor watch, model #6318143, please help
I don't have manual but to reset ..press SET and and ALM together. will beep 3 times.
First set age, then max heart rate, (not sure of next item mine came up as 040), then set 24 hr or 12hr, then set hour, last set minute answer_thread2_side.jpg
Mar 22, 2011 | Centrios Wrist Strap Blood Pressure...
My 2005 Katana 600 F was idling slow at about 600 - 700 RPM so I messed with a throttle screw under the throttle lever. I got it to idle at 1000 RPM where I think it should be. But now when I turn the...
turn the cable adjuster back to its original position ie between 600-700 rpm look to the left hand side of the carbs you will see a large adjusting screw on a metal bracket whilst engine is running turn inwards towards rear wheel until between 1000 - 1500 rpm remember to warm engine first as rpm will rise if idle is set with a cold engine as the engine warms up when riding
Aug 09, 2010 | 2005 Suzuki GSX 600 F (Katana)
I have Sportline S7 Heart Rate watch with no manual. This model is not listed as an option at www.sportline.com I need to know how to set the time. I also need to know if it has the capability to of sound...
In checking out information about my new S7 ECG Heart Rate Watch, I noticed your posting. There is a Sportline website that enables you to down the product manual.... although I'm not sure it pertains to the S7. If this doesn't work, I'm sure there is a manual included with the watch I just received, and I'd be happy to email to you. I'll check back to see if you've posted a response here to see if the below website worked for you first. Posted 7/11/2010 by Mary G.
download product manual - HEART RATE WATCH 7. HELPFUL HINTS IN MEASURING HEART RATE. 8. SETTING THE WATCH FUNCTIONS ... stylish LED Heart Rate Watch measures ECG accurate heart rate with the simple ..... HEART RATE WATCH. Sportline® is a trademark of SPORTLINE, a division ...
http://www.cbs.sportline.com/manuals/SP4421IS01SPO1.pdf
May 18, 2010 | Watches
My Xerox Copy centre C123 shows error code 124-315 pls help
Thats a weird one. The machine is detecting the wrong speeds.
Try this.
  1. Enter Diagnostic Mode ( UI Diagnostic Mode).
  2. At the Control Panel, press and hold the 0 key for 5 seconds, then press the Start button while still pressing the 0 key.
  3. Press buttons 6, 7, 8, and 9 on keypad and press Confirm.
  4. Press the Log In/Out button (button with Key symbol) on the Control Panel.
  5. Select System Settings.
  6. Select Common Settings.
  7. Select Maintenance/Diagnostics.
Then look at these 3 locations and see if they match, If they do not set them to match the machine speed.
  • [700-600]
  • [700-601]
  • [700-602]
Feb 11, 2010 | Xerox CopyCentre C123 Copier
Is there a url that compares all the whole house humidifiers?
go for the Aprilaire 600 but make sure they install the outdoor sensor and set it up for AUTO operation
Oct 01, 2009 | Aprilaire 600 Humidifier
Picture dark
Please check its G2 (grid) volts, should be approx 600-700 volts dc. In some sets it calls Screen Volt.
Aug 09, 2008 | Toshiba 42H83 42" Rear Projection...
Setting Polar CE0537
You do not have the right model number. For some reason, Polar puts the CE0537 in big numbers on the back of the case. The real model number on my unit was in very light engraving right above the words "Polar Electro" on the back of the case. Looks like they have an engraving problem where both the model and serial number are very hard to read. If it helps, my model was S120 and I found the manual quickly on the polar site. The polar site also has the location of model numbers in their FAQ area.
Jun 29, 2008 | Polar S150 Heart Rate Monitor
Exercise & Fitness Logo
77 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
