Question about Audiovox MMDV70CB Car DVD Player
No sound i have the dvd player but it was purchased with the used car i just got..there is no sound coming from the player at all..i need to know what station its suppose to be on and do u have to have the remote for this system
I get a picture but no sound. I bought the car with the dvd player already installed but no directions.
Hopefully you have a remote control for this unit. There is a FM select button. It's to turn on the FM modulator. When you press the button it will select different radio stations on the FM band. Once you select a station on the DVD, tune your vehicle radio station to the same and you will be able to hear the sound. Use this system to select the station with the best reception and less interference.
If no remote is available, there may be a FM button on the DVD player to perform the same function.
May 05, 2011 | Audiovox VOD102 Car DVD Player
What fm station should my PADVD-360 sound come thru?
Sometimes 88.7 , 89.1 just run a scan and wherever the radio sounds clear then thats your station, make sure to preset it in your memory.
Good luck.
Jun 12, 2010 | Power Acoustik PADVD-360 Car DVD Player
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
Advent DVD player in vehicle - can't get sound through speakers
I just solved this problem on my Ford Edge 2010. Start the dvd. Hit the FM button on the remote. It will pop up an FM radio frequency in the top left corner of the screen. For example, ours is 88.7. Tune the car radio to that frequency and the sound should come through the speakers. Hope it works for you.
Mar 24, 2009 | Sony MV-900SDS Car DVD Player
Can't get analog stations
Good Day, Jamievass;
Please disconnect the NEW DVD Player, does analog stations come back? What input are you using; RF, Comp, hdmi? If ok try using another input or you may need a main bord that processes the signal.
Good Luck, big IRISH.
Aug 10, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
How do you work the sound on the DVD player?
I have a 2005 with DVD - but do not have the wireless headphones. I use the AUX button on the front radio to switch between FM/AM/and the DVD Player. I do have headphones jacks in the roof console by the DVD player, but have never used them.
Aug 06, 2008 | 2006 Chevrolet Uplander
Dvd player in van no longer has sound
hi i have a toyota van and i have dvd play in it...the dvd player sound works with the radio station but i for got the channel...so cnu help what channel is it spousd to be....write back plzzz
thnks
Jul 18, 2008 | Eiger Vision AV-1301 Car Monitor
No Sound when playing CD or DVD
Hi, in the menu check that the output is set correctly for dvd playback. ie not through the preout for an amp. It is possible for the unit to be set up to play surround sound for dvd's. Worth a try?
Mar 14, 2008 | JVC KW-AVX800 CD Player
No audio
FM station 88.1 or similar. Set radio to scan while dvd is playing. When the correct frequency is reached, you'll hear sound.
May 06, 2007 | Blaupunkt DVD-ME2 Car DVD Player
Car DVD player sound quit working
Best thing to do in this thing is contact panasonic to see if its compadable with all these differaqnt places your going..see www.panasonic.com or call emc at 1-800-782-4362 they will fix ya up and tighten that sound gap!!!!
Mar 07, 2006 | EMC POWER SUPPLY ASSY-380WATTS Power...
Audiovox MMDV70CB Car DVD Player Logo
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
