? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
When the water won't dispense that usually means that the pump belt is usually stretched or broken. Here is a link to the belt you need and a manual you can view:
it might be the drive belt slipping if the unit is off then the belt is locked onto the belt and then when the unit is switched on the belt slips and if its loose it doesnt hold the belt to the motor shaft
if the belt is more then 6 months old or more, then the belt will have to be replaced reguardless of the way it lookes. belts can stretch over time and when you put the machine on the carpet the friction causes the brush to stop because the belt has stretched. i would try this first. hope this helps
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
The belt has broken and needs replaced. bissell uses a belt driven pump. ther ar two belts, one for the brush, and one for the pump. all can be replaced through the belt access on the left hand side of the machine.
