Question about Kenmore Washing Machines
Kenmore elite top ?oad washer f84 error code - Kenmore Washing Machines
    Top Expert:
  • Kenmore Master
  • 78,010 Answers
F84 Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code
Posted on Dec 02, 2016
Testimonial: "Thanks for the information.That was the problem"
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ...
    • 6 MIN
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - · PDF file Kenmore Elite He3 F11 Error Code How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Keeps Stopping and saying UE
    uE error code 79631512210 Kenmore Elite Washer - Sears ... > Ask an Expert
    Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
    UE Error code on my front loading Kenmore washing machine > Manage My Life > Questions
    Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
    Jan 21, 2016 | Kenmore Washing Machines
    In mid wash the Kenmore Elite Oasis HE flashes F51 and
    check if basket turns freely. if it does replace the main board
    Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
    Error F51 for Kenmore Elite Oasis Toploading washer??
    bad main board or motor possitioner sensor.. most likely motor sensor.
    China made junk parts with a million problems
    Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
    My kenmore elite HE3 front oading washer says 02F
    "F02" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
    Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
    If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
    NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
    Sep 18, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite Oasis Washer Error Code F1
    per sears unplug the washer for at least 10 min then plug back in and push pause or stop 2 time.
    Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
    Error code on kenmore washer
    LG washing machines indicating error code CL may have the child lock activated.
    Try holding down the temperature and eco/rapid options together to turn off child lock.
    Some LG series use "TEMP and OPTION" at the same time.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
    We've had this problem for about a yr when i finally firgured out how to correct it.
    the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get.
    How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
    Aug 24, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite top load washer
    error code with this? f11 or f22 are control board related commucation errors.
    Jun 02, 2008 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    47 people viewed this question
    Sal De
     Brian Main
    Brian Main
