Question about Home
Way to silence . Clock is a wall model and has three holes on the face. Needs to be wound with a key that looks like a skate key. Belonged to my grandfather so it's probably fifty years old.
  • 277 Answers
There is no way unless it has a chime/ silent lever on the dial.
UsedClockParts.com
Posted on Dec 30, 2016
How do I get the chimes to work on a howard miller grandfather clock they worked fine till I rewound the weights and stopped
There are a number of things that can cause this. The most obvious is to ensure the weights have been wound up (either by pulling the chain or using the key that comes with the clock). Next is to ensure the clock isn't on "silent" mode. Some clocks, especially the more expensive models, have a small pull rod just behind the clock face. You can usually find it by opening the front door, and looking just under the wood frame the surrounds the clock face. Pull or push to enable/disable silent mode. The next option is to look at the clock face/dial itself, check to ensure it's not on silent. Sometimes there is a lever on the right or left of the clock face. Next, some "triple chime" clocks have either a turn dial or lever on the left or right of the clock face. This lever usually has four options Westminster, St. Michael's, whittington and silent. Check to ensure it's not on silent. If it's on for example Westminister, try moving it to St. Michaels. If the clock then starts to chime, you know there is an issue with the movement that needs repaired. You can also open the clock, if you feel comfortable and check the lifting levers aren't stuck, I've found this a few times. Additionally, while it's a bit hard to explain, on some movements there is a long rod that pulls almost all of the rods back at the same to make the "bonging" sound when the hour chime arrives. This sometimes ends up misplaced on the wrong side of the chime hammers. As you can see there are a number of things that can cause a clock to stop chiming, but a little research on your model and some confidence and you can usually fix most problems fairly easily. The only exception is if the movement has been neglected over the years (failure to oil etc), in which case a rebuild may be required.?
Dec 02, 2017 | Home
I have a Bulova chime mantle clock, three wind, that needs sync. it is off by 15 minutes (it chimes 1/2 hour on 15 minute time etc. can you help me?
Simplest way is to remove the minute hand on dial and reseat it at the correct setting I.e one quarter turn .recheck the hour chime is on hour etc.replace glass front.
Jun 20, 2015 | Bulova Collins Majestic Triple Chime...
I have wound the clock up but it still does not work
Mechanical clocks need periodic servicing. After so many years, even a well treated clock will have internal oil congeal and cause the clock to not run. I suspect your clock needs to be cleaned and rejoined to run properly.
I operate a clock service and repair shop.
Kliks Clocks
Jan 07, 2014 | Audio Players & Recorders
How to operate howard miller clock 645-342
Make sure all winding springs are wound well- but not overly tightened and set pendulum in motion. The clock needs to level across the face and front to back to work correctly. Time can be adjusted by moving the hands of the clock via the minute hand- allow it to strike once at each strike interval to keep strikes synched to clock time, and fast or slow can be adjusted by either the adjustment onthe pundulum arm or on the mechanism where you see an arc with "F" and "S" on either end.
Depending on model, it will need winding at least as often as the name of the clock type- in other words, a seven day clock should only need to be wound every 7 days.
Sep 17, 2012 | Welding Tools
Lost key to cabinet !!
The locks on sewing machine cabinets are notoriously easy to pick. Is the key hole round or flat? If it is round, use a flashlight and look into the hole. It could be a triangle shaped hole, a square hole, or the male opposite of either. For a hole, find a small screw driver that will fit and fill it between two corners (of the hole) and rotate. For the male opposites, you will need something like maybe a skate key or a clock key, or possibly a piece of hard rubber tubing to fit onto the protrusion. If key hole is flat, find some old keys that slip easily into the slot and wiggle & turn gently until you find one that works.
Apr 04, 2011 | White Sewing 2037 Mechanical Sewing...
HOW TO SET SKYSCAN 86715 ATOMIC CLOCK
first make sure there are fresh batteries in the clock. when you first put the batteries in you will need to look on the clock for the buttons that allow you to choose your time zone., press that button. put the clock in a window or near a wall so that the clock back faces toward Colorado (assuming you are in the united states) colorado is where the atomic clock is located. depending on where you are located you may have to wait till early am (3 to 5 am) to get a strong signal form WWV (the call sign of the transmitter station). you clock should automatically set over night and be ready to go the next morning. you can also manually set the clock, but that kind of defeats the purpose. good luck
Mar 20, 2011 | SkyScan 86709 Atomic Wall Clock
Have a skyscan clock and the the time will not set automatically like it is supposed to. Is there a fix for this
If you're down in hole, or if the signal is somehow otherwise blocked, the clock may never sync with WWVB. Otherwise, you need to try it in different locations and facing in different directions. Some folks place the clock outside once a week or so, and face it towards Colorado to pick up the signal.
Bill B
Apr 19, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Believe chime springs have been over wound
The idea of "overwinding" is probably the most common myth in clockmaking. A clock cannot be wound too tight, unless it is wound so hard that the mainspring breaks, in which case the spring becomes completely unwound and will not wind up again. What has actually happened is that the clock is fully wound, but does not unwind because it is not running for some other reason. Letting down the mainspring would have no benefit.
You're correct that the clock was made in 1974. This is far beyond the expected lifespan of the clock. It is possible that lubrication by a qualified clock repairer could get the clock running again, but considering its age, it may be more likely that the movement is worn out, dirty or corroded and needs replacement.
The three keys should be wound all the way, as far as they will go, once a week. This clock should be self-starting when wound, so the fact that it has been sitting wound without running for years indicates a previous problem that prevented the clock from starting and running the mainspring down on its own.
Nov 04, 2008 | Watches
Home Logo
59 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
