Question about Panasonic Televison & Video
My panasonic tv tc-37lz85 sound ok no images-question-where is the location of the fuse on the t-con board or the power inverter. Need help
    Top Expert:
  • Panasonic Master
  • 80,339 Answers
The fuse will be a tiny wire on the circuit board not a little glass fuse which I think you are looking for correct?.
Posted on Dec 02, 2016
TO REPLACE FUSE ON A T-CON BOARD PANASONIC TV MOD. TC-37LZ85
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Nov 28, 2016 | Panasonic Viera TC-37LZ85 LCD TV
Only the right side of my Panasonic Plasma TV (TC-P50UT50) is displaying. The left is is black with some white flickering lights. Sound and video on the right side are perfect.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 01, 2015 | Panasonic Viera 50" Class 1080p Full HD 3D...
I have a panasonic LCD tv i could hear the audio but i can't see the image of the tv can someone tell me what could be the issue of the tv?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 11, 2015 | Panasonic TC-20LA2 20 in. EDTV-Ready LCD...
Panasonic Viera TC-37LZ85 powers on with a solid red light that does not blink, the screen slightly illuminates but no picture. Blown fuse?
T'Con board fault. In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 10, 2015 | Panasonic Viera TC-37LZ85 LCD TV
Panasonic pv 4561
please check the power supply of your TV,multimeter the export voltage of power supply.if it is defective you can replace it.
if not you need check main boards,and inverter boards
From Wisiny.com can find those parts,power supply,inverter boards and t-con
Nov 17, 2013 | Televison & Video
Panasonic TC-P42G15, plasma flat screen tv owner. lost power while watching, would not turn back on. got flashing red light at first. unhooked all cables, and power cable. plugged back in, tv turned on but...
Please check these 3 boards for blown fuses, bad caps, blown/shorted components.
Power supply, Y-SUSTAIN, and Z-SUSTAIN board.
You should download any one of the PLASMA TV training manuals to learn how PLASMA TV works from the link below, it will help you to get more understanding.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 14, 2011 | Panasonic TC-P42G15 Plasma TV
The picture tube on our 15 month old 37" Panasonic LCD TV does not come on. Is it worth repairing or should we buy a new TV?
15 months is not very long time, contact PANASONIC yet, typical LCD flat panel repair si from $150 and up.
You may have either the power supply or the backlight inverter boards problem.
Please see my basic troubleshooting guide here:
http://s807.photobucket.com/home/budm/allalbums
Jul 18, 2010 | Panasonic Viera TC-37LZ85 LCD TV
Televison & Video Logo
62 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
