Question about Health & Beauty
When I turn on the scooter the power indicator lights doesn't come on but the lights for how fast you travel come on for a few seconds
    Top Expert:
  • Health & Beauty Master
  • 78,289 Answers
Have the scooter battery(s) tested with a load tester. Most auto parts stores or any battery plus store can do this testing for you free of charge
Posted on Dec 02, 2016
My husbands Daytona 4 just started having this charging problem
I'm afraid your batteries have expired. They will show full voltage but the Amps are not being replenished.
Jun 18, 2014 | Drive Medical Health & Beauty
I have a go go elite traveller plus , the battery pack will not lift off my scooter it seems to be stuck , i need to replace the batteries
The manual for this scooter is at http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
The closest info I can find is page 14. MOVING AND TRANSPORTING YOUR Easy Travel Elite
6.1. Moving Your Easy Travel Elite in Freewheel Mode when unfolded:
The Freewheel switch (Fig. 1/17) is used for releasing the brake and moving the Easy Travel Elite without operating the motor. Before activating, make sure your Easy Travel Elite is switched on. Turn Freewheel switch to the "freewheel" position and push or pull the Easy Travel Elite manually.
NOTE: The Freewheel mode can only be activated after the battery is in place and the power switch (Fig.9/1) is turned on. Doing otherwise will cause a fault situation indicated by rapid flashing of the Indicator light (Fig. 9/4). See section 4.2.
WARNING: The Freewheel switch should never be engaged on a slope.
CAUTION: The seat back must remain in the upright position.
They seem to assume removal is obvious, I would check any connections from battery to scooter are pulled out and that freewheel mode is not engaged.
Oct 07, 2013 | Pride Mobility Products Go-Go Elite...
Golden companion II full charge turn key on press lever to go forward it dont move hear clicking sound green light on dash blinks
John count the number of flashes by the green light and it will be the fault code indicating the problem Your owners manual should list the fault codes to be able to determine what the problem is. Ie 4 blinks pause 4 blinks pause. The clicking you hear is the electric brakes being engaged. Hope this helps
Mar 01, 2011 | Golden Technologies Companion II Travel...
Ultralite 480 lacks power, new batteries fitted 5 months ago, shows fully charged, dips down when accelerator lever pressed but stays in green area
The battery lights dropping down while the scooter is in motion is normal; the motors are drawing current from the batteries which is going to drop the battery level slightly. However, if you see the battery indicator lights dropping off steadily while the scooter is in motion (1 bar every few minues or seconds) this can indicate a battery problem. It sounds like this is normal operation!
Nov 07, 2010 | Ultra Products Health & Beauty
After a few seconds cooling fan stops and it doesn't charge.
This usually indicates that the battery is fully charged. Does the indicator light change? Have the batteries been sitting unused for a while? If so, they may have oxidized inside and will no longer take a charge. The charger is indicating they are full, but instead of being full of energy, they are full of crud and need to be replaced.
Nov 06, 2010 | Universal Power Group 24V 5A Universal...
Controller light is flashing and chair will not move
Sandi Count the number of flashes ie: 4 flashes pause 4 flashes pause etc. This will give you the flash error code and your users manual should tell you what the number of flashes indicate. (for example 3 flashes bad brake) Also check to make sure your scooter is not in freewheel. Turn off the scooter and move the freewheel lever in and out of gear a few times then turn the scooter on and see if you still get the flashes. If you can't figure out what is wrong then contact your provider and ask if they can check it out for you. Hope this Helps
Oct 03, 2010 | Pride Go Chair Travel Power Chair
Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
May 09, 2010 | Golden Technologies Companion II Travel...
When I stop the scooter after travelling a short
Hi. Yes, most, but not all machines have a "sleep" mode. More for safety than any other reason. Neil .
Oct 31, 2009 | Electric Strider Maxi 4 Wheel Mobility...
I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Jun 28, 2009 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
