Question about Sewing Machines
Cannot get thecoking to lock the bottom plate to my electric blower so it will start
New model RBV 2400cs
  • Sewing Machines Master
  • 10,755 Answers
This can't be a sewing machine.
Posted on Dec 02, 2016
    Master:
  • 469 Answers
Overlocker Instructions
Bottom blade should be flush with the stitch plate. The top blade should pass below the stitch plate at the bottom end of the stroke.
Nov 22, 2013 | Baby Lock Sewing Machines
Handwheel is locked down
Several things to check. Did the needle break and jam in the bottom? Is the needle bent or did it jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom cut the threads until you can free the hoop and material. Check the bobbin for pieces of thread and fuzz. Check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping and will cause a jam which means the handwheel locks.
Sep 23, 2013 | Brother PE770 Computerized Sewing Machine
New home model 4018 birdnesting problem help
try changing the needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
check to make sure the thread has not come off the thread take
up lever
Aug 05, 2012 | New Home Sewing Machines
When "locking " a stitch, bottom thread breaks and/ or bunches up.
Make sure you hold thread in back of the lowered presser foot when you begin stitching, and that the needle is piercing the fabric so that the fabric isn't slipping down into the feed dogs (under needle plate area).Hope this helps you out,alexlefebvre.Jimmy
Apr 12, 2012 | Sewing Machines
Sewing serge it wont sew after i thread it it just keeps breaking the bottom thread I dont have the manual i lost it
change the needle--flat side to the back of the machine
check to see if
1. bobbin is inserted correctly
2. are there any burrs on the needle plate or bobbin area
3. change thread--use every thread guide
name of machine & model number is not shown
if this is a baby lock machine then go to the website & contact customer service about a manual
Mar 28, 2012 | Baby Lock Sewing Machines
Top thread locks bottom thread bunches and machine makes noise
start with a deep clean and oil. check tensions, top and bottom-stitch should "lock" inside the fabric. make sure you use same thread on bobbin as on the machine. Check needle for nicks or bent. Make thread is threaded correctly, passing through upper tension plate. check tension plate(upper) for rust or lint.
May 31, 2010 | Singer 7462 Mechanical Sewing Machine
I have model 4795. When I received it in the mail
If I were you I would send the whole machine back for replacement
Mar 19, 2010 | Sewing Machines
Model identification to find owners manual
Hi Joanna,
I collect very old sewing machines (mostly Singer) and would be very happy to help you with your 'new' machine. The first thing we have to do is figure out which model you have. Could you please send me a couple of photos? That will help tremendously. Also, there should be a number plate on the right side of the base. Could you tell me what that number is? That will help identify the model and tell us approximately how old the machine is.
Robbie
Jan 31, 2010 | Singer Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
