Question about Garden
Cannot get the base plate to go into locking position on my electric blower - the small bolt just keeps on tuning
    Top Expert:
  • Garden Master
  • 75,822 Answers
The bolt is stripped out, retread the hole and install a slightly larger bolt.
Posted on Dec 02, 2016
How to remove four blade base plate from masport 450 series
use hole where bolt for blade goes insert a large screwdriver or steel rod and get it to catch on the casting or at the grass throw end with base locked you can now undo lock nut. should be lefty loosy.
Feb 26, 2017 | Cars & Trucks
Can't lock miter angle with slide handle
There is a plate under the turntable which needs to be replaced, remove centre bolt locknuts and washer (44,45 and 46) from the underside of the base and lift the turntable off taking care to not loose the detent spring (36) and steel ball (37), turn it upside down and remove the spacer plate (31) and replace it, use a small amount of grease on the spring and steel ball during assembly to keep them in place
Jun 24, 2015 | Hitachi C10FSB 10" Sliding Dual Compound...
How do i change out the battery on my 2007 denali. what is keeping it locked into position
there is usually a small bolt that holds it in place with a rubber block the rubs along the bottom of the battery. Take a flash light and look for the small bolt at the base of the battery,,You need like a 1/4" drive socket with a 6-9" extention on the socket to reach it..Just unscrew the bolt and the bolt and the block will come loose,you just lift it up and out of the way. Remove old battery and reinstall new one in reverse order.
May 21, 2011 | 2007 GMC Yukon XL Denali
How do i change ignition switch on my 19890 ford ranger xl 4x4 2.9L V6
Rotate the lock cylinder to the lock position. On tilt columns, remove upper extension shround by squeezing at 6 and 10 o'clock and popping free of the retainer plate at 3 o'clock.
Remove 2 shroud halves by removing the screws. Disconnect the electrical connector from the ignition switch. Drill out the 2 break-off bolt heads that hold the switch to the lock cylinder using a 1/8" drill bit.
Remove bolts (may have to use a screw extractor). Disengage ignition switch from actuator pin and remove switch.
To Install:
Rotate the key to the run position. Install switch by aligning holes on switch base with hole in the cylinder housing. You may have to move it a little to get the actuator pin to line up.
Install new break-off bolts untill the heads shear off. Connect electrical connector to switch.Then reverse the removal procedure to complete.
Mar 19, 2011 | 1989 Ford Ranger
I need to replace a blower motor on a 1998 GMC Sierra 2500 6.5L diesel. Could you tell me how to go about it, how much of the dash do I have to remove? Thanks
To Remove:
  1. Disconnect the negative battery cable.
  2. Remove the glove compartment from the instrument panel.
  3. Remove the front screw from the right door sill plate.
  4. Remove the right kick panel trim.
  5. Disconnect the electrical connectors from the powertrain control module (PCM), as needed. Remove the PCM and mounting bracket if equipped with a diesel engine.
  6. Disconnect the electrical connector from the blower motor.
  7. Remove the bolt from the right lower instrument panel support.
  8. Remove the blower motor cover.
  9. Remove the blower motor cooling tube.
  10. Remove the blower motor mounting flange screws.
  11. Carefully pull the blower motor forward in order to avoid distorting the fan and pry back on the right side of the instrument panel to as necessary to remove the blower motor.
To Install:
  1. Guide the blower motor assembly into position. Avoid catching the blower fan on any protruding parts.
  2. Install the blower motor mounting screws.
  3. Install the blower motor cooling tube and blower motor cover.
  4. Install the bolt in the right lower instrument panel support.
  5. Connect the electrical connectors, as necessary.
  6. Install the mounting bracket and the powertrain control module (PCM) if removed.
  7. Connect the electrical connectors to the PCM, as necessary.
  8. Install the right kick panel trim.
  9. Install the screw into the front door sill plate.
  10. Install the glove box in the instrument panel.
  11. Connect the negative battery cable.
  12. Check the operation of the blower motor.
Feb 03, 2011 | GMC Sierra 2500 Cars & Trucks
1994 chev pu compressor replacement
Front
Without Air Conditioning
199198 C/K With Air Conditioning
  2. Remove the instrument panel compartment.
  3. Unfasten the forward-most screw in the right side door sill plate. Remove the trim panel from the right hinge pillar.
  4. If necessary for access, unplug the ECM wiring and remove the ECM.
  5. Unplug the electrical lead at the blower motor and if equipped, remove the underdash courtesy lamp.
  6. Remove the bolt from the right side lower instrument panel support. Remove the blower cover and the cooling tube.
    Fig. 1: Blower motor wiring
  8. Unfasten the flange screws and pull out the blower motor. You may have to pry back the right side of the instrument panel slightly. Be careful!
To install:
  1. Position the blower motor and install the mounting screws. Be careful not to catch the blower on anything when sliding it in.
  2. Install the cooling tube and the blower shield.
  3. Install the bolt into the instrument panel support.
  4. Attach the courtesy lamp and the blower electrical lead.
  5. If removed, install the ECM. Attach the wiring harness.
  6. Install the trim panel on the pillar. Don't forget the screw in the sill plate!
  7. Install the instrument panel compartment and connect the battery cable.
Rear
1992-98 Models
(see Figure 4)
  2. Remove the right rear quarter panel trim.
  3. Disconnect the electrical lead at the fan.
  4. Remove the screws and if equipped, the cooling tube.
  5. If necessary, remove the fan retaining nut and lift out the blower fan.
  6. Remove the blower motor.
To install:
  1. Install the blower motor and then position the fan.
  2. Install the retaining nut and then tighten the mounting screws to 12 inch lbs. (2 Nm).
  3. If removed, install the cooling tube.
  4. Connect the electrical lead. Install the quarter panel trim cover.
  5. Connect the battery cable.
Fig. 4: Auxiliary heating and A/C system
Hope helps; keep us updated.
Feb 03, 2011 | 1994 Chevrolet C1500
How to remove blower motor
Try this procedure...
2. Remove the instrument panel (IP) storage compartment.
4. Remove the right hinge pillar trim plate.
5. Disconnect the electrical connectors from the blower motor, as necessary.
6. Remove the bolt from the right lower IP support.
7. Remove the blower motor cover.
8. Remove the motor cooling tube.
9. Remove the blower motor flange screws and ferrules.
10. Perform the following steps in order to remove the blower motor:
Carefully pull the blower motor forward in order to avoid distorting the blower motor fan.
If necessary, pry back the right side of the IP.
11. Inspect the blower motor terminals for distortion.
12. Clean corrosion from the terminals as necessary.
13. Replace the blower motor as necessary.
14. Inspect the flange of the blower motor for damage or distortion that may cause an air leak.
15. Repair the flange as necessary.
16. Inspect the blower fan for any damage and distortion.
Fig. Pull the retaining tab down while turning the blower motor counterclockwise in order to disengage the blower motor
To install:
1. Guide the blower motor and blower fan into position. Be careful in order not to catch the blower fan on any protruding components.
2. Install the blower motor flange ferrules and screws. Tighten the blower motor mounting screws to 20 inch lbs. (2.1 Nm).
3. Install the blower motor cooling tube.
4. Install the blower motor cover.
5. Install the bolt to the right lower IP support.
6. Install the electrical connectors to the blower motor, as necessary.
7. Install the right hinge pillar trim panel.
8. Install the front screw into the door sill plate.
9. Install the instrument panel storage compartment.
10. Install the negative battery cable.
11. Verify the circuit operation.
Hope helps.
Dec 14, 2010 | 1999 GMC Yukon Denali
How do i change the blower motor on a 1994 gmc sierra 1500 truck
GM Full-Size Trucks 1988-1998 Repair Information
Blower Motor - REMOVAL & INSTALLATION
Front
(see Figure 1)
  1. Disconnect the negative battery terminal.
  2. Mark the position of the blower motor in relation to its case.
  3. Unplug the electrical connection at the motor.
  4. Remove the blower attaching screws and remove the assembly. Pry gently on the flange if the sealer sticks.
  1. The blower wheel can be removed from the motor shaft by unfastening the nut at the center.
To install:
  1. Install the blower wheel to the motor shaft and tighten the nut at the center.
  2. Apply a bead of sealer to the blower mounting flange. Position the blower so that the marks are aligned and install the screws.
  3. Attach the electrical connection at the motor.
  4. Connect the negative battery terminal.
1991-98 C/K With Air Conditioning
  7. Unfasten the flange screws and pull out the blower motor. You may have to pry back the right side of the instrument panel slightly. Be careful!
To install:
Rear
1992-98 Models
(see Figure 4)
To install:
Hope this help (remember comment and rated this).
Mar 31, 2010 | 1994 GMC Sierra
Starter replacment instructions
1. The Upper Bolt is easily accessed from the front of the vehicle going OVER the right side of the radiator. It is partially hidden by a black brace. There is a black ground wire going to where a nut(s) are located. This first nut will allow you to take off the ground connection, however the bolt has another nut further in (to the left) which is totally hidden. Remove this first nut.
2. After the first nut is off, remove the ground wire, then using a deep socket 15mm socket remove the second nut which is welded/attached to the bolt.
3. Go under the vehicle to remove the wires from the Starter. The first wire is the positive cable (should be red) attached on the solenoid portion of the starter. Remove the nut and lock washer and detatch the wire. The second wire (single small gauge) goes to the solenoid and is connected using a slide lock - press release connection. It is difficult to see the slide lock and the press release located on the top side of the connection. Slide the red slide lock out and press the release, and pull out the connection straight out. Do not force it, or it may damage the connector. Note the placement of the bottom bolt position on the Starter. DO NOT remove the two (2) small, but long connector bolts on the wire connection end of the starter.
4. Remembering the noted postion: remove the lower 15mm bolt from the Starter. The bolt head is located on the back side of plate moving towards the left side of the Van. It is easily accessed from underneath in front of the transmission. Near the end of removing this bolt, support the starter or it will fall out.
5. Remove the Starter, noting the position of the starter. There should be a separate starter facing plate. If if didn't come down with the starter check up in the starter to flywheel opening and remove the plate.
6. Installation is Reverse of above. The facing plate is a little tricky getting it to stay in place. By starting with the bottom bolt it is easier, Make sure you continuously support the Starter in position to save crossthreading the bolt or starter. Hand tighten only the bottom bolt as youwnat to be able to turn the starter slightly to get the top bolt in.
Starter Bolts are tigthen to 35 ft-lbs.
Let me know if it helped or if you need additional help at fixya.com
Dec 31, 2009 | 1997 Plymouth Voyager
Starter
6. Installation is Reverse of above. The facing plate is a little tricky getting it to stay in place. By starting with the bottom bolt it is easier, Make sure you continuously support the Starter in position to save crossthreading the bolt or starter. Hand tighten only the bottom bolt as you want to be able to turn the starter slightly to get the top bolt in.
Dec 10, 2009 | 1999 Plymouth Grand Voyager
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
