Question about Building Materials
My new Pyle backup unit says stop all the time it's in reverse So I cleaned the eye Then tried too adjust it no luck What's the problem
2 Suggested Answers
  • 42218 Answers
SOURCE: My Pyle backup camera says stop all the time I adjusted the eye no luck I cleaned the eye no luck Then I shut off all the power no luck Can you help
if you are talking reversing camera then you are paying attention to the wrong item
the camera just shows you what is there
it is the proximity sensors that tell you to stop or beep when approaching an object
have their operation checked
Posted on Dec 02, 2016
I have a pyle 36 backup camera when I touch the brake the screen flashes, it keeps working, what could cause this thanks for any help
Possibly poor ground at the tail light assembly.
-Check and re direct ground from the tail light assembly.
Good luck
Mai
Feb 05, 2017 | Pyle Car Audio & Video
Dec 02, 2016 | Cameras
When I power up the unit, the camera is displayed immediately, the backup wire turns the screen off.
There's a wire in the head unit harness that's meant to be connected to the vehicle's reverse light wire. If you don't have a rear view camera, this wire should not be connected to anything.
Aug 06, 2015 | Pyle PLCD23A CD Player
Whe i put the cd in iy doesnt play properly. it plays and stop for a few second and then plays again.
Try cleaning the lazer eye, Buy taken the cover of of it, Use a Q tip. If that dooesn,t help. The lazer is shot , It is a verry costly repair, Just go end buy a different one,
Nov 11, 2012 | Pyle PRO PDCD210 -Dual CD Player w/Quick...
Pyle PLCM4300WIR
The Green wire is a reverse trigger wire. It should be tied into the reverse light hot wire. This tells the monitor to turn on and switch to Video 2 so that it displays what is seen by the backup camera. When you take the vehicle out of reverse thus removing power from the green wire, the monitor switches back to normal driving mode. ( no video displayed ).
Jan 15, 2012 | Pyle Car Audio & Video
Pyle plcm7300bt what does the green wire reverse car wire connect to + or ground
The green wire connects to the backup lights control. When the gear shift is in "Reverse" this acts as the switch on the "Monitor" and turns the system on so you can see what's behind you to safely "Backup" Hope this helps you.
Jan 09, 2012 | Pyle PLCM7300BT 7"TFT Mirror Monitor W/...
I have a subaru legacy 1995 estate, it's the boxer twin turbo and I can't get the reversing lights to work that are on the tailgate. I have checked the fuse (wording on the box all in *** but I have a...
The switch is call backup light switch.
Inspect / clean the entire unit end to end.
Spray WD-40 or similar fluid on the plastic male and female socket ends to rule out bad contact points.
You may use a meter to check the socket for conductive resistance (when pressed)
I attached two pictures to help you identify the plastic socket that you need to disconnect and clean.
UK/International switch may look sightly different from USA version.
Remove / adjust this switch on level ground.
Transmission/gear fluid will leak out during removal.
MAKE SURE THE ENGINE and TRANSMISSION/GEAR BOX IS COLD before removal.
Top off / inspect all fluid level after switch installation.
This backup switch retail for around $45 USD.
Good luck
Apr 25, 2010 | Subaru Legacy Cars & Trucks
Cd player not working
  1. its eye unit may in trouble, clean eye by using a eye cleaning cd
  2. eye alignment is failed, adjust the eye by adjust the screw on the eye
  3. cable may loose contact, re fix cable, check cable replace cable if necessary
  4. low power supply problem, check supply voltage, if it low simply add a filter capacitor of 4700uF/40V accross it.
  5. some time its main board may problem, check and replace it
Jan 16, 2008 | Audio Players & Recorders
Dvd player reading no disc
If you have been using the unit in a dusty environment or in a smoking allowed area the laser lens should be cleaned and the unit should be tried again. Replacing the entire dvd player portion of the unit should also fix the problem. I have not looked into this or tried it yet but it looks to me like any computer dvd player drive would work with this unit. you may have to buy new or modify power and data cables to accomidate size differences but that is also worth a shot. Sometimes player mfg will use parts that interchange between units. Good luck. Dan
Oct 08, 2007 | Pyle PLDVD97N DVD Player
Building Materials Logo
69 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
