Question about Dell Computers & Internet
Dell inspiron M5030 Motherboard replace
I did replace the motherboard, Now the problem is when turn on the logo of Dell comes on for a second and then the screen stays blue/white. do I need to do an special setup?
    Top Expert:
  • Dell Master
  • 8,211 Answers
It could be that the new motherboard is not reading or picking up the hdd drive with its operating system you may have to put a new set back on the hdd.
Posted on Dec 02, 2016
Lap top turns on, but screen blank
Do you get the Dell logo when first turned on? if yes this indicates hard drive trouble, but if there is no logo the problem will be motherboard, first remove one ram memory stick, if no change remove second piece and replace the first, no improvement it is time to have the motherboard assessed.
Jun 13, 2012 | Dell Inspiron 1525 Laptop Jet Black
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Apr 04, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Dell 3000 beeps twice no video after blue dell logo.
The most possible cause is that RAM isnt attached properly on motherboard, it might loosen up sometimes. So just try to check your motherboard, pull out the RAM carefully from the RAM SLOT & attach it precisely. Hope it will work....
Feb 29, 2012 | Dell Dimension 3000 PC Desktop
Are soyo monitors compatable with dell computers?
try running it in safe mode tap f5 when you see the dell screen. if it boots to safe mode remove the driver for the display adapter in device manager. the dell computer doesn't know what kind of monitor it's plug into. install the soyo monitor driver
Jun 13, 2017 | Computers & Internet
Hi, I have a Westinghouse 42"
The only other thing that I would think to replace on this is the power board. You may have bad power going to the main board. Other than that you may be at the point of no return on that TV.
Mar 01, 2011 | Televison & Video
I have a dell laptop. When I turn it on Windows comes up and it stays on the screen that says windows and has the bar that goes from left to right to tell you it's booting. It never stops doing that. I...
Shut the system down by holding the power button for 5 seconds or more. Turn the system back on, as soon as the blue dell logo goes away tap f8 on the keyboard. This should bring you to a menu from which you can select "safe mode". See if it starts in safe mode. If so, troubleshoot further from there. If not press f12 on the dell logo and choose diagnostics. Run a quick scan, see if any errors are returned for the hard drive.
Feb 24, 2011 | Dell Latitude D600 Notebook
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Blue screen with dell logo??
This is usually called the "Blue Screen of Death" and the system tries to dump memory
See if you can Read any of the text which may detail the error
Try starting it in safe mode by tapping F8 every few seconds during startup
If it starts post back and i'll tell you how to use system restore
If it still fails then call in an Engineer
Oct 14, 2008 | Dell Axim X50v Pocket PC
Doesn't start
hi, if ur screen turns white, it could be any problem starting from ur LCD to motherboard or as u said a virus. to assist u in a right way i need to know what exactly is happening between that short duration between pressing the button and white screen. most importantly is anything else comming up on the screen before the white screen.
cheers
Oct 12, 2008 | HP OmniBook 500 Notebook
Will not go past startup screen
I think u need to updrage ur bios and RE-INSTALL UR WINDOWS
Oct 26, 2007 | Dell Inspiron B130 Notebook
Computers & Internet Logo
29 people viewed this question
Alun Cox
