Question about Boating
JOHNSON OUTBOARD 1990 30ELEN WHAT IS THE COMPRESSION NUMBER SUPPOSED TO READ ON A COMPRESSION TEST... (HOT OR COLD ENGINE? TKS JERRY
    Top Expert:
  • Boating Master
  • 51,484 Answers
As long as all cylinders are the same there should be no problem only a guess anymore as I have no manual to refer to since my dealer sold out but it might be 90 or close to that
Posted on Dec 02, 2016
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
My boat motor Johnson 90 hp will not rev up throttle is wide open have checked coils fuel pump new spark plugs. all good boat sank a few years back. before that ran great.it is a 1986 unit
it sank..ooopppsss...sounds like trouble.. First thing I would do is check the compression with a gauge... This will require a GREAT friend.. remove all the spark plugs - makes PULLING the engine over easier.. get a compression gauge (or take it to a competent professional to get the compression checked!). Install the compression gauge... Put the throttle wide open... have your buddy yank with ALL his heart about 6-8 times..it should show about 115psi+ minimum..all 3 cylinders should be with 10+-psi.
If they are not at these specs minimum..you have found the issue..then try putting a little outboard oil into all three cylinders and repeat the test.. if the PSI goes way up.. you have found the issue.
Jun 11, 2017 | Johnson Boating
How to find the model number for my johnson outboard from serial number
On the port side where the outboard attaches to the boat there is a plate that has your engine model and serial number.
May 07, 2017 | Johnson Boating
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
Johnson V4 outboard #C0020325 I'd like to know the year and hp of this engine
call your local outboard dealer . they will help you figure it out
Sep 12, 2016 | Boating
What should the compression be on a 1988 evinrude 185hp outboard?
The compression on your Evinrude outboard should be at least 100 with no more than 10% difference between cylinders. Keep in mind gauges can give very different results. Also, remember the test should be run when the engine is warm!
Hope this helps!
Jun 13, 2016 | Johnson Evinrude Ignition Kit, Digital,...
What year is my Evenrude 5.1 outboard
provide a model number and perhaps someone can assist you .
May 10, 2016 | OMC Johnson Evenrude 9 1/4" X 9" Stainless...
My 1988 ( i think) 6hp Johnson outboard motor is always hard to start if it is cold. It can take 10 - 15 minutes of pulling on the cord to start it when cold but will start first go every time once it has...
I would suggest you replace the 2 coils. Also, is choke closing properly? The carb if never rebuilt, could cause this problem. A carb kit and 2 coils should not cost much, maybe 20 each for coils and 17 for carb kit. Make sure carb is adjusted properly with outboard in water and warmed up. Mixture screw should be turned in slowly clockwise until engine just pops(lean). Then slowly open it apprx. 1/8 turn. This will aid engine in starting next time. Also, make sure primer bulb firms up when squeezed.
Feb 09, 2011 | Boating
Engine not running
Let it dry out a day or so, perhaps in the sun or a warm place. Try again. If it still won't start, try to find a fuel line or fuel jet and inject some compressed air in to blow it out a bit. Good Luck!
Dec 16, 2008 | Boating
Boating Logo
97 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
