Question about Miscellaneous
Amni registered at ps?ra? - Miscellaneous
I have Royal alpha 600/601SC Cash register with PS-700e bar code reader.I purchased one PS-700P bar code reader for that after the original got damaged. But I have problems with this unit. it does not
the clue is in what youve typed
you used to use a 700E type
you replaced with a 700P type
perhaps look for the 700E type that matches the older type you have
i would assume the last letter is the series ident so the one you replace it will it newer
perhaps doesnt communicate in the same exact way
Nov 30, 2014 | Royal Alpha Retail Supplies
What is going on with my sharp register xe-a102 it shows all zero's and when the feed button or the tax/ra button is pressed (no other keys will work) the register beeps continually till i turn it off.
Two very real possibilities. The machine received water damage, or the CPU blew up. Usually when you see all 0's in a display that is what it indicates. Sorry. Fortunately those are very cheap machines.
May 27, 2014 | Casio Parts Cash Register PC Desktop
My samsung er 290 wont stop printing till roll
system option 21.Key on pgm press 21-RA-1-PO-CASH. Turn you key to reg and press PO. Good luck
Jan 28, 2014 | Sam4s Samsung Er-290 Cash Register
I have an lxd 75 goto mount. When I align on a star the ra motor skews to infinity and registers a motor fault. It skews just fine from the hand controller but when I try to align during setup it goes...
most probably has a faulty shaft encoder on the ra motor. If the encoder is working correctly the fault will lye in the H-Bridge circuit that drives the motor or if you're really unlucky, further up the signal path from the detectors
Sep 06, 2013 | Coronado LXD75 Mount and Tripod with...
Rotel RA 12
I think RA 12 is not existing type, but RA 12xx types exist.
Please try this link, and I hope you will find the relevant documentation.
gylacz
Mar 18, 2013 | Audio Players & Recorders
How do i reset the x2/s2 readings on a casio se-s300 cash register please?
Try turning the key to X2/Z2 then press RA until you see the report that you want. then press CASH.
Nov 24, 2011 | Computers & Internet
Dera Sir/Madam, my Navigon 33xx screen is cracked. I can switch it on but the screen became insensible. It is possible to change the screen, how much could be cost and where can I make it in Leeds? Thank...
I can understand the problem in the unit so to over come this problem you have to send the unit in for repair . Please contact the technical support to send the unit in for repair .They will register your unit problem and they will provied you a Repair Authorization number (RA).You will need a Return Authorization (RA) number prior to shipping your product to Magellan for repair.
An RA number is required prior to shipping your product to Magellan for repair.
Hours: Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT Telephone: 800 707 9971
thank you
Feb 18, 2011 | Navigon 3300 Max Car GPS Receiver
Entering a sales transaction
You use RECIEVED ON ACCT (sometimes labelled RA). That will allow you to receive money into the drawer without logging it under a PLU or Dept.
Apr 30, 2009 | Casio Parts Cash Register PC Desktop
I want 5600 umax astra scanner driver
Go here for the driver for the umax 5600 astra scanner:
http://www.opendrivers.com/freedownload/233307/umax-scanner-astra-5600-5650-driver-windows-98se-me-2000-xp-download.html
Go down the page and put the code you see into the box. It looks like this:
Press Download.
Fixya!
Chris (ziraffa)
ps Remember to rate this solution as Fixya!
Jan 09, 2009 | Umax Astra 3400 Flatbed Scanner
Sharp cash register dont know what the keys are
You should be able to go to Sharp support and search your model number for a copy of the operator's manual. If it's an older model send me the model number and I'll look for one. Good luck and God bless.
Jun 14, 2008 | Office Equipment & Supplies
Miscellaneous Logo
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
