Question about Asko Washing Machines
My front loader asko W6564 won't start, making noise like trying to but can't
  • 1028 Answers
SOURCE: Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Posted on Sep 07, 2008
  • 2712 Answers
SOURCE: a Kenmore washer/dryer combo front
Check the bearings. I suspect they are faulty..
Posted on Sep 28, 2008
  • 2605 Answers
SOURCE: We have an asko 10504 front loader washing
Welcome to FixYa.
Have you checked the pump to insure the filter isn't clogged or debris causing the noise ? Or do you know where it is and how to check it ?
In the event the washer can't drain sufficiently it will not spin properly either. This is by design, but it's easy to confirm or dismiss.
Check as follows...
**Unplug the unit from the dryer or the wall which ever scenario applies to your set-up, or turn off the breaker at the home service first**
Remove the lower panel with two screws and then you'll see the pump filter/insert as shown here...
Once here, twist the filter out ( make sure you've got some towels, a wet/dry shop-vac or a drain in the floor close by as there WILL be water present ) and check the filter, pump, and hoses to the pump, drain etc. thoroughly for debris.
The filter should look like this...
Let me know if any of this isn't clear and I'll attempt to help you move forward. Once you've cleared the pump filter or ruled out it was indeed blocked or not, you can now try a short spin/drain cycle to listen for whether the noise is still present.
Let me know how you make out. Thank you for choosing FixYa and good luck. Please take a moment to rate the info provided for you here today at FixYa.
Macmarkus :)
Posted on Dec 11, 2010
  • 6277 Answers
SOURCE: whirlpool front loader 7.5kg model
Manual first!
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
Won't drain
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jul 24, 2011
  • 7 Answers
SOURCE: Samsung front loader washing machine making noise
Posted on Jun 17, 2012
What would cause a nasty metal nashing sound when machine goes from medium spin to high speed spin during spin cycle?
Hi dear,
As I know it happens to other Asko washer models as well. From 800 rpm going up to 12-14 or 1600 rpm. That sounds happens due to vibration generated from motor. I do not thing you can do much about it unless changing motor,which is costly remedy. Thanks.
Jan 09, 2016 | Asko Washing Machines
Machine making loud noises w6863 front loader
could be that the wights are coming loose on the drum turn the drum by hand and see if you can feel any movement in the drum if yes get them looked at also try some oil on parts
Oct 12, 2014 | Washing Machines
How do you replace the pump cover with attached needle trap? On ASKO front loader washing machine W6231?
it usually unscrews anticlockwise, but check to make sure there isnt a retaining screw that needs removing first. they can be a bit on the tight side
May 02, 2014 | Asko W6021 Front Load Washer
Asko w6444 front loader drum vibrating quite loudly. Feet are level. Any suggestions.
Check the 3 transit bolts on the backside of the machine. Should be removed. Could also be a problem with the balancing spring on the top of the drum, so the drum tilts a bit forward, and cause noise
Aug 11, 2013 | Asko W6761 Front Load Washer
Asko W6564 the front seal has fallen off, i am trying to remove the front to re install seal i have undone the 2 front screws, removed the detergent draw and pulled the bottom half out but the top wil
You dont need to remove the front panel to fit the rubber seal, best to leave the front panel on, Note that the rubber seal attachs to the front panel not the washing barrel
Dec 08, 2012 | Washing Machines
My front loader won't spin - the machine makes a noise when it is supposed to spin but nothing happens
sounds like a bad pump open the sumpm on the lower left side (preapre water to gush out if still in the tub) check if there is any objects in the pump or sump if yes remove and try if not replace the pump
Sep 02, 2011 | Asko W6021 Front Load Washer
I'm trying to start the asko washer for the first time and I can't get the door to lock. the start button is blinking??
HI there, the door on my front loader was very hard to close, but the service people told me to close it really hard - slam it! and it has been fine ever since.
Jan 02, 2011 | Asko W6021 Front Load Washer
Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Mar 10, 2009 | Asko W640
Washing Machines Logo
53 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
