Question about Sanyo Televison & Video
Sound no picture on Sanyo 32 inch flat tv model number DP32648-02 how long has this been a problem for Sanyo?
  • Sanyo Master
  • 10,073 Answers
Circuits fail with time no matter who the manufacturer is. That's what warranties are for. If yours is no long in warranty you can get a replacement T-con board and replace it yourself. Get the part from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Posted on Feb 04, 2017
  • 834 Answers
SOURCE: I have a 32 inch Emerson tv..model # LC320EM8AN
t-con board is failing have a tech replace it
Posted on Sep 20, 2009
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
  • 8457 Answers
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like, to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 23, 2010
  • 1961 Answers
SOURCE: Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Posted on Jun 04, 2010
  • 11361 Answers
SOURCE: just purchased a 32 inch insignia flat screen
Look for 'ASPECT', 'MODE', 'VIDEO', or 'DISPLAY' on the remote button to change the aspect ratio.
One thing to remember is that if the video was made for 4:3 old TV format, when you expand it to fill 16:9 screen, people will loof short and fat.
Posted on Dec 04, 2010
White space above and below picture
Thirteen Retailers Recall 32" Coby Flat Screen Televisions ...
U.S. Consumer Product Safety CommissionDec 12, 2013 - This recall involves black Coby 32-inch flat screen televisions with model number ... AmTRAN Video Recalls to Repair 42-Inch JVC Flat Panel ...Missing: space
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the ... Just match up the sticker, and also add a space and n8lk, then search on amazon. .... LCD & LED TV Repair - No Image & BlankBlack Screen Flashlight Test ...
Coby DVD-209 Ultra Compact DVD Player Troubleshooting ...
iFixitNot Compatible With Coby DVD Player; Disc Types Compatible; Problem Message Displayed On Screen. "WRONG ... Follow the repair guide to replace the fuse inside the device. ... The same goes for the white and yellow plugs and ports.Missing: space
Top 139 Complaints and Reviews about Coby Electronics > Electronics > Televisions
Dec 21, 2015 | Coby TFDVD2284 22 LCD TV
My sanyo 32 inch flat screen TV has sound but no picture is it time to get rid of it
It depends upon your electronics ability. In 90% of cases, get rid of it as it's not worth repairing.
Mar 22, 2015 | Sanyo Televison & Video
Sanyo 2008 flat screen 42 inch no picture have sound
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 26, 2012 | Sanyo 42K40 42 inch Multi-System LCD TV
What kind of tv is sanyo ds32225?
Google that model number for lots of answers--32 inch set that is no longer made.
Apr 09, 2012 | Sanyo Televison & Video
Devant 32" LCD TV: No picture display, no sound, no standby mode.
You should call Devant's hotline now to verify the problem. Be prepare to present the model number and serial number located at the back of the TV. Devant's hotline is 3029700.
Aug 07, 2010 | Televison & Video
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Ysus board number for a sanyo 50'' plasma model dp50747
This is a Sanyo Vizon 50" plasma the model number is DP50747 .. hope this helps the website for this product is and the phone number is 1-800-877-5032
Mar 16, 2009 | Sanyo DP50747 50 in. Plasma TV
The power button lights up but no sound or picture.
Check to see if the set is under warranty or an extended warranty.
If not, ouch, but do-able.
From least to worst case, possibilities include
1. Bad panel drivers (between the Y-Sus PCB and Panel)
2. Bad Y-Sustain board or equivalent.
3. Bad power supply.
4. Control PCB.
5. Bad Panel.
Or any combination of...
I would recommend that you have a certified and factory authorized technician repair your set. Or at least diagnose it. Not always is it just replacing a board. There are adjustments that need to at least be verified by a knowledgeable technician.
Wouldn't want to get zapped. There is High Voltage back there.
You might also try entering the make and model number of your set online to search for others with like problems on the same model. Odds are that it has happened more than just once and that other techs may have a definate solution to your problem.
Just takes a little research.
Good luck.
Certified TV
Jan 11, 2009 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 TV won't turn on
Sanyo 32" TV has no Picture sound fine.Model DP32746
Dec 03, 2008 | Sanyo DP32746 32 in. LCD Television
Tv has sound but picture is black
good day.
The crt circuit of the unit might be loose or the the parts inside the board is loose. Have it hecked by a technician first. Minor parts inside might caused the problem.
Response is highly appreciated.
Mar 28, 2008 | Televison & Video
Televison & Video Logo
54 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
