Question about GE Washing Machines
Where is the pump filter on a ge front load washer wsxh208f1ww?
    Top Expert:
  • GE Master
  • 77,939 Answers
A light came on to clean the washer. Is there something special I need to do?
Even a blonde can do it! Quick fix/repair for Kenmore He2 ...
? 4:57
Sep 1, 2013 - Uploaded by And Justice For All
Quick fix/repair for Kenmore He2 front loading washing machine... a Kenmore He2 front loading washing machine when blinkinglights error code occurs ... How to Clean Front Load WasherDrain Filter and Empty the Water ...
Front Load Washer Pump Clean Out - YouTube
? 3:03
Sep 6, 2012 - Uploaded by GE Appliances
If you have a front load washer with a pump filter, your pump filter may become ... pressed start again but it still stops and the cleanpump light still comes back on. .... Samsung Washing Machine cleaning the pump & coin trap
Nov 29, 2015 | Kenmore Washing Machines
Ge adora front load washer not draining
I had the same problem with mine. would figure you have it fixed by now, but it is your pump. I had a childs sock get PAST the lint filter and jam my pump. but it does not take long for the pump to go bad once something has gotten into it. Somewhat of an easy fix, if your a do-it-yourselfer
Jul 18, 2010 | GE WSXH208A Front Load Washer
Howdo you get to drain pump filter on Ge wbvh5200
you'd better ask for after sales service people to help you.It's difficulat and not safe to get to the electrical component.
Mar 14, 2010 | General Electric WBVH5200J Front Load...
GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Feb 07, 2010 | GE WBVH6240F Front Load Washer
GE Aurora Front Load Washer leaves the clothes soaking wet
there is a filter under the washer door behind the panel...its white just unscrew it and clean out the filter and that should solve your problem.
Sep 18, 2009 | GE Washing Machines
GE washer not draining
You should have one. Get down low, and look at the kickplate. You should see screws just below the main front panel of the machine.
best regards, --W/D--
Jul 25, 2009 | GE Washing Machines
Locating the filter
based on info provided your ge would be a frigidaire made machine, only filter is at drain pump. to access remove lower front access panel (screws on bottom) pump sits in middle of machine, locate large rubber hose connecting to tub, loosen clamp and pull off. inside is plastic strainer cup, empty and replace. make sure nothing went past to pump, reassemble.
Jul 19, 2009 | GE WSXH208A Front Load Washer
WCVH6260HWW GE front load washer won't start - press the On button, then press Start/Pasue button and it goes beep beep, and keeps blinking, and washer does not start; the washer pump strainer has been...
no power to control panel checked outlet with another appliance it worked drained water from pump filter still nothing door locked and nothing on control panel
Feb 23, 2009 | GE WSXH208A Front Load Washer
I see this is an old post, but if someelse has this problem I hope this helps. I had this same problem.
My GE front load washer (GBVH6260) has a filter located behind the front cover below the door. My manual makes no mention of this filter no is it obvious. Remove the three screws located at the bottom of the cover below the washer door, and remove the cover. You will see a what looks like a knob. This is the filter. Be sure to place a pan under it as best you can. If your washer is holding water be prepared you could get over a gallon, have some towels ready. Unscrew the filter and slide it out, it slides in the same way.
Apr 12, 2008 | GE WBVH6240F Front Load Washer
Washing Machines Logo
41 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
