Question about Panasonic Microwave Ovens
Panasonic microwave is locked,tried the press 3 times but still won't open
4 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: my microwave says lock on the display
Press function then 5 or function button 5 times
1 for lock on
2 lock off
Eric
Posted on Jun 19, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic microwave does not work for more than 3 secs.
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on them.
You can find many Panasonic owner's manuals for free download here.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If you're not in the US, see Panasonic.net.
Posted on Dec 06, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave oven will not start after I put in the time. It says open and close door and press start. Still won't start
Probably a bad door switch or mount. The door switch help file is here.
On some models though (you didn't mention yours) the door circuit is very complicated, and may be showing the door error due to a blown fuse or cavity TCO.
Accessing the cavity TCO for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
The drawing below shows what to check:
You can find handy exploded views and order parts by model number
here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Dec 20, 2011
How do you unlock the panosonic microwave
hi Barbara.
this is what i could find out.
. Press the "Stop" button three (3) times.
or read up more at this link.
You are now ready to use your new Panasonic Microwave Oven. When you first turn on your microwave oven and under normal operation the "CHILD LOCK" feature is off. If "LOCK" or "CHILD" appears on your display . . . Press the "Stop" button three (3) times and the "CHILD LOCK" will be turned off.
set-up guide - Panasonic
ftp://ftp.panasonic.com/microwaveoven/om/set-up_guide_en_om.pdf
How do you unlock the panosonic microwave Google Search
Dec 02, 2017 | Microwave Ovens
How do I unlock the child lock on my Panasonic Genius Microwave?
March 2009 press the function key,select option #5, select option#2. This should take it out of child lock. If this doesn't work enclose your model number and I will try to look up the manual
Or, press "Cancel" three times to clear the (child) lock.
You set the lock by pressing "Start" three times.
Apr 01, 2010 | Panasonic NN-T888S Convection/Microwave...
There is a child lock on our Panasonic Inverter 1200w microwave, but don't know how to unlock it. Can you help me?
In my "Panasonic Junior Smart" microwave it's 3 times START to lock and 3 times CANCEL to unlock. Try if that works for your model.
Nov 03, 2009 | Microwave Ovens
Its locked
mine just did this too, its the inverter type. I finally found the instructions. It goes in lock when start is pressed 3 times. It can be unlocked by pressing the stop/reset button 3 times, the clock should come back up in the display window. Good luck
Jul 07, 2009 | Panasonic NN-T888S Convection/Microwave...
My microwave says lock on the display
1 for lock on
2 lock off
Eric
Jun 19, 2009 | Panasonic NN-P794SF Microwave Oven
Child sign in window of microwave ,cant start it panasonic
On my NN-L738BA there is a Child Lock feature.
You set the child lock by pressing the Start button 3 times.
If the Child Lock is enabled it displays the word :CHILD".
To disable this feature on my microwave the manual says to
press the Stop/Reset 3 times.
Check your manual for the Child Lock.
Mar 06, 2009 | Panasonic NN-S541 Microwave Oven
My microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
Nov 08, 2008 | Panasonic NN-T990SA Microwave Oven
PANASONIC MICROWAVE NN-K657
To UNLOCK it, press Stop/Clear 3 times.
To LOCK it, press Start 3 times.
You can download your owner's manual here:
http://techdocs.panasonic.co.uk/GetDoc.aspx?did=125787&fmt=pdf&lang=en&src=3
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 24, 2008 | Microwave Ovens
Microwave NN V622m locked
To lock, press START 3 times. To unlock, press STOP/RESET 3 times. If this doesn't work, contact Panasonic Support at http://www.panasonic.com/support/
Mar 26, 2007 | Panasonic NN-V671S Convection Microwave...
Panasonic Microwave Dimension 4 convection (11 yrs old)
You need to press clock 3 times, then start 3 times and then clear/reset 3 times. Then you can reset the clock by pressing clock 1 change the time and press clock again.
Mar 11, 2007 | Panasonic NN-T888S Convection/Microwave...
Microwave Ovens Logo
47 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
