Question about Jenn-Air Ovens
I have a Jenn-Air JMW8530 wall oven which is misbehaving as follows. After using the oven, the cooling fan continues to run for a few minutes. This is normal. The cooling fan shuts off, then after 10 min or so it comes back on with a single beep. 30 seconds after that there is a triple beep, 30 seconds later it displays F7 and starts continuous beeping. Some 10-15 minutes later the fan shuts off and at that time the beeping and F7 display can be terminated by pressing the "cancel" pad.I have swapped the control/clock board with one that has a failed display illumination and the behavior does not change so I suspect a component other than the control board. The behavior has been triggered once or twice by power fluctuation and can happen during oven operation for long periods at high temperatures.
  • 7 more comments
  • honeyman57 Jul 20, 2009
    This (stuck key) is what I first suspected. However, the fact that the
    cooling fan comes on before the F7 is displayed, and that the F7 can be
    cleared with a "cancel" after the fan shuts off, makes me want to find
    a more specific explanation involving the fan before I replace the keypad.
    Stuck key is what I first suspected. However, the fact that the cooling fan comes on before the F7 is displayed, and that the F7 can be cleared with a "cancel" after the fan shuts off, makes me want to find a more specific explanation involving the fan before I just replace the keypad.
  • honeyman57 Jul 21, 2009
    I had no intention of "voting you down", I'm new on this service and don't know about the voting. Sorry for that mistake. This is not a convection model, and the fan in question is the cooling fan and there is no button/key that controls it. I can, and have, pulled the ribbon connector for long periods, and yes the problem does not reappear upon reconnecting. However the problem also goes away just by waiting until the cooling fan stops. If someone is around that simply can not tolerate the beeping, I pull the power to the control board. The fan will continue to run for some minutes. When it stops, I reapply power to the control board. The fan usually cycles on then immediately off. F7 is displayed, but can be cleared via the "cancel" button/pad. If I finally replace the entire control panel and the problem goes away I will certainly mark your solution as "accepted." You are correct about me not wanting to spend a couple of hundred bucks to find out that the problem is in the oven sensor circuits/logic. I was hoping someone would know that there are other conditions that might be interpreted by the logic as a stuck key or could explain the cooling fan's involvement. If there is a way I can "un-vote you down" please let me know.
    I have the Service Manual and understand that F7 means a stuck key. I have two clock/control boards that yield the same behavior so I'm not considering the control board as the culprit, but I also know enough not to rule out anything permanently. If someone can explain how an actual stuck key could involve the cooling fan in this behavior, I might feel better about spending a couple of hundred bucks on a new control panel.
  • honeyman57 Jul 23, 2009
    Having received no additional comments in 3 days from the two initial responders, I'm attempting to expose my problem to additional viewers.
  • honeyman57 Jul 24, 2009
    OK, assuming probe is failing (resistance going high) or probe circuit is opening causing cooling fan to run, why would that cause an F7 to display?
  • honeyman57 Sep 09, 2009
    I have the service manual so there's no need to repeat what it says about the F7 error code. In addition to the behavior described in the original post, the cooling fan will come on for no apparent reason after several days of normal behavior. I'm looking for an explanation of the interaction between the fan and the detection of a "stuck key". And why does it go away after the fan runs for about 12 minutes.
  • honeyman57 Sep 10, 2009
    See September 9 comment...
  • honeyman57 Sep 21, 2009
    Regarding "Sometimes there is no why..."(Sep 10th). There is always a "why", we just may not have enough data or knowledge of the system to determine it.
    Regarding Sep. 13 - I don't think failure to heat or problem with the heating element was ever mentioned. The oven works perfectly until (and if)control is disabled by the error code and running cooling fan.
    Guess there isn't any solution available here...
    Guru:
  • 830 Answers
The sensor is out on the oven. This happened to my oven (different brand) but after replacing the sensor, all error messages stopped.
http://www.repairclinic.com/0078.asp#JennAir
Posted on Sep 21, 2009
  • 11,896 Answers
I believe the control panel board itself may be faulty.
You can get manual and parts at repairclinic.com
You can watch howstuffworks and youtube videos on how to test and replace this device and the manual is also extremely helpful. Any questions, feel free to ask.
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button
F7 Shorted key sensed for 32 seconds 1. Membrane shorted, or,
2.
Display board defective
Posted on Sep 10, 2009
  • Nate Stansfield
    Nate Stansfield Sep 13, 2009
    Most times it is easy to see a failed oven element. Their will be a
    hole or a welded mark somewhere on the element where a piece of cheese
    fell on it and caused a hotspot. You can also check elements with a
    meter or simply apply some wall current to them using a cheater cord to
    see if it gets warm. If the element gets warm that means it will work
    and is not bad. If the element ain't coming on but you have checked it
    out, of course then that would be the thermostat.
    HEADS UP: When fooling with the stove always be sure the power is off.
    Pull out the bottom drawer and most of the time you can unplug the
    power cord without moving the stove.
    To make it easier to work on most stoves the oven door can be removed.
    I set the door at the broil position and gently ease up on the door,
    remove it, and set it to the side. As far as the oven thermostat goes,
    they are simple enough to replace but quite expensive. I suggest if you
    have an electronic oven control then that old extended warranty plan is
    a winner.
    Heads Up: One thing you want to remember about fancy electronic
    controls, never put the stove on self clean! The temperature will cause
    the delicate electronics to fail. I don't care what anyone says. That
    stove will get to 900 degrees and adversely affect those controls.
    I would check is the main power source. I have been called to a home
    with a similar problem and it turns out that one of the fuses for the
    240volt oven was blown half of the oven worked but not the other. I am
    not sure if you have fuses or breakers but if you do have fuses pull
    the fuse holder out of the box and check for continuity on both fuses
    from one end of the fuse to the other if it does not have continuity
    then the fuse is bad. If you have breakers carefully remove the panel
    cover and check to see that you have 240 volts between the two wires
    for the oven. Of course you would have to have an electrical meter to
    attempt this.
    President:
  • 1,129 Answers
Temp. sensor is malfunctioning it may need to be taken away from the wall to replace the temp. sensor probe.
Posted on Jul 23, 2009
    President:
  • 1,865 Answers
The F7 error represents that a function key is shorted on the touch pad control. Replace the touch pad
Posted on Sep 09, 2009
    President:
  • 1,167 Answers
Hi buddy on my oven this is natural after about 20 mins it turns off the fan will run because it is circulating the hot air inside u ntil it cools down but will stay running if you turn it on and off quickly this is natural buddy
Posted on Sep 08, 2009
  • 15,935 Answers
F7 is touchpad sticking Error Code.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control. (also called clock or ERC assembly)
If code does not recur, problem is with the Key Panel
Sometimes pulling the ribbon and cleaning the contacts with a pink eraser will get rid of this error without replacing a part.
Give it a try!!
Posted on Jul 24, 2009
    Genius:
  • 1,043 Answers
This is a direct quote from the Jenn-Air repair manual:
Per their instructions you are looking at replacing the touch pad or ERC if you cannot un-stick the key. Hopefully this will help.
Posted on Jul 20, 2009
    President:
  • 744 Answers
Hello the error code f7 is related to the touch pad. basically there is a button in the touch pad that has shorted. To confirm this when in f7 error switch power off remove the touchpad ribbon/wiring harness from the EOC (Electronic oven control) switch power back on and leave for 24 hours. you should see that the f7 does not come back this will confirm the touchpad is bad. Once you have confirmed it is the touchpad replace it and you should be all set. Good Luck!! please feel free to comment again should you have any further questions or concerns. Mike
  • Mike Price
    Mike Price Jul 20, 2009
    Hello I'm sorry you voted me down before giving me a chance to respond. I stick by my diagnosis from before, The fan may be running because the convect if you have it is the button shorting (a button is shorting on touch pad). If like I said you pull the ribbon from the eoc and leave for 24 hours or even 12 if the f7 does not come back replace the touchpad. I know you are looking to get this nailed before you spend money on parts but I have been doing this for 20 years and have come across this kind of problem quite a few times. If i were at your house now i'd test it as stated before and replace it. Touchpad IS going to resolve this problem. Thanks Mike...If you have any other questions please feel free and give me a chance to respond :)
  • Mike Price
    Mike Price Sep 10, 2009
    Have you even tried changing the touch pad? some times there is no explanation for quirky things happening. I have been in the business for 25 years now and had I walked into your place with your oven showing f7 i would have replaced the touch-pad and you would be up and running...Some times there is no why...The con-census is the same from the experts and the not so expert. A piece of advice would be not to worry about the why..replace the touch-pad or pay for a professional to do it. Good Luck! Mike
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Jenn Air W30400 wall oven does not heat.
Turn off the power to the oven.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Jul 16, 2010 | Jenn-Air Ovens
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
The electronic controls click out with in just a few minutes after starting the oven. The light does not go on and nothing works. This problem started within one week of install and use and have had the...
Unfortunately this seems to be a problem with several of the jenn air models. I have replaced quite a few and have also talked to thier tech line for servicers and they don't have anything else to offer other than replacing the control board. Each time I ran across one I found no other problems and I tested everything. If you replace 3 times you can usually get them to give you a new one.
www.appliancehelponline.com
Mar 18, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Error message on JJW9530DDS Jenn-air wall oven is 4d21
no/low cooling fan rotation (No RPM) single cavity or upper oven - check connection at cooling fan if ok, replace blower - DO NOT REPLACE CONTROL
Mar 06, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Oven jjw9527aab fan runs continuously even when cool and now shows F2 alarm message
The F2 error code is due to the temp sensor is registering a tempature over 600 degrees. So the reason why the convection fan is continously running is because the ERC thinks the oven is overheated and is trying to cool it down. It is probably a bad tempature sensor or oven relay board. You will need to test the tempature sensor with an OHM meter. They usually will read 1000-1100 OHMS at room tempature. If you get an open read or a incorrect OHM reading then I would replace the tempature sensor otherwise replace the power relay board if the temp sensor is reading correct. But try unplugging the power to the oven for over 10 minutes first and then plug it back in. This will reset the ERC and might fix the problem.
Jan 18, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Jmw8527AAb Jenn Air Electric Wall Oven
Has anyone done any repairs to the oven lately? It sounds like it's working in reverse. The fan is supposed to come on about 10 minutes after the oven is turned on. The reason I ask this question is if someone did work on it they could have wired the fan relay wrong. If not you have a problem with the oven fan relay. They occasionally short and it wll cause them to run the opposite way they are supposed to.
Dec 21, 2007 | Jenn-Air JMW8527C Electric Double Oven
Jenn air single wall oven model jjw8530BAB - exhaust fan not working properly
in not sure but i think that fan runs off a thrmistor that goes to the contol board.open the oven door and look on the right side of the oven see if theres a metal looking bulb.
Aug 19, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
245 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
