Question about Pool & Spa
Can I buy direct from pool manufacturer Verona
16x54 above ground pool
  • 14,584 Answers
    Top Expert:
  • 4,740 Answers
I think the only way you can find out is give them a ring.if not put the details of your model into google and see if it finds anything.
Posted on Dec 01, 2016
How do I find manufacturer of rail cap for above ground pool
Remove one of the other existing caps and take to pool store, they are very easy to recognize who made the pool.
May 27, 2013 | Pool & Spa
Pool rover goes only one direction
they usually do unles its et the other way.. if its working leave it alone..
Jul 29, 2012 | Aquabot Pool Rover Above Ground Robotic...
Where can you buy rubber gasket under the function selector for an above ground sand filter unit.
Spider gasket? At your professional Pool Supply place ...
You are aware you should turn this handle only in a clock-wise direction, right?
Jul 18, 2011 | Hayward SAND FILTER, PRO SERIES
Rapak above ground pool heater is leaking from the bottom
leak is prolly from pressure switch connection or heat exchanger...... if from heat exchanger buy a new heater
Aug 20, 2010 | Raypak Versa 130,000 Btu Above Ground...
My intex saltwater system does not fit on my summer escapes filter pump. My pool size is 16' x 42" and the pump sits on the ground. On end of the filter is high and the other is low (returm flow).
unfortunately every thing you mentioned is not reaaly important.
Bottom line is that Intex has there own size hoses and prevents easy installation with other manufacturers.
You will need to make a trip to home depot and buy a basket full of fittings and keep trying till one works
Jun 15, 2010 | Intex Automatic Salt Water System for ...
Need replacement motor. Two years old motor shot
The only place that you can buy a replacement motor for these automatic pool cleaners is directly from Dolphin.
May 31, 2010 | Smartpool Dolphin Robo - Kleen Above...
After receiving the smart heater above ground pool sunheater I found out that it needs 6 hours of sun. The pool is covered by trees therefore no sun. Should I return the heater or will it add at least a...
The panel must have direct sunlight for it to heat. At 6 hours of direct light the 2'x20' panel should "collect" around 40,000 BTUs of sun heat energy. If water is circulated through the collector when sunlight is not warming it, the collector will act like a radiator and you will actually cool the water, so if you run your filter at night be sure to divert the water directly to the return and by passing the collector. So, if the entire area where the collector will be is always in the shade, it will not add a few degrees but actually cool the pool instead.
Jul 08, 2009 | Smartpool Sunheater - Above Ground Pool -...
Sand in backwash
You need to replace the seal in the head unit of the filter.. The sand should be replaced every three years or buy a cleaning solution.
Jun 17, 2009 | Hayward Pro Series 18" Above Ground Pool...
Lopsided 18x4 intex round easy set pool
I started out with easy set pools a few years ago and finally gave up and went to their steel supported ones.
I have put up over 20 above ground Intex pools and have learned a few things in the process:
A: The larger the pool with the air ring at the top the more difficult it is to fill to its maximum potential.
B: Eventually the pool is going to collapse with people in it, especially if someone leans over the edge with their arms on it which is a perfectly natural thing to do.
C: It is virtually impossible to get an area beneath the pool level without scraping the ground and measuring it with, in your case, at least a 16' long 2"x4" on its edge with a level on it.
D: Trying to build up the ground on one side with sand will eventually result in collapse of the pool.
E: There is a type of stiff styrofoam ring that you can buy in sections to go around the bottom of the pools, but that will also result in collapse unless it is used for what it was developed, and that is a rigid wall pool.
F: Out of the three types of pools that Intex sell, the easy up with the air ring (the worst), the steel supported all the way around (next worse). and the rigid side, only the rigid side is forgiving to a tiny degree where unlevel ground is concerned.
For your size of pool everything must be exact and completely level or at one point it will collapse. There is little more discouraging than seeing all those gallons of water run out onto the grass. Once the water goes over the edge, no amount of people can prevent the collapse.
Finally I have learned that, with above ground pools, you get exactly what you pay for. My 5th above ground Intex pool was the best, but even with the ring around the edge at the bottom and the rigid side, I was still wasting my money unless the ground was aboslutely level. You just have to cut away the dirt until the level shows no angle.
I wish you all the luck. If you feel a desire, I have 5 Intex pools in my barn I will give to you if you pay the freight. Each was a dissapointment and a waste of time, energy, and above all, money.
I finally spent about $750 on one, had a professional crew level the ground, and it stays up through the winters even.
May 25, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Pool & Spa Logo
169 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
