Question about LG Washing Machines
Lg fault code 05 - LG Washing Machines
    Top Expert:
  • LG Master
  • 77,202 Answers
What does the code on the screen mean flashes between ch and 05 ?
CH 5 on these units indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assembly to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts. 800 243-0000
Oct 15, 2016 | LG Art Cool LA181CNW Split System Air...
Error F 05 what is it indicating?
www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html whirlpool
Jun 26, 2015 | Washing Machines
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
150-05 fault code
Speed Shift sensor "door" open???
Or speed shift sensor circuit open???
Keep us udated and send us additional details about yea, brand and model and engine sizes.
Feb 09, 2012 | Cars & Trucks
Hotpoint aquarius fault code f 05
  • F05 - Pressure switch jammed on full
  • Thing to do check pump is not blocked and clear it then reset machine by unplugging for 5 mins and plug back in if still gets error F 05 then you need a repair call out. hope this helps.
Jan 08, 2012 | Hotpoint Washing Machines
Error code ch 05
Feb 03, 2011 | LG Art Cool LA181CNW Split System Air...
LG air condotioner with a CH5 error code
CH-05-Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Jul 27, 2010 | LG L1004R Air Conditioner
Fault code f-05
make and model of the washer, codes are not generic
Oct 04, 2009 | Washing Machines
Fault code or engineers reset for beko washing machine wma 756s serial no 05-100 905-06
please can you send me fault code for beko wma 665 w serial no 05-103296-10 thankyou
Dec 21, 2007 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
