Question about Electrolux Washing Machines
Electrolux dish washer will only drain has code ' 30
Slash 30 '30
  • 4 more comments
  • Cindy Insco
    Cindy Insco Dec 01, 2016
    I hear it running but won't shut off till I flip the breaker
  • yadayada
    yadayada Dec 01, 2016
    THIS SHOWS '30 IN THE DISPLAY? OR JUST 30?
  • Cindy Insco
    Slash on it then 30
  • Cindy Insco
    '30
  • Cindy Insco
    Can u tell me what this means????
  • Cindy Insco
    Cindy Insco Dec 02, 2016
    We fixed it there was a particle in the drain! Thank you
4 Suggested Answers
SOURCE: Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Posted on Sep 06, 2009
VOTIT
  • 2071 Answers
SOURCE: my dish washer dose not start, it keeps yieling "
Hi enasammar, First thing to do is to reset. Merely unplugging the power cord from the wall socket for 4 hours, then power up again.The purposed of unplugging is to dissipitate the stored current in the memory IC thats control the unit to hang up, so it will gone. Take out all inside the unit and clean,then turn on . If still not working give me the model number so i can find the schematic diagram for that unit. Hope it may helps.
Regards: VOTIT
Posted on Dec 03, 2010
tonosantacru
  • 248 Answers
SOURCE: Electrolux dish washer not draining
Is it new? Or new garbage disposal installed? Make sure the drain pipe is punched out under the sink
Posted on Feb 11, 2017
Feb 11, 2017 | Electrolux Washing Machines
E24 error
Hello Dana, this is Z. I am happy to assist you!
If you are getting an error code E24 on your Electrolux washer, it usually means one of three things: your drain pump relay has failed, a wire may be disconnected from the pump, or your main control board needs replacing. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards.
Mar 18, 2014 | Electrolux Washing Machines
Electrolux dishwasher control panic locked - how do I unlock? Have tried pressing LOC button for 3-5 seconds and have turned circuit breaker on and off.
Pull out the dish washer and unplug the machine for about 30 minutes. Then replugin the machine and open door. This should reset the electronics on the washer
Oct 17, 2013 | Whirlpool 24 in. ADP5966 Free-standing...
Electrolux EIDW6305GS1 will not run , keeps flashing error code 11 which indicates drain valve problem. I have replaced drain valve, wash pump, float valve and reed switch but no luck, still flashin
Hello Gene Skates - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. This is typically not a DIY job and strongly recommend contacting a professional to check the wiring between the main control board and drain valve since you have already replaced the drain valve.
Jan 11, 2013 | Electrolux Frigidaire Professional Series...
Electrolux dishwasher with error code 11
Hello Jason Johnson - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. I strongly recommend contacting a professional to check the wiring between the main control board and drain valve.
Dec 30, 2012 | Electrolux Frigidaire Professional Series...
Error code 11 on electrolux wave dishwasher
Hello - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. I strongly recommend contacting the technician that repaired your unit previously to check the wiring between the main control board and drain valve. Some certified technicians warranty their labor and part for 30 days.
Nov 04, 2012 | Washing Machines
Electrolux Dishwasher EDW7505HPS stopping a cycle
you could always put dishes needing washing in the washer and run cycle. The electric element will heat the water to 140 degrees and it will clean just fine.
Mar 10, 2012 | Electrolux Dishwashers
Fault code 30 has come up on my dishwasher how do i fix it
-30 is a leak in the system and is filling up the drip tray at the bottom. The float is attached to a micro switch and will halt the program and start the pump to drain the washer. You can tell by feeling in under the tray for water.
Nov 04, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Electrolux dishwasher shows code 10 not filling fault and code 20 not draining fault but when running you are able to hear it filling and draining. Whats the problem.?
I had the same issue (Electrolux ESF 6251). I had both error codes 10 and 30. I found that the short hose connecting the inlet valve (solenoid) to the tank was cracked. That explained error code 30, but even after replacing the hose I still got error code 10. I checked water supply and also drain hose and filters. I realized that I had recently tried to flush out lime scale and suspect that the drain or pump had lines could have clogged up. I tried pumping into the floor drain inside the dishwasher (removed the filter cartridge and screen) simply with a suction cup like you use in the kitchen sink. Voila. Now it works again...
Sep 17, 2009 | Electrolux Dishwashers
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Washing Machines Logo
851 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
