Blaupunkt tv led keeps flashing tv will not turn on
    Top Expert:
  • Televison & ... Master
  • 45,139 Answers
Could be an open internal fuse or power supply failure
Posted on Dec 01, 2016
    Top Expert:
  • 80,656 Answers
Shorted main board most likely.
Blaupunkt TV is completely black with no image but flashes red and blue
I do not know this TV but my reaction would be to unplug any external monitors so its working just its own, then turn it off (by the mains) wait five minutes then turn on and see if anything has changed.
If not then see if you can get the menu up, if you can find its system reset/ restore to bring it back to when it was new, this will mean you will have to reset things but it might clear any other issues.
Should that fail then I suspect its graphic IC has failed which will be a new TV because modern sets are not worth repairing beyond about 3 years less so for the real cheap types, due to technology moving on which results in older models losing value very quickly.
Hope this helps..........
Jan 18, 2018 | Blaupunkt Televison & Video
My blaupunkt smart tv I switched it on sound but no picture red light flashing
Power board or more likely LED lamp failure, try the flashlight test
May 26, 2017 | Blaupunkt Televison & Video
My blaupunkt tv said no signal then when i turned it off it stayed off? What can I do
my tv says no signal - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../my-tv-says-no-signal/td.../13296...
Jun 28, 2012 - My tv says no signal. ... Start here. Sign in or Sign up ... Plug in the TVfirst, then the cable box, turn on the TV, then turn on the cable box.
Computer turns on, monitor says "no signal" [Solved] - CCM
ccm.net > Forum > Windows
Mar 10, 2013 - I recently had problems of it randomly turning off at any time, i could be working ... Then i decided to take out the wireless B PCI card, then the computer booted! ... tycoonXD) and i needed to start my computer up again cause it didn'tworkwell, ... i've tried many things, turned of the powerbutton waited for 39 ...Missing: blaupunkt
Jan 05, 2016 | Blaupunkt BLA32/147 32" LED TV 1920x1080,...
Remote control code required for virgin TiVo & 50 inch blaupunkt TV combo
I have just managed to do this. I cannot tell you the code as I had to do it manually, but this is how I did it.
point the remote away from the TiVo and hold down the clear button and the to button until the free light flashed twice.
type in the code 0999 and the light will flash again. Then point the remote at the to and press and hold the channel up button. You will now scroll throw all the codes.
it will take about a minute but eventually the to will go off. When this happens release the channel up button and hold down the green on button to try turn the tv on with the TiVo remote.
if it comes on press ok and this will store the code. If it doesn't come on, use the blaupunkt to remote to turn the tv back on and then keep holding down the channel up button to scroll through more codes. When the to goes off again release the channel up button and try turn it on with the TiVo remote. If it works this time store the code by pressing ok
for me it took two attempts to turn the to on but eventually it worked on the second code
Nov 29, 2014 | Blaupunkt Car Audio & Video
Got the new shape bt vision remote control but cant find the code for my blaupunkt tv can you help
Try these codes. Hopefully one will work.
034,118,119,138,189 if no joy then refer to your TV manual and look for a code there.
Sep 12, 2014 | Televison & Video
Why when turning on blaupunkt 1080p led hd tv i only get a black screen there is start up menu
If you tap "gently" on the front screen do you see whiteish color?
If no you have a problem with the set. probable power supply issue.
If you do then press menu. If you don't see the menu on screen, probable control board issue or lvds board. Time for a tech.
Jul 29, 2014 | Blaupunkt BLA32/147 32" LED TV 1920x1080,...
The tv keeps turning itself on and off
Ur tv have a LED POWER indicator light and a LED light indicator LAMP flashing?Yes,this is a DLP Tv the lamp live is over,must be replaced it with a new lamp.No,LED light LAMP indicator flashing,than ur tv is a LCD or a Plama tv.Than ur power supply board is dead.Must replaced the power supply board to solved this problems.
May 24, 2010 | Samsung HL-P6163W 61" TV
Protect led flashing with hit of bass
Try a bigger amp. This one wants to be turned down. But seriously the protect can act like sort of a clipping device when the unit is trying to amplify out of a certain range. The transistors may be getting weak and need to be replaced. That said I would move this amp to the midrange or the highs and get a little bigger amp for you low low's. Hope that helps.
May 08, 2010 | Blaupunkt GTA 260 2 Channel Amplifier 400...
Televison & Video Logo
228 people viewed this question
Top Televison & Video Experts
