Question about Williams Heating & Cooling
Can I heat a secondvroom with a Williams wall furnace?
I have a Williams wall furnace in my living room, but the heat doesn't get around the corner very well to warm the adjacent bedroom. The bedroom wall gets quite warm from the radiator in the furnace, and there doesn't seem to be any special insulation or protection for the drywall behind the furnace. Can I safely cut a vent in the bedroom wall near the ceiling to move some warm air in there?
    Top Expert:
  • Williams Master
  • 77,932 Answers
I would use a fan to circulate the heat.
Posted on Dec 01, 2016
Thermostats aren't very expensive. You can get universal ones at home improvement stores.
Dec 06, 2016 | Williams Heating & Cooling
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download. > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
I have a 1000xl heater that has no power at start up no lights or anything
Check main breaker in panel box if good check small fuse on the control board inside furnace if good check 24v transformer in furnace
Feb 12, 2015 | Williams Wall Heaters: 35,000 Btu/hr...
How to wire a gas valve and thermosat
We need more information. Is this a 30 year old furnace or newer one? The safeties vary greatly.
Nov 22, 2014 | Williams Wall Heaters: 35,000 Btu/hr...
I have just had a Williams 33,000 wall furnace installed to replace a pre-existing furnace. However, after installation, the Bellflower inspector issued a "correction notice" which the installer...
The "drip leg" is generally placed near the appliance, but that doesn't mean that it can't be placed in a more convenient location. However it must be dedicated only to that heating appliance.
Hope this helps you and thanks for choosing FixYa.
Sep 20, 2011 | Williams (5009622) Ceramic Gas Wall...
I have a williams forsaire furnace that won't heat a room properly. The main burner will light and shut off as the thermostat tells it to but the blower won't blow any heat unless the thermostat is set...
There is probably another thermostat buried in the furnace for safety purposes which could be faulty - it is very unlikely there won't be safety devices built into the furnace and no reason to assume those devices would be any more reliable than a room thermostat for instance.
You really need a service manual for your furnace.
Sep 09, 2017 | Heating & Cooling
Williams wall furnace no longer adequately heats home
A couple thoughts. On some of the wall furnace gas valves there's a knob that you can set for low fire or high fire. If your valve has this make sure it is in the high fire setting. Is the wall furnace controlled by a wall thermostat or a knob on the heater? With the thermostat turned all the way up like to 90, does the burner and fan continue to run or is the burner short cycling. Is the fan clean and running up to speed. Some of the Williams wall furnace had a two speed fan motor so when the fan came on at first it would run on low speed. As the heat exchanger got hotter the internal fan switch would switch it to high speed. Outside of that you would need a monometer to check the manifold gas pressure.
Aug 31, 2017 | Heating & Cooling
Furnace-not heating all rooms to set temperature
Depending on where your living room is in comparison to your furnace it could be just that the fan doesn’t have enough force to get it there so what is happing is that all the other air is reaching other rooms before it. There are products that can help with this u can find them at larger hardware stores they r inline fans that go in the ductwork or there r a flat type of fan that mounts on the vent and plugs into a wall outlet that will pull the air to that room the latter would be much easier but it is your choice. Hope this helps.
Nov 08, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
43 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
