Computers & Internet Logo
J
Judy Osborn Posted on Dec 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get Blue Mountain e-cards icon on desktop?
NOEL
Level 3:
Top Expert:
  • Icon Master 8,606 Answers
  • Posted on Dec 01, 2016
NOEL
Icon Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2322222
Points
68630
Just right click on the icon . then it should give you the option either copy it or cut it pick the one you want to do,cut means it will take it from where it is.copy means just that a copy. .what ever one you do you then goto your desktop screen on there you right click again then you pick paste it will then go on your desktop.
2helpful
What do the icons mean
The tulip is for close-ups and the mountain is for more general-purpose distant objects. For more information consult the manual. Since you neglected to specify the model of your Coolpix, I can only suggest you select it from this list if you need a manual.
1helpful
Sep 20, 2012 • Cameras
I have a Dell Inspiron 531S, I have both two different monitor slot, does my PC support dual monitor systems?
Yes.
The area on the back of the computer, that has two ports to connect a monitor, is a Graphics Card.
It is a PCI-Express graphics card, and is plugged into a PCI-Express x16 slot on the motherboard.
(Expansion Slot)
It has a blue VGA port, white DVI port, and black S-Video port.
The area on the upper left with a blue outline around a VGA port, is a VGA port connected directly to the motherboard. It is Integrated Graphics.
You CANNOT use Integrated Graphics, and a graphics card at the same time.
It's either use the Integrated Graphics VGA port, OR use the graphics port/s on the graphics card.
BIOS will Not support using both Integrated Graphics, and a graphics card.
HOWEVER, you can use the VGA port, and the DVI port when using two monitors.
You will be only using just the graphics card.
Example of a VGA port, (Connector), and VGA cable,
http://en.wikipedia.org/wiki/VGA_connector
Example of a DVI port, and DVI cable,
http://en.wikipedia.org/wiki/DVI_connector
1) Whatever monitor you have that has a VGA cable, plug it into the blue VGA port on the graphics card.
(There are VGA monitors {CRT} that resemble a small TV. VGA cable is usually attached.
There are also LCD flat screens that have a VGA connector, for a VGA cable, and may also have both a VGA, and a DVI connector.
To digress for a moment;
VGA is Analog. It uses an Analog video signal.
DVI is digital. It uses a Digital video signal.
A computer naturally puts out a digital video signal. This digital signal has to be converted by the computer, into analog for an analog monitor. This slows the graphics process down. This is one reason it is best to use digital )
2) Plug a monitor with a DVI cable into the white DVI port on the graphics card.
3) Turn the monitors on.
4) Turn the Inspiron 531s on.
5) When Windows has loaded, right-click on an empty area of your desktop computer screen.
Now left-click on Properties at the bottom of the list.
Left-click on the Settings tab.
6) You are now looking at a small window that has two monitor icons in it.
Monitor 1 icon, and monitor 2 icon.
Monitor 1 icon is your Primary Display.
Monitor 2 icon will be for the Secondary Display you are adding.
Note how monitor 1 icon is sitting to the Left, and monitor icon 2 is sitting to the Right.
This is how your monitors are supposed to be arranged on your computer desk.
If the second monitor is on the Left on your computer desk, you need to move the icons around.
Move monitor 2 icon to the Left.
Left-click on the icon, hold the left mouse key down, and drag the monitor 2 icon over to the left side of monitor 1 icon. (All the way over, or it will snap back to where it was)
It may matter to you how your monitors are arranged. It may not. Once you read the following it may help you decide.
7) Left-click on monitor icon 2 if you have not already done so.
Go down to where it states, "Extend my Windows desktop onto this monitor"
8) Left-click once in the empty square, to the left of Extend my Windows desktop onto this monitor.
9) Now left-click on Apply at the bottom Right corner.
10) Finally left-click on OK at the bottom Left corner.
You should now see your desktop screen on both monitors.
When using the internet on both monitors, you have to drag the screen from the Primary monitor to the Secondary monitor.
Go to the left side of the screen. Left-click right on the edge of the blue frame. Hold the left mouse key down after you click, and drag the screen across to the left.
Doesn't work?
Go to the right side, click on the blue frame, and drag the screen to the right.
This is why it may matter how the monitors are arranged on your computer desk.
It's kind of eerie your first time dragging the screen across.
You will also find out why it is best to use two similar monitors, when using dual monitors. The pixel resolution is different for both monitors, if they are different from each other.
For additional questions please post in a Comment.
Regards,
joecoolvette
Just to add:
http://support.dell.com/support/edocs/systems/inspd531/en/OM/appendix.htm
Since installing this graphics card I've had a shadowing issue. Being a new graphics card I assumed it was a problem with my power supply. I replaced the power supply and I still have a shadow on every...
Maybe the new card supports more of XP's graphical features and the shadows might be a feature.
This border on desktop icons can be created when the desktop items have been locked, to unlock the desktop web items right click on an empty area of your desktop. Now select Arrange icons by and uncheck 'Lock web items on desktop' if it has a little tick next to it. If you did not have a tick here then Right click on your my computer icon and view its properties, now click the advanced tab and then on the settings button under performance. Now on the visual effects tab scroll down the list of effects to 'use drop shadows for icon labels on desktop' and put a tick in the box next to it, then click ok. This should remove the shadow border from your desktop icons.
Pic up side down
  • Open the picture(With Windows Picture & Fax viewer)
  • Type "CTRL+K" to turn the picture 90 degrees clockwise. Additionally, instead of using the command keys, you may select the "mountain" icon. This icon located next to the magnifying glass icon on the bottom of the picture.
  • Type "CTRL+L" to turn the picture 90 degrees counter-clockwise or select the second mountain icon. This icon located next to the red "X" icon on the bottom of the picture.
  • Repeat the steps, changing the number of degrees as needed to adjust the picture to the correct angle.
  • hope this will help you... Have a Nice Day
    Games crashing and icons on my desktop scattering
    hi this does sound like your graphics card has a conflict with another device, your best bet would be to go to the site of your graphics card manufacturer and download the latest drivers for your card, un-install ( actually delete ) the graphics card from the system, ie...add and remove programs, look for drivers for your graphics card, then remove, also go to your device manager and delete it from the hardware so there is no trace of it ( don't worry it will still work it will just default to minimal settings on re-boot) re-boot the system, if it says found new hardware and tries to install your card click no you don't want to install it, then find where you downloaded the drivers and install them and then that should stop the blue screens, games..this also could be the sound card has a conflict with something, as i know allot of games just crash to the desktop for this reason, try doing the same for the sound card, download, remove and install, as above...any more probs just reply and i will see what else there is, if you can also post the blue screen error on here to will be helpful as you can determine what the cause is...hope this helps
    2helpful
    3answers
    How can we connect two moniters to one cpu
    To have and use 2 monitors at the same time, you need a video card with a dual VGA outputs.
    To use 1 monitor at the time you can buy a VGA switcher, to switch between the 2 monitors.
    Best of Luck
    Sabre
    We have Dell OptiplexGX745 smallform factor desktop computers that we need to run two monitors.
    If your Dell Optiplex GX745 came with the ATI Radeon X1300 graphics card, that has One - DVI graphics port, and One - VGA graphics port, it's no problem.
    This link shows an ATI Radeon X1300, and the two above mentioned graphics ports,
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5550932&CatId=28
    (Please scroll down to the larger photos for more detail.
    The Radeon X1300 graphics card in your computer, is a Low Profile graphics card. It will not look exactly like the one shown.
    Low Profile means shorter in height. Your graphics card is shorter in height, in order to fit in your SFF computer case. {Small Form Factor}
    The longer white connector shown on the left side of the view, is a DVI port. (Technically it's a Dual DVI port)
    The shorter blue connector shown on the right side of the view, is the VGA port.
    1) If one of your monitors has a DVI connector plug, simply plug it into the DVI port.
    If the other monitor also has a DVI connector plug, you will need an adapter to plug it into the VGA port.
    2) If both of your monitors have a VGA connector plug, one will plug into the VGA port on the graphics card.
    The other will need an adapter to plug into the DVI port, on the graphics card.
    This link shows an adapter for connecting a monitor with a DVI connector, to the VGA port on a graphics card,
    http://www.directron.com/dviadapter.html
    The adapter to connect a monitor with a VGA connector, to a DVI port on the graphics card is opposite of this.
    [ I have found them at Radio Shack.
    This = Expensive! $14.99
    Not advertising for Radio Shack, or the above website in the link]
    NOTE*
    Use care when selecting the adapter you need.
    A monitor with a VGA cable connector has the Male pins.
    Your adapter must have the VGA Female sockets.
    The DVI side of the adapter must have the Male pins.
    It goes into the Female socket holes on the graphics card.
    Same with a monitor that has a DVI cable connector.
    The adapter must have Female DVI socket holes.
    The other side will have Male VGA pins.
    If your ATI Radeon X1300 only has One - graphics port, I Do Not advise using a splitter.
    This is an adapter cable that has a connector on one end, and splits into two cables.
    The graphics quality will be poor.
    If you have No graphics card the situation is worse. This is Onboard, or Integrated Graphics.
    (OnBoard. On the motherboard)
    Using a splitter cable will result in very poor graphics.
    How to tell if your Optiplex GX745 only has Integrated Graphics?
    Look at the back of the computer. Come down from the audio ports. (Green and Blue)
    Look under the USB ports.
    The Blue VGA port is the Integrated Graphics port.
    If you have an ATI Radeon X1300 graphics card, you will see a blue VGA port in an adjacent slot, also.
    (Your computer can have Integrated Graphics, and a graphics card.
    You CANNOT use the Integrated Graphics port, and a graphics port on a graphics card, At The Same Time!
    It will Not work)
    Once the two monitors are attached.
    1) Turn both monitors on.
    2) Turn the computer on, let Windows load
    3) After Windows has loaded, Right-click on any empty area of the desktop screen.
    4) Go to the bottom of the drop down menu, and Left-click on Properties
    5) There are tabs across the top. Left-click on the
    Settings tab.
    6) You will see two rectangular icons. These icons represent monitors.
    The one on the left side with the white border around it, is your Primary monitor. The main monitor you have always had.
    The grayed out icon on the right side represents a Secondary monitor. This is for the second monitor you plugged in.
    Note how the two monitor icons are sitting.
    Primary on the left, Secondary on the right.
    This is how your monitors should be sitting.
    If it is Not, left-click on the Secondary monitor icon. Hold the left mouse button down, and drag it over to the left.
    Now scroll down this window with your eyes.
    Under the resolution settings you will see -
    There is a square box to the left of it.
    Left-click in the square box. Go below to the right, and left-click on Apply.
    Now go to the left, and click on OK.
    Your monitors will now both be showing your desktop screen.
    [Note* When doing this procedure, you have clicked on the Secondary monitor icon. Clicking on the icon activates it]
    When you open the internet, or have a program going.
    Go to the right side of the screen to the blue border,
    of the Primary monitor.
    When the mouse cursor turns into a double-headed arrow, hold the left mouse button down, and drag the screen to the right.
    (You will note that the mouse cursor changes quite easily. It has to be double-headed in order for this to work)
    If this direction does not work, go to the left side of the screen, drag to the left.
    (You have to drag in the direction your monitors are actually sitting, in relation to each other)
    Need some clarification, or have further questions? Click on Comment.
    Top Icon Computers & Internet Experts
    Tracy
    Robbie Goodwin
    MrFixitSTTL
    Are you an Icon Computer and Internet Expert? Answer questions, earn points and help others
