Question about Crosley Audio Players & Recorders
It was a crosley record player in light blue and I paid for it ,it's on my bank account my name is Linda Taylor it is xmas gift
djnick989
  • 1067 Answers
SOURCE: crosley songwriter cd recording problem
maby the formatt its wrinting on is ther any options in menu of it to set the output formatt to mp3
Posted on Jan 22, 2008
  • 17 Answers
SOURCE: Needle slides across the record on Crosley 5 in 1 player
you have unscrewed the suspension screw?
also check the needle for dirt and dust... try blue tacking a 5p coin to the top on the needle to give it a little more weight, if the needle stays in place then the arm balance if off, and unless there is a mechanism to adjust that on this turntable then i guess its a return!
Posted on Feb 12, 2009
  • 38 Answers
SOURCE: will my autorama crosley cr712 record player work without
The record player will work with out a remote.
The CD will need a remote, for operation control.
The radio will work with out a remote
Posted on Nov 04, 2009
  • 84 Answers
SOURCE: My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Posted on Nov 25, 2009
  • 17 Answers
SOURCE: I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Posted on Jul 24, 2010
I got a bill and my records show its paid
What KIND of record(s) show that it was paid? Checking account records? Credit card records? Bank statement(s)?
May 11, 2017 | Computers & Internet
My name is Alec Immelman 5512305083080. my daughter paid 100 us dollars into my Paypal acc. how do i get this money. it is pending in my account.
connect your bank account with your paypal account and you can ask for a transfer. If you don't want that, go online, find a gift card and buy it with paypal and use the gift card
Feb 22, 2017 | PayPal Computers & Internet
How to use my gift card to pay for my purchas
Amazon.com Help: Pay with a Promotion or Gift Card
www.amazon.com/gp/help/customer/display.html?...
Amazon.com, Inc.Go to Amazon Video from your computer's web browser. Use search or browse to find the video you'd like to purchase. Click More Purchase Options underneath thepurchase options. Click Redeem a gift card or promotion code underneath thepurchase options.
use Amazon Payments - Help - Help ' Amazon Payments
https://payments.amazon.com/help/5970
Amazon PaymentsTo make a payment, you can use a credit card, debit card, bank account, ... Please note that you cannot use Amazon Gift Cards to pay for purchases ... Is it safe to letAmazon use my bank account login credentials to verify my bank account?
Amazon.com Help: Redeeming Gift Cards
Dec 26, 2015 | Free Amazon Gift Cards & More
Base is brittle plastic and is broken in 2 places. It was Xmas gift.
? under warranty? Try to find the Xmas gift paperwork/ receipts.
sometimes the dealer keeps sales records. Try to find the selling dealer. Take it back they may help if you are nice about it.
Mar 26, 2015 | Cell Phones
Crosley CR711
it sounds like the switch that indicates witch item gets power is gone,
Mar 16, 2014 | Crosley Audio Players & Recorders
I need to change my bank details
Before you tell the Child Benefit Office about the change, make sure that the account is in any one of the following names:
  • your own name
  • your partner's name
  • you and your partner's names
  • the name of a person acting on your behalf
  • both your own name and the name of a person acting on your behalf
There are some accounts that may not be suitable for your Child Benefit to be paid into, for example a Child Trust Fund Account or an ISA (Individual Savings Account).
BMW Custom Parts
Jun 06, 2012 | PayPal Accounts
Can you use a prepaid american express gift card to start an account
i think you should be able to its just like an all-purpose gift card but you can always call the company to find out.
Jun 14, 2011 | PayPal Accounts
Hi there, i have just bought a record player on ebay which looked very genuine but the needle seems to slide across every record that i have tried, would it be that the needle is blunt or is there a...
Chances are it was sold with a faulty stylus. The only other thing to try is to increase the weight at the end of the tone arm. It might have numbers on, turn it up in stages to see if that solves it
Jan 20, 2011 | Crosley CR249TA Turntable
Dec 26, 2008 | Crosley CR248 Turntable
Adjusting for PayPal fees when recording payment received
Actually, you do not want to reduce the product name. When you make the deposit from PayPal, you want it to be for the full amount the customer paid. Then add a second line with a minus amount for the fees, and the account of paypal fees (expense). This way, you split off the fees paid to paypal as an expense, and the bank reconcile matches.
Attempting to reduce the ProductName will only result in tax liability issues, as you have to charge sales tax on the full amount the customer was originally charged.
Using a negative line on the deposit to split the paypal fees off is a much cleaner process, and causes no confussion for the accountants.
Oct 31, 2008 | Intuit QuickBooks Pro 2007 Full Version...
126 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
