Question about Electrolux Washing Machines
My Electrolux EWF1481 front loader is displaying "machine is locked, use key combination to unlock it." I can't find this in the user manual. What to do? Thanks for your help.
SOURCE: unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
Posted on Apr 12, 2008
aborcass
  • 2651 Answers
SOURCE: need a manual
here you go
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208182271.pdf
Posted on Apr 29, 2008
FitzOriginal
  • 842 Answers
SOURCE: The door will not open on my Electrolux washing machine
How much trouble do you want to go to?
If you just want to preserve the washing, then simply put it on another cycle tonight and that will keep it fresh until the callout turns up to fix it.
The next clever step is to power the machine off at the mains for 10 minutes. Depriving it of power MAY release the interlock door switch even if the cycle didnt.
Final attempt to get to it... Turn off power, unplug at the mains. drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
If you trust yourself NEVER to open the door in the middle of a cycle, the machine will of course function without a switch. Just so long as you recognise that you will flood the place if you do open it with water in. Also if you put your hand inside dirung a wash (Or worse still a spin) the power of the motor combined with the weight of the wet washing will rip the arm clean off a fully grown man, so if you doubt yourself or you have kids (or kids may visit) don't leave it like this.
Posted on Feb 09, 2009
  • 4 Answers
SOURCE: unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
Posted on Aug 19, 2009
SOURCE: i want a manual for an electrolux ewf1074 front
http://www.electrolux.com.my/Files/Malaysia_Singapore/Manuals/FabricCare/EWF1074.pdf
Posted on Jan 10, 2010
Hi,I have lost the user manual for my samsung front loader washing machine IPX4 model www60j426hs and the lock sign stays on. It is stuck and cant change programme. What can I do?
seems as if the washer is in child lock mode pressing and holding a key related to the child lock for four seconds will unlock the washer and allow you to use the washer again
Feb 26, 2017 | Samsung Washing Machines
Hi i have Electrolux washing machine model EWF14811 the display is not working what can i do ?
I've never seen a model EWF14811 so I believe that it is a EWF1481 model washing machines.
Unfortunately, you have to replace the entire electronics because the LCD display is part of the PCB.
Also, before replacing I suggest you to check contacts on the LCD display which can be weakened by moisture,... etc.
Dado
Feb 19, 2015 | Electrolux Washing Machines
I own a 1Q-Touch Front-Load Electrolux washing machine. The door won't open. What can I do?
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Jan 15, 2013 | Electrolux EIED55HIW Electric Front Load...
I know this will be a simple question to answer ans cannot for the lifeof me fine my manual but the the not the proper lock , as in the door lock flash but the other lock sign is on and I cant seem to...
there is a child lock on that on,, it might be one button or two just hold it or them in until it unlocks,,, i cant remember which ones they are but they will be marked sometimes with alittle picture of a baby
Jan 20, 2011 | Electrolux EW1000i Front Load Washer
Electrolux ewf1481 door seal twisted
This sounds as if one of the top spring hangers has come out of its location point.If you turn off the power and remove the top lid,then look into the machine you may still see one spring connected and the other one may have fallen into the base of the machine which you will have to retrieve and refix,by lifting up the drum and resitting it in the hole at the top.Check also that the rear counterbalance block if fitted and the front one have not come loose and the bottom struts are ok.This fault can occur after an uneven load has been in the machine.Some of the Models have a keep plate fitted to stop the springs from un - seating.
You can then inspect the door seal for any damage.
Hope this helps.
Jun 12, 2010 | Washing Machines
How do I unlock the door. I pressed pause however it didn't unlock and then I pressed all sorts of buttons. Now the green little button above the key simbol is on. Can't find use manual. It is the...
try un pluging it for a couple minutes then after plugging back in ht stop cancel see if that works.if you know the model # you can download the guide from electrolux website
Feb 17, 2010 | Electrolux Washing Machines
My front load washer has the door lock stuck and the door is open
When this happened to our front loader washing machine, we had to unplug the appliance, wait, then replug it to reset and unlock the door.
Feb 10, 2010 | Electrolux EW1000i Front Load Washer
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot...
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Mar 30, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
