Question about Hardware & Accessories
How do I program my sp045 timer to go on and off every day at certain times
How do I get the programs to repeat daily?
This should be explained in the instructions. Some timers allow you to select certain programs for certain days of the week.
Nov 23, 2015 | Hardware & Accessories
Cannot set for a second watering time for certain areas of lawn. Have a Orbit 6 Station. Certain areas of lawn have been replaced and require additional watering.
Set up a B Program for the zones that need extra watering.
Say you want zone 2 and zone 3 to run 20 minutes every day in addition to your normal watering.
Set B Program, put Z2 and Z3 time of 20 minutes in, set a start time that is away from your normal watering time, say 6:00 pm. Set every day watering.
Your normal program will water and Z2 and 3 will water every day, too.
Gary
Jun 29, 2011 | Hardware & Accessories
Do not know how to set timer DT300 for Lights
Hi
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Thanks.
Dec 27, 2010 | Audio Players & Recorders
I have a HB88RC Intermatic 7 day / 7 event timer. I have followed the "easy set instructions" I have program 1 set to turn on X-mas lights at 4:30 PM and go off at 11:30 PM. For all seven...
Just program it as noted previously and put the timer in Auto. Set the clock to 1 min BEFORE your earliest timer program is set to come on. When the clock hits the correct time, it will turn on. Then set the clock to the correct time and you're golden.
Dec 03, 2010 | Intermatic HB88RC - 7-Day Programmable...
I caNT SEEM TO PROGRAM OR CHANGE THE TIME . HOW DO I DO IT
Page showing Woods timers and models:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment with specific model number and I will help.
Instructions below are for Woods 59203 24-hour digital timer:
Plug timer in until battery is recharged.
If display will not show, then timer battery is dead and needs to be recharged, or timer may be broken.
Set current time:
Press and hold CLOCK button.
Press HOUR and MINUTE to set correct time with am and pm.
Press Day button to set current day.
Release clock button.
Program timer:
Press PROGRAM button until "1 ON" displays. This is program1 ON.
Press MINUTE and HOUR buttons to set ON time for program1
Press DAY button to choose day or group of days for program1 ON
Press PROGRAM button until "1 OFF" displays. This is program1 OFF
Press MINUTE and HOUR buttons to set OFF time for program1
Press DAY button to choose day or group of days for program1 OFF
Press PROGRAM button until "2 ON" displays. This is program2 ON.
Repeat steps above to set ON and OFF time for 5 programs.
When programming is completed, press CLOCK button to exit programming.
Press ON/AUTO/OFF button until Auto displays.
Nov 27, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
How do you set this to go on at a certain time and off at a certain time for the whole week.
The ST01C timer has 40 available programs.
You are going to use 1 program.
First, you set program1 ON time
And then set the days-of-the-week to ALL
Next, you set program1 OFF time
And set the days-of-the-week to ALL
The days for the ON and days for the OFF have to be the same.
The timer gives you choices of M-F -or- WDK weekdays -or- ALL for all 7 days
The steps are shown in section 6 of the manual
http://waterheatertimer.org/Intermatic-st01c.pdf
The following page has large easy-to-read ST01C instructions:
Set ON-OFF times is shown in step 4
http://waterheatertimer.org/ST01C-program.html
The important thing is that both the ON and OFF times have days set to ALL
add a comment if you need more help
Nov 06, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have programmed the timer and it doesn't turn on/off. What did I do wrong? thanks!
People seem to have a problem getting the Woods 59377 programmed.
Solutions have been posted but nobody posted back and said, oh, that's what happened, and here's what to do. So without feedback, it's hard to say where the problem is for sure.
After looking at the programming steps myself several times, I believe the most confusing part is the 'blocks of days.' As a result, people may be entering a 'conflict' in their ON OFF times.
For example, if program 1 says ON at 7 and OFF at 8 for certain days, but program 8 says the opposite, then the timer will not function as expected.
The suggested solution is to make a chart of ON OFF times before programming. And then carefully watching the screen for prompts to make sure each ON time has an OFF time.
Re-post your solution and it will help others. Thanks in advance.
Oct 14, 2010 | Woods Industries 59377 Indoor Digital...
How to set timer
Hello.
I just made two youtube videos on this Westinghouse Tri Mode Digital Outdoor Timer 28499. The first video shows how to set the day and time. You can find it here
http://www.youtube.com/watch?v=qV7Fj6TMNMw&feature=related
The second video details how to program it to go on and off at certain times of the day on certain days of the week. You can find this video here
http://www.youtube.com/watch?v=cSVN2V8EE5s&feature=iv&annotation_id=annotation_608324
I did my best to demonstrate how to do this.
Thanks
Nov 30, 2009 | Heavy Duty Westinghouse 3-Outlet Outdoor ...
Hardware & Accessories Logo
66 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
