Question about Casio "FR-2650TM Two-Color Printing Desktop Calculator, 12-Digit Digitron, Black/Red"
I am having trouble inserting paper into the Casio FR-2650TM.
When I insert the paper roll the feed will work fine until I reinstall the plastic cover. Then the feed will no longer work. What am I doing wrong ?
  • 641 Answers
SOURCE: Casio Exilim won't turn on when memory card is inserted
It sound like a bent pin issue. Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in. From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break. Good luck !
Posted on Aug 22, 2007
taran_2005
  • 10515 Answers
SOURCE: Casio fr-2650 plus calculator
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Do rate the solution.
Posted on Apr 05, 2009
jackcity
  • 34 Answers
SOURCE: HOW TO INSTALL PAPER ROLL IN CASIO HR-8TM
There is a slot just in front of the printer
1. turn the power on
2. turn the switch to "PRINT" position
3. slot the paper in & press "FEED"
4. the paper should be able to feed up
Posted on Sep 13, 2009
SOURCE: Casio FR-620TER no manual need instructions..plz
I have this problem too. Did you get instruction already? Can YOU help me?
imwinde@gmx.de
Regards
Posted on Dec 07, 2009
SOURCE: I have a borrowed Casio FR 105S printing
Make sure the paper has a straight clean edge. Feed the paper into the slot in the back - make sure the paper is straight. Paper will go in about 1/4 inch. Push the feed button and the paper should feed through the printer.
Posted on Feb 14, 2010
How do i feed the paper of the casio fr 2500 printing calculator
Hello Michel Dekock,
Could not find your FR2500 (but close)...
Has worked every time for me...
Mount the paper roll on the wire bracket... feeding
over the top of the ROLL (TOWARD THE MACHINE).
With the keyboard FACING away from yourself
Fold the FRONT EDGE of the PAPER on to the
side to form a chisel point... and insert the point
(folded side up) in the rear roller slot (paper feed)...
As shown on FR2650
http://www.ebay.com/itm/Casio-FR2650TM-Printing-Calculator-FR2650TM-/122298781152?hash=item1c79934de0:g:bwEAAOSw44BYbWjv
With the PRINT feature turned on the roll should be
advancing while holding down the TOTAL key...
Hold the key until the edge of the paper roll emerges from the machine.
Hope that helps.
(now you only have to freshen up the ink).
https://en.wikipedia.org/wiki/Carnac_the_Magnificent%E2%80%8B
Mar 27, 2017 | Casio Office Equipment & Supplies
Im looking for an owners manual for a casio FR-1011calculator
Manuals - Support - CASIO
www.casio.com > Home > Support
CasioManuals are available for free on our website by selecting one of the links below. If you need a manual to be printed and mailed to you please call ...
FR-2650TM - Graphing, Fraction & Scientific ... - Casio
www.casio-usa.com > ... > Products > Calculators & Dictionaries > Printing
Manual. (Opens a new window) Product Manuals(Opens a new window). Technical Specs. FR-2650TM Technical Specifications ... Service Locations.
Dec 02, 2015 | Casio Office Equipment & Supplies
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
How to feed paper roll into calculator
Installing the Paper Roll
Caution: Avoid placing a double thickness of paper into the mechanism.
Do not pull the paper through the mechanism without pressing feed button.
1. If necessary, press on to turn the calculator on, and press P
to turn the PRINT display indicator off.
2. Remove the printer compartment cover by placing a thumb on each of the lower ridged corners of the cover. Push until the cover pops open, and lift the cover off.
3. Unroll a few inches of paper from the small roll and cut the end squarely.
4. Hold the paper so that it unrolls from the bottom, and insert the end of the paper into the slot under the printing mechanism.
5. Press feed button until the paper feeds out of the top of the printer compartment.
6. Place the small roll of paper inside the compartment.
7. Feed the end of the paper through the slot behind the clear plastic "window" of the printer compartment cover. Then snap the compartment cover back onto the unit.
Jun 07, 2011 | Texas Instruments TI-5006 II Calculator
Will not feed paper
PAPER ROLL REPLACEMENT
Never insert paper roll if torn. Doing so will cause paper to
jam.
Always cut leading edge with scissors first.
1) Insert the leading edge of the paper roll into the opening.
(Fig. 1)
2) Turn the power on and feed the paper by pressing . (Fig.
2)
3) Lift the attached metal paper holder up and insert the paper
roll to the paper holder. (Fig. 3)
DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
DAMAGE TO PRINTING MECHANISM.
Dec 19, 2010 | Sharp EL-1801AII Calculator
Jul 18, 2009 | Casio FR-2650A Calculator
Loading the paper
Cut the paper off clean.
Slid it through the slot on the back.
The place the paper between the black plastic rail,
and the bottom of the calculator.
Keep feeding it in the slot untill you can see it under the
foam wheel.
The repedably hit the feed button until the paper comes
out the other side.
If it does not feed, the paper is not under the wheel far enough.
This should work on other similar models as well.
Dec 24, 2008 | Casio HR8TM Calculator
Casio FR-2650A
the tape goes into a small slot on the backside of the machine, not in the clear plastic cover. Install the roll so the paper rolls off the bottom, not over the top. Folding the paper back about 2" does help you get it through.
Aug 30, 2007 | Sharp CS-2850 Calculator
Casio "FR-2650TM Two-Color Printing Desktop Calculator, 12-Digit Digitron, Black/Red" Logo
47 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
