Question about Samsung Hl-p5085w 50-inch Widescreen Hd-ready Dlp Television With Pc
My Samsung HL-P5085 screen works for about 5 minutes then turns off but sound is still on what could be the problem?
  • 304 Answers
SOURCE: Samsung DLP HL-R6167W - works fine for about 5
There are three possible parts causing the problem. First, the Main or Digital bd is bad, Second, the DMD bd is bad. Third the Color Wheel is bad. You need a trained Samsung tech to have a look at it.
Posted on Jul 16, 2009
tvservice306
  • 458 Answers
SOURCE: samsung dlp hl-s6187w turns itself off after about
check or replaced LAMP-BALLAST board
Manufacturer Samsung Part Number BP47-00037A Description LAMP-BALLAST;EUC 132
Posted on Nov 09, 2009
SOURCE: HAS SOUND BUT NO PICTURE
okay the reason that the its turning off could be the fan isnt spining fast enoug hold your hand at the back of the tv to feel where the exhaust air if isnt good enough to help cool off the bulb then the fan may need to be replaced also the balast could be going bad and last check the power supply that feeds the balast make sure its a constant dc voltage
Posted on Apr 13, 2010
  • 8457 Answers
SOURCE: I have a Samsung HL-R5678W
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Posted on Oct 22, 2010
  • 11800 Answers
SOURCE: Hi, my Samsung 40" LCD TV's
Actually no board/part is defective - you have a bad contact that when the tv heats up it fails. Since the screen goes totally black but not light goes out on the tv and the sound still goes on then the problem is in the mainboard or the connection between the mainboard and the t-con board - a wide flat cable.
You must open the tv and reseat the connecting cables. If this doesn't fix it then the problem is in a soldering: you will have to remove the boards and check by eye every single soldering - redo all that look suspicious; you will probably have to move the components with your fingers to clearly see a bad soldering in their pins.
Posted on Nov 02, 2010
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
My Samsung HL-R4667W rear projection tv turns off -- has sound but no picture. You then have to turn the tv completely off, wait a few minutes, then it will come back on with picture and sound. It may...
Lamp or Lamp Fan For replacement Lamps Call Mats Electronics 1-800-628-1118
for other Parts/Boards Call Encompass Parts Distrubtion 1-800-638-3328
Replace Lamp!
Mar 02, 2010 | Samsung HL-R4667W Rear Projection...
Replaced buld still no picture only sound
I have been having a similar problem with my Samsung # HL-R5087W.
I will be watching the TV and then it will lose the the picture, just sound. I then, turn off the TV for a minute and turn it back on. Works for another 30 minutes to 2 hours til it happens again. Weird!
Oct 19, 2009 | Samsung HL-R5087W Replacement Lamp
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung flat screen problems
you will have a years guantee
Jan 06, 2009 | Samsung HL-S4266W 42" HDTV
Samsung HL-R6167W set turns itself off
sounds like the digital main board, seen this before
Jul 18, 2008 | Samsung HL-R6167W 61" HDTV
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Samsung Hl-p5085w 50-inch Widescreen Hd-ready Dlp Television With Pc Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
